 Transmission with Side input and output shafts?
W1ldyOvvnZ
W1ldyOvvnZ
Transmission with Side input and output shafts? Empty
PostSubject: Transmission with Side input and output shafts?   Transmission with Side input and output shafts? Icon_minitimeJune 9th 2012, 5:45 pm
Does anyone know of a Transmission with a side input and output shaft? Preferably a 3-6 speed? Ive been thinking of trying to put something like that in a Lawn Tractor.
http://www.stat10.tk/
Jordan
Jordan
PostSubject: Re: Transmission with Side input and output shafts?   Transmission with Side input and output shafts? Icon_minitimeJune 10th 2012, 10:01 pm
are you thinking 2 trannys?
i have a murray gt16 vertical shaft engine but side input tranny one belt from the motor to a right angle gear box then another belt from that to the tranny, so im replacing the right angle gear box with a tranny i have that will do the same job but with different speeds...im going to end up with 13 forward speeds and 7 reverse speeds a top speed of about 20 mph but still low gears for turnin dirt
ironart
PostSubject: Re: Transmission with Side input and output shafts?   Transmission with Side input and output shafts? Icon_minitimeJune 17th 2012, 4:10 pm
Wildy;
This link I posted on my question on my new to me..but old JD 100. This trans is listed as coming from a Cub Cadet. It looks just like the one in my JD 100, cast iron housing..I believeit was listed as a Peerless 1200. Hope this helps...
http://jnemes.com/yahoo_site_admin/assets/docs/1214.8780511.jpg
W1ldyOvvnZ
W1ldyOvvnZ
PostSubject: Re: Transmission with Side input and output shafts?   Transmission with Side input and output shafts? Icon_minitimeJune 18th 2012, 11:22 pm
My original idea was to take a horizontal shaft diesel and put a live axle and make it all chaindrive, I was hopping someone would know one that would be like a Rear Engine Rider Transmission but with the input on the side. I guess im going to skip the deisel and just use a Vertical shaft Gasser and a Rear Engine rider Transmission.
» mud monster
» stator output ac
» Overdriving the output of a Hydro? Has anyone did it and how long did it last?
» Leaking input shaft
