| Mud tires? | |
+2gilsonrumbler RompinRedneck 6 posters |
RompinRedneck Member
Age : 31 Join date : 2012-01-01 Points : 4761 Posts : 41 Location : CT
| Subject: Mud tires? January 18th 2012, 7:00 pm | |
| I have stock carlisle turf tires on my Wheel Horse and those just aren't going to cut it for the mud. They are 18x8.50x8. There really arent many choices for aggressive tires from what i've seen. Should I look harder? Or should I get some different wheels? The tallest i'd go is 20" by the way. Thanks. | |
gilsonrumbler Member
| Subject: Re: Mud tires? January 18th 2012, 7:26 pm | |
| carisle has AG tires (AKA V lugs.... tractor tread) in size 18x9.50x8 for 60 apeice but they last forever unless you cut a hole in them or they rot out... i have a set of 26x12x12 and they haven't lost any tread i did have to put a tube in one because the tire started rotting away from being older than moses... Yes 18x9.50x8.50 will fit on your current rim it would just be a tad bit wider which looks cool to some. The taller you go with agressive tire tread the more likely the transaxle can crack depending on the model so 18s is a safe bet. just my .02 | |
| Subject: Re: Mud tires? January 18th 2012, 7:27 pm | |
| Okay, I was just worried about the extra half inch of width on each side, causing some c;earance/rubbage issues. Looks like i'll have to take some measurements to be sure. Thanks | |
Jordan Member
Age : 30 Join date : 2010-10-03 Points : 5357 Posts : 170 Location : Ontario Canada
| Subject: Re: Mud tires? January 18th 2012, 7:34 pm | |
| i put a set of 25 12.5 12 bear claws on my stock tractor, no problems with rubbing but i had to raise the fenders a half inch because they rubbed | |
| They should fit with no problem i've had wider and taller tires on many different tractors, only way i think they would rub is if you were to run them on the front which i don't think is the case..... | |
| Subject: Re: Mud tires? January 18th 2012, 7:35 pm | |
| - Jordan wrote:
- i put a set of 25 12.5 12 bear claws on my stock tractor, no problems with rubbing but i had to raise the fenders a half inch because they rubbed
^ had to do the same when i put 26s on the gilson | |
| Subject: Re: Mud tires? January 18th 2012, 7:40 pm | |
| Okay thanks. I guess it looks like I'll be saving up for some super lugs. I think those would be just at home in the mud! | |
| Subject: Re: Mud tires? January 18th 2012, 7:42 pm | |
| - RompinRedneck wrote:
- Okay thanks. I guess it looks like I'll be saving up for some super lugs. I think those would be just at home in the mud!
oh they will just don't let the clutch out too fast if you have swapped pulleys.... they GRAB and DIG hard! | |
| Subject: Re: Mud tires? January 18th 2012, 7:44 pm | |
| Both pulleys are stock and I have Hi and Low gearing. I am yet to try her out, but I think she'll do alright. No need for a fast top speed on a mudder anyways. | |
dagr8tim Member
Age : 48 Join date : 2012-01-01 Points : 4943 Posts : 194 Location : Columbus, Oh
| Subject: Re: Mud tires? January 18th 2012, 9:20 pm | |
| You can also spend $40 on ebay for a tire groover and make your own cheap mud tires. | |
| Subject: Re: Mud tires? January 18th 2012, 9:22 pm | |
| - dagr8tim wrote:
- You can also spend $40 on ebay for a tire groover and make your own cheap mud tires.
I assume you are referring to turf tires. Like remove every other "knob" so there are bigger voids? | |
dagr8tim Member
| Subject: Re: Mud tires? January 18th 2012, 9:52 pm | |
| Yea that resembles siping more or less, at least in my opinion. I would love to do it because it has the potential to save me money, BUT one of my rear tires has no hope with all the dry rot and leaks. I'd be better off getting those carlisle super lugs imho. Thanks for the idea though! | |
dagr8tim Member
| Subject: Re: Mud tires? January 18th 2012, 10:00 pm | |
- Yea that resembles siping more or less, at least in my opinion. I would love to do it because it has the potential to save me money, BUT one of my rear tires has no hope with all the dry rot and leaks. I'd be better off getting those carlisle super lugs imho. Thanks for the idea though!
Siping are smaller cuts to improve traction on wet pavement or ice. | |
Jamus Established Member
Age : 45 Join date : 2010-06-28 Points : 5808 Posts : 511 Location : Southern WV
| Subject: Re: Mud tires? January 18th 2012, 11:53 pm | |
| While watching those youtube clips I saw one on the side to a guy who used a chisel(wood?) and a torch to groove his tires. Not as pretty as the real thing, but I'd give it a shot on some mower tires. If I didn't have enough ATV tires that it. | |
| Subject: Re: Mud tires? January 19th 2012, 8:23 am | |
Siping are smaller cuts to improve traction on wet pavement or ice. While that may work on mud tires, I don't really think it would be too effective on turf tires with the intention of mud performance | |
AcreFarm Member
Age : 40 Join date : 2011-11-02 Points : 4938 Posts : 208 Location : Tennessee
| Subject: Re: Mud tires? January 19th 2012, 1:04 pm | |
| I used razor blades to cut the tread blocks on a pair of super-turf tires. It was tedious work, trying not to puncture the tire or my fingers. | |
| Subject: Re: Mud tires? January 19th 2012, 1:13 pm | |
| to correct my mistake in one of my post, 18x9.50x8 will fit your rim and cut turf tires do work but there are certain limits to where they will start to cake with mud... heres a set i cut and ran for awhile | |
| Subject: Re: Mud tires? January 19th 2012, 1:29 pm | |
| - gilsonrumbler wrote:
- to correct my mistake in one of my post, 18x9.50x8 will fit your rim and cut turf tires do work but there are certain limits to where they will start to cake with mud... heres a set i cut and ran for awhile
Yea they will work, but for what i'm going through they will cake right up and won't clean themselves out. | |
| Subject: Re: Mud tires? January 19th 2012, 1:39 pm | |
| thats where AG tires come in, i love mine because they dig and push right through anything | |
| Subject: Re: Mud tires? January 19th 2012, 2:04 pm | |
- thats where AG tires come in, i love mine because they dig and push right through anything
Thanks for all the help. And if I came across as being rude, I didnt mean it. | |
| Subject: Re: Mud tires? January 19th 2012, 2:09 pm | |
| oh no problem and you weren't in anyway rude so its all good | |
| Mud tires? | |
