 Cracked up tires
greener179
Tractor Man Jeff
7 posters
Tractor Man Jeff
Tractor Man Jeff
Cracked up tires Empty
PostSubject: Cracked up tires   Cracked up tires Icon_minitimeSeptember 9th 2012, 9:47 pm
Guys, My front tires are next to no good. Both leak air and are cracked up really bad, so a tube is out of the question. What do y'all suggest I do to squeeze just a little more life out of them? I can't spend $140 bucks on new tires. To make matters worse, they are(as luck would have it) an odd ball size. (22x7-10) Any suggestions?
PostSubject: Re: Cracked up tires   Cracked up tires Icon_minitimeSeptember 9th 2012, 9:58 pm
Why is a tube out of the question? My rears are cracked so bad they are missing chunks of the outer rubber... a tube works fine for them. #shrug#
Chaos Build
Check out the pics and vids!
Haspin 2021 thread
Haspin Acres Rally 2022!
TheRainbowBoxer on YouTube
Tractor Man Jeff
Tractor Man Jeff
PostSubject: Re: Cracked up tires   Cracked up tires Icon_minitimeSeptember 9th 2012, 10:00 pm
I figured they would just slice the tubes. Plus, I can't find any that fit my tire size.
greener179
greener179
PostSubject: Re: Cracked up tires   Cracked up tires Icon_minitimeSeptember 9th 2012, 10:05 pm
mine were cracked really bad i bought tubes and a thing of thick silicone and rubed it into the cracks now you cant even teell it had cracks
Tractor Man Jeff
Tractor Man Jeff
PostSubject: Re: Cracked up tires   Cracked up tires Icon_minitimeSeptember 9th 2012, 10:09 pm
Like I said, I can't seem to find any tubes that fit my tire size. I hate odd ball sizes.
W1ldyOvvnZ
W1ldyOvvnZ
PostSubject: Re: Cracked up tires   Cracked up tires Icon_minitimeSeptember 9th 2012, 10:43 pm
Whats the bolt pattern for the rim? what about finding use tires and rims.
http://www.stat10.tk/
greener179
greener179
PostSubject: Re: Cracked up tires   Cracked up tires Icon_minitimeSeptember 10th 2012, 7:44 am
i found a 23x7x10 tube it would work just wouldnt fill it up all the way
Tractor Man Jeff
Tractor Man Jeff
PostSubject: Re: Cracked up tires   Cracked up tires Icon_minitimeSeptember 10th 2012, 2:42 pm
Don't know. All I know is the hubs came off a Honda 250 HPX ATV. How much and where did ya find the tube?
redneckcarrow
redneckcarrow
PostSubject: Re: Cracked up tires   Cracked up tires Icon_minitimeSeptember 10th 2012, 3:47 pm
tubes don't have to be the exact same size as the tire thay will streatch quit a bit just dont get one bigger then your tire becouse you don't wont to wrinkel the tube in the tire becouse it wont last that long that way
Tractor Man Jeff
Tractor Man Jeff
PostSubject: Re: Cracked up tires   Cracked up tires Icon_minitimeSeptember 10th 2012, 4:00 pm
I suppose I could. Tubes themselves are pricey at napa. Almost $20 bucks for two. I know, I'm nuts to say $20 bucks is a lot, but I'm trying to save big time because I don't yet have a job yet. What size of tube do y'all suggest I get?
greener179
greener179
PostSubject: Re: Cracked up tires   Cracked up tires Icon_minitimeSeptember 10th 2012, 11:00 pm
http://www.kenjones.com/Scripts/XListAll.aspx?XGID=TUBES_ATV they have a whole bunch of different tubes there
CornishMorgan
PostSubject: Re: Cracked up tires   Cracked up tires Icon_minitimeSeptember 11th 2012, 10:31 am
Have a look on ebay, I got a new inner tube for the front wheel of my tractor for less than £10. I have to get a new tube for one of the rear tires at some point and thats only £13.
Tractor Man Jeff
Tractor Man Jeff
PostSubject: Re: Cracked up tires   Cracked up tires Icon_minitimeSeptember 11th 2012, 12:57 pm
What's that in US dollars? Smile
greener179
greener179
PostSubject: Re: Cracked up tires   Cracked up tires Icon_minitimeSeptember 11th 2012, 2:04 pm
its about 16 dollars 72 cents for 13 euros
Tractor Man Jeff
Tractor Man Jeff
PostSubject: Re: Cracked up tires   Cracked up tires Icon_minitimeSeptember 11th 2012, 3:55 pm
Gotcha, bout the same here. I'm heading into town now. I'll see what I can find for tubes.
CornishMorgan
PostSubject: Re: Cracked up tires   Cracked up tires Icon_minitimeSeptember 11th 2012, 5:05 pm
I am in the UK, the UK does not use euros, we use pounds.
£13 is about $20.90 USD
Tractor Man Jeff
Tractor Man Jeff
PostSubject: Re: Cracked up tires   Cracked up tires Icon_minitimeSeptember 11th 2012, 6:37 pm
OK. I found nothing. I'll keep my eyes peeled.
greener179
greener179
PostSubject: Re: Cracked up tires   Cracked up tires Icon_minitimeSeptember 11th 2012, 9:21 pm
my bad i dont know why i thought it was euros
CornishMorgan
PostSubject: Re: Cracked up tires   Cracked up tires Icon_minitimeSeptember 11th 2012, 9:49 pm
No, There are 17 countries that use the euro, luckily the UK isn't one of them.
redneckcarrow
redneckcarrow
PostSubject: Re: Cracked up tires   Cracked up tires Icon_minitimeSeptember 12th 2012, 7:32 pm
sorry it took couple days to respond dont mess with auto parts stors for tubes find a tire shop tell them what size tire you have and thay should have something to fit
Tractor Man Jeff
Tractor Man Jeff
PostSubject: Re: Cracked up tires   Cracked up tires Icon_minitimeSeptember 12th 2012, 10:28 pm
Yeah, They don't have it anyway. I'm going to look around on the web and see if I can dig up something.
Hillbilly Homer
Hillbilly Homer
PostSubject: Re: Cracked up tires   Cracked up tires Icon_minitimeSeptember 13th 2012, 1:12 am
Like a Star @ heaven ...Homemade Tire fix... Like a Star @ heaven
1 tube of Latex Window Caulking. Cost $2.00
1 cup old used or cheap antifreeze. Cost ?
10 squares of Good quality toilet paper. YES tp.. Exclamation
mix 1/2 of antifreeze with the tp the other with the Caulking.
Then mix the tp slurry and caulking slurry well.
Knock the bead of one side of tire and pour mix into the tire.
Air up the tire to desired PSI and slosh around.
Yes it works.
Tractor Man Jeff
Tractor Man Jeff
PostSubject: Re: Cracked up tires   Cracked up tires Icon_minitimeSeptember 13th 2012, 10:12 am
Wow. TP?? Your kidding. Very Happy Do you pour both mixtures in the tire?
PostSubject: Re: Cracked up tires   Cracked up tires Icon_minitimeSeptember 13th 2012, 10:27 am
LOL No, you drink the TP mixture LOL
I would guess that both get poured into the tire...
Chaos Build
Haspin 2021 thread
Hillbilly Homer
Hillbilly Homer
PostSubject: Re: Cracked up tires   Cracked up tires Icon_minitimeSeptember 13th 2012, 12:27 pm
Mix the tp slurry WITH the caulking slurry mix up good pore it into tire.
The tp acts as a clotting agent for bigger holes.
Cracked up tires
» What do you do with a cracked water containing seat?
» which mud tires?
» what tires to get?
» What tires should I get?
» Mud tires?
