 back fire through carb help
crafsmankiller
Junkstarbuilds
jaymz
8 posters
Go to page : Previous  1, 2
jaymz
back fire through carb help - Page 2 Empty
PostSubject: Re: back fire through carb help   back fire through carb help - Page 2 Icon_minitimeOctober 21st 2012, 11:11 am
I hope it works tho, if not im gonna have to admit defeat and shes going to the shop Sad
jaymz
PostSubject: Re: back fire through carb help   back fire through carb help - Page 2 Icon_minitimeOctober 21st 2012, 11:55 am
well guys i appreciate everyones help, Ive eliminated everything we've talked about and unfortantly its beyond me now, shes got a date with a shop mechanic now Sad the real shitty thing is you know its gonna be something really simple and dumb and its prolly gonna cost a fortune lol i guess thats the price of learning though. still open to suggestions since im not going to take it next week or so. but to recap we know its not a carb problem now since i switched carbs with one off my working mower and it does the same thing, almost positive its not a valve clearence problem. soooo that leaves.........possesed possily? haha btw we cured the back firing through the carb problem but still fighting it only running on choke. Also compression is great, great spark and great fuel flow not only out the fuel line but also out the bottom of the float bowl....I also went to the extreme of putting a new battery in it just to eliminate all we talked about.
jaymz
PostSubject: Re: back fire through carb help   back fire through carb help - Page 2 Icon_minitimeOctober 21st 2012, 11:57 am
wait, when timing one of these small motors, Ive noticed something.....when i turn that motor to TDC, sometimes theres no valve clearence at all but i can rotate the motor over a cycle back to TDC agian and i have perfect clearence...is that normal??? is it possible Ive timed it on the wrong stroke of the cycle????
Chopperhed
Chopperhed
PostSubject: Re: back fire through carb help   back fire through carb help - Page 2 Icon_minitimeOctober 21st 2012, 12:47 pm
Yes its possible to time the wrong stroke of an engine. If it was it wouldn't run at all
I still say its carb related. Generally as a rule, backfiring is caused by a lean condition. If it was backfiring every stroke, then it could be valves, but if it only pops occasionally, its a fuel system issue.
Don't assume that the carb off your running engine is good for this engine either.. ALL engines are different when it comes to fine tuning. even between engines of the same make model and size.
If it makes you feel any better, the carbs on my bike had to be gone through several times before I found the problem.
It was a olugged passage I couldn't even see with the naked eye. I've seen this problem on many dozens of motors over the last 30 years or so.
jaymz
PostSubject: Re: back fire through carb help   back fire through carb help - Page 2 Icon_minitimeOctober 21st 2012, 1:15 pm
yeah chopper that makes since now that you mention it, the good carb is off a 14 hp and the one im workin on is a 16.5 hp. for kicks i stuck the carb off my broken mower on the good one and it did the same thing the broke one did b4 it died, it missed and carried on at full throttle...so i guess its a day of cleaning carbs...what is the carb " dip " everyone talks about....is that something you can do at home???
jaymz
PostSubject: Re: back fire through carb help   back fire through carb help - Page 2 Icon_minitimeOctober 21st 2012, 2:52 pm
PROGRESS!!!!!!! i took a guitar string and used it to clean the high flow jet out and sprayed it out and the thing actually ran on full throttle for a few seconds b4 sputtering out and dying.....I gotta go out and buy a blow tip for my air compressor since mine has mysterously went MIA lol
Junkstarbuilds
Junkstarbuilds
PostSubject: Well I'm glad things are making progress   back fire through carb help - Page 2 Icon_minitimeOctober 21st 2012, 3:16 pm
Well that's good news that you may have found some of the problem. Good thing is cleaning is a cheap fix .
Chopperhed
Chopperhed
PostSubject: Re: back fire through carb help   back fire through carb help - Page 2 Icon_minitimeOctober 21st 2012, 4:53 pm
carb dip is available from parts stores. It comes in several names and formulas.
try to avoid using steel wire or anything hard. brass jets are soft and can scratch easily, changing the metering. A piece of straw from a broom works, or something similar. I only use my mini drills if I know the exact size the jet is supposed to be.
Check out old motorcycle resto forums to see what they do. You'd be surprised what works.
jaymz
PostSubject: Re: back fire through carb help   back fire through carb help - Page 2 Icon_minitimeOctober 21st 2012, 6:24 pm
Ive got one heck of a clog in the passage for the fuel, sometimes the carb cleaner will go through it, other times it wont, theres a 90 degree bend inside there im having problems reaching with my wire.....i guess its a long night of carb cleaner, probing and compressed air blowing...yay!
Junkstarbuilds
Junkstarbuilds
PostSubject: Good Luck   back fire through carb help - Page 2 Icon_minitimeOctober 22nd 2012, 9:22 pm
I hope you get it all working right.
jaymz
PostSubject: Re: back fire through carb help   back fire through carb help - Page 2 Icon_minitimeOctober 30th 2012, 6:41 pm
good news! she now purrs like a kitten in heat! runs great...actually better!
Junkstarbuilds
Junkstarbuilds
PostSubject: Awesome   back fire through carb help - Page 2 Icon_minitimeOctober 30th 2012, 6:56 pm
So what happened? Did you take it in to be fixed? What did they do...what did they charge yah?
jaymz_eric
PostSubject: Re: back fire through carb help   back fire through carb help - Page 2 Icon_minitimeNovember 3rd 2012, 10:48 am
believe it or not i sea foamed the hell outta it after blowing the heck outta the carb with my air compressor.....runs great now.....must have been a tiny clog somewhere
tractorboy567
tractorboy567
PostSubject: Re: back fire through carb help   back fire through carb help - Page 2 Icon_minitimeJanuary 23rd 2013, 4:42 pm
if the carb is sucking air out that in than it is the timing. i just had a gocart in with the same problem. could also be spark.
» Backfires when brought to low idle
» Tecumseh hh100 carb
» im back and married and the wife wants me to get back into monster mowers
» help need cub 106 carb
» Need a new carb!
