 axle question;
ironart
axle question; Empty
PostSubject: axle question;   axle question; Icon_minitimeOctober 6th 2012, 11:02 pm
Bought a Wheelhorse 212-6 lawn tractor at auction yesterday. The 12hp kawasaki fired up and ran beautifully. Found rear tire flat..went to remove it and discovered that the left axle has a lot of "wobble" are there bushings or bearings available for these transaxles..on the outboard end...
greener179
greener179
PostSubject: Re: axle question;   axle question; Icon_minitimeOctober 7th 2012, 1:30 pm
im not sure but my left axle does the same thing
Junkstarbuilds
Junkstarbuilds
PostSubject: could be plastic or brass   axle question; Icon_minitimeOctober 8th 2012, 7:15 am
most bearings/bushings are either nylon/plastic or brass. You should be able to find either to shim out the wobble. I have gone as far as cutting a sleave to use as a bushing from a cheap broom handle, but I dont recommend that.
You should be able to find a schematic of the transaxle by searching for replacement parts. then look to see if your model has or missing parts..
I use those schematics when re-assembling my transaxles to make sure I dont leave anything out..
here is an example:
TRANAXLE BIBLE
axle question;
» transaxle axle question?...
» how NOT to lock a mtd axle
» axle repair help
» keyway in axle or new axle??
» Can I tow a LT without an axle with another LT? Maybe ...
