 monster muddy orange
Chopperhed
SuperMudMuppet
CornishMorgan
Junkstarbuilds
greener179
Tractor Man Jeff
Josh Blair
craftsman30mph
Shawn1750
WellThatsSurprising
Craigsnedeker
idlorah
gearheadmike
superswamper77
dked41
Wheel Crazy
W1ldyOvvnZ
matthew sidor
26 posters
matthew sidor
monster muddy orange - Page 3 Empty
PostSubject: Re: monster muddy orange   monster muddy orange - Page 3 Icon_minitimeJune 30th 2012, 8:06 pm
today i was riding in the woods on my dirtbike and i found a 25x12-9 Dunlop atv tire in a ditch out on the logging roads how lucky am I
monster muddy orange - Page 3 541587_381477778580324_1422797123_n
monster muddy orange - Page 3 600186_381477811913654_1213365477_n
monster muddy orange - Page 3 251967_381477838580318_1904835817_n
matthew sidor
matthew sidor
PostSubject: Re: monster muddy orange   monster muddy orange - Page 3 Icon_minitimeJuly 10th 2012, 10:30 pm
Finally took the Spicer out to weld the spider gears and put a new hub on one side. I'm going to rebuild the drive-shaft and make it how its supposed to
be already have the drive-shaft grinded off so it shouldn't be long until I have that done I just need to order a new pillow block bearing. Also when I get
some rims for my two new tires i just got I'm gonna put my 22s in the front to give it nice look. I will post pics over the next couple days on my progress
monster muddy orange - Page 3 205353_385923564802412_2004105036_n
monster muddy orange - Page 3 531673_385923544802414_1242849719_n
monster muddy orange - Page 3 578791_385923521469083_1198889891_n
monster muddy orange - Page 3 431941_385923538135748_245410081_n
matthew sidor
matthew sidor
PostSubject: Re: monster muddy orange   monster muddy orange - Page 3 Icon_minitimeJuly 11th 2012, 11:15 pm
Today I decided to weld the drive-shaft together and weld in the 3/4 shaft collar onto my pulley. My uncle told me not to weld the spider gears and
keep it stock because he did it before and broke it and he told me it cost way to much to fix. I also replaced the old long drive-shaft and welded the
other hub to the other side. Now I have to figure out how high my pulley has to go so I can cut the drive-shaft so its short enough to fit. Right now
its too long. then I have to order my pillow block bearing so i can put the drive-shaft together. lastly my new magneto that I just got doesn't fit so I
have to drill some holes into it so it will fit where it needs to go and hopefully that will work.
monster muddy orange - Page 3 402961_386257194769049_969288911_n
monster muddy orange - Page 3 483295_386257248102377_2082869318_n
monster muddy orange - Page 3 599472_386257254769043_1311210183_n
monster muddy orange - Page 3 576212_386257314769037_625993280_n
monster muddy orange - Page 3 484053_386257351435700_1057973796_n
monster muddy orange - Page 3 399495_386257268102375_702526496_n
monster muddy orange - Page 3 320493_386257284769040_1380264973_n
matthew sidor
matthew sidor
PostSubject: Re: monster muddy orange   monster muddy orange - Page 3 Icon_minitimeJuly 16th 2012, 10:21 pm
put a new gas pedal on
monster muddy orange - Page 3 402784_387909864603782_494517236_n
monster muddy orange - Page 3 396072_387909887937113_1587446958_n
Then i put an extra gas tank in the back so i have two
monster muddy orange - Page 3 539654_387909924603776_308804889_n
matthew sidor
matthew sidor
PostSubject: Re: monster muddy orange   monster muddy orange - Page 3 Icon_minitimeJuly 25th 2012, 1:09 am
has anyone put a dirtbike carburetor onto a lawnmower and is it a good idea for a little bit better throttle response and power please respond
PostSubject: Re: monster muddy orange   monster muddy orange - Page 3 Icon_minitimeJuly 26th 2012, 7:00 am
Dirtbike, snowmobile, motorcycle carbs should give a ton more throttle response/power - youd need to make a flange to hook it to the motor tho - or simply use an old radiator hose with hose clamps - just make sure it doesnt bounce around a lot - needs to be stable.
matthew sidor
matthew sidor
PostSubject: Re: monster muddy orange   monster muddy orange - Page 3 Icon_minitimeJuly 26th 2012, 12:27 pm
Ok thanks i already had it all set up and done i just wanted to know if it was a good idea to do it. I have a picture on the first page of what it looks like
matthew sidor
matthew sidor
PostSubject: Re: monster muddy orange   monster muddy orange - Page 3 Icon_minitimeJuly 26th 2012, 5:56 pm
yes like literally 2 seconds ago i got my pillow block bearing finally. ill post the drive shaft on the next sunny day when i get too installing it.
monster muddy orange - Page 3 311595_391579134236855_449603167_n
matthew sidor
matthew sidor
PostSubject: Re: monster muddy orange   monster muddy orange - Page 3 Icon_minitimeJuly 30th 2012, 7:14 pm
Did anyone know that parts off some weight benches can be used on racing mowers i found that out today. its sweet it bolts right into the stock place. You just need some spindles for it.
monster muddy orange - Page 3 268269_392622084132560_1656723042_n
matthew sidor
matthew sidor
PostSubject: Re: monster muddy orange   monster muddy orange - Page 3 Icon_minitimeJuly 31st 2012, 11:11 am
W1ldyOvvnZ
W1ldyOvvnZ
PostSubject: Re: monster muddy orange   monster muddy orange - Page 3 Icon_minitimeJuly 31st 2012, 11:14 pm
matthew sidor wrote:
i want this truck.
http://orlando.craigslist.org/cto/3133079680.html
I wouldn't fork out $40k on that thing. You couldn't even drive it on the street(you probably wouldn't want to considering the tires are probably $2,000 a corner).
http://www.stat10.tk/
matthew sidor
matthew sidor
PostSubject: Re: monster muddy orange   monster muddy orange - Page 3 Icon_minitimeAugust 1st 2012, 4:11 am
I wouldn't spend that much either on something like that but it doesn't mean I don't want it.
PostSubject: Re: monster muddy orange   monster muddy orange - Page 3 Icon_minitimeAugust 1st 2012, 7:12 pm
Its not street legal , mainly for the tire size ( width) - ive seen some lifted trucks around tho. Heck used to see a lifted lincoln ( donk style) around the corner on 26" wheels with low profile tires - thing couldnt get out of its own way tho .
Id say its probably worth the $40K - for all the work the guy put into it - those military axles arent cheep - neither are those tires.
W1ldyOvvnZ
W1ldyOvvnZ
PostSubject: Re: monster muddy orange   monster muddy orange - Page 3 Icon_minitimeAugust 1st 2012, 10:51 pm
Id prefer to show off a truck on pavement or a dirt road rather then a float trailer or a flatbed, you get more attention that way:P
I have a friend who had 48" military tires on his truck on a 2005 F350, he was asking $30,000 for it last year, It was a sick truck, probably a 4ft drop from the floor of the truck and it was street legal, he used it to tow trailer, he had a custom 2 1/2ft drop hitch made.
I saw some tires like whats on that chevy for sale in a flier today(might not be exact, they were 66"x43" tires) for $4000 for 4 of them and they were used off of a harvester.
matthew sidor
matthew sidor
PostSubject: Re: monster muddy orange   monster muddy orange - Page 3 Icon_minitimeAugust 2nd 2012, 5:54 pm
ok how come when I put my transaxle back together with the new grease in it the mower is now harder to push around is it just because the grease needs to be worked in
W1ldyOvvnZ
W1ldyOvvnZ
PostSubject: Re: monster muddy orange   monster muddy orange - Page 3 Icon_minitimeAugust 2nd 2012, 11:11 pm
im pretty sure thats the reason, I know Fearless fronts video on locking the transaxle he said that the transaxle will be stiffer after putting it back together(I was expecting that was because it was locked) but it could be from the new grease.
matthew sidor
matthew sidor
PostSubject: Re: monster muddy orange   monster muddy orange - Page 3 Icon_minitimeAugust 2nd 2012, 11:31 pm
well mines not locked but the grease is the only thing that makes sense in why its harder to push.
Josh Blair
PostSubject: Re: monster muddy orange   monster muddy orange - Page 3 Icon_minitimeAugust 2nd 2012, 11:43 pm
could you do a few pics to show how that dirt bike carb is on there?
matthew sidor
matthew sidor
PostSubject: Re: monster muddy orange   monster muddy orange - Page 3 Icon_minitimeAugust 3rd 2012, 12:38 am
yeah i totally will tomorrow its really super easy.
PostSubject: Re: monster muddy orange   monster muddy orange - Page 3 Icon_minitimeAugust 3rd 2012, 5:14 pm
That happened with my kleen kut - the brass bushings have a lil index pin( sometimes) - if those arent set right it can mess with the trans- whenever i pushed it around in neutral it was a pain to push - had it apart 4 times afterwards and still does it .
matthew sidor
matthew sidor
PostSubject: Re: monster muddy orange   monster muddy orange - Page 3 Icon_minitimeAugust 7th 2012, 12:47 am
i love the summer. naked girls playing football at the river! then we hung out with them for a couple hours and played football with them. i know it has nothing to do with my mower but i thought whatever.
matthew sidor
matthew sidor
PostSubject: Re: monster muddy orange   monster muddy orange - Page 3 Icon_minitimeSeptember 2nd 2012, 1:02 pm
haha old pictures. fun in metal shop.
monster muddy orange - Page 3 375808_259165614134210_184606997_n
monster muddy orange - Page 3 185005_434630793254357_1384769975_n
matthew sidor
matthew sidor
PostSubject: Re: monster muddy orange   monster muddy orange - Page 3 Icon_minitimeSeptember 17th 2012, 3:19 am
alright well i just found my memory card so here's some new pics. i finished the rear end and made a new muffler.
monster muddy orange - Page 3 406538_409439439117491_1711100751_n
I just have to finish weld this down which i should do in next couple days
monster muddy orange - Page 3 576846_409439455784156_1955621114_n
monster muddy orange - Page 3 558654_409439482450820_1997390555_n
Tractor Man Jeff
Tractor Man Jeff
PostSubject: Re: monster muddy orange   monster muddy orange - Page 3 Icon_minitimeSeptember 17th 2012, 2:52 pm
My tranny was stiff for a little after I took it apart. Once you take it out and use it for a little, It'll loosen up. Nice going on your mower.
matthew sidor
matthew sidor
PostSubject: Re: monster muddy orange   monster muddy orange - Page 3 Icon_minitimeSeptember 21st 2012, 12:08 pm
got the muffler welded last night. now its time for the driveshaft. but its raining so maybe some other time
matthew sidor
matthew sidor
PostSubject: Re: monster muddy orange   monster muddy orange - Page 3 Icon_minitimeOctober 3rd 2012, 8:27 pm
I bought 2 used ITP mudlites on friday for $93.00 and i should be getting them in the next couple days. size 22-11-10. ill post pics of my mower when i put them on my mower
monster muddy orange - Page 3 140
Page 3 of 5Go to page : Previous  1, 2, 3, 4, 5  Next
» The Orange Deere
» What Welder is the best for mower modding?
» An old Orange Craftsman Project
» M&G MOTORSPORTS ''MUDDY CUB'' mb3 [2018 Build-Off Entry]
» G1 monster mower
