 monster muddy orange
Chopperhed
SuperMudMuppet
CornishMorgan
Junkstarbuilds
greener179
Tractor Man Jeff
Josh Blair
craftsman30mph
Shawn1750
WellThatsSurprising
Craigsnedeker
idlorah
gearheadmike
superswamper77
dked41
Wheel Crazy
W1ldyOvvnZ
matthew sidor
26 posters
Go to page : Previous  1, 2, 3, 4, 5
Tractor Man Jeff
monster muddy orange - Page 5 Empty
PostSubject: Re: monster muddy orange   monster muddy orange - Page 5 Icon_minitimeFebruary 28th 2013, 9:35 am
I fought this problem with mine and still do on really cold days. It was a bad battery that caused the issue. I'll eventually put a car battery in one of these days. If your engine is like mine, a briggs OHV, these engines are hard starters anyway.
matthew sidor
matthew sidor
PostSubject: Re: monster muddy orange   monster muddy orange - Page 5 Icon_minitimeFebruary 28th 2013, 12:16 pm
ok well how to i get a car bettery hooked up if they have different terminals
Tractor Man Jeff
Tractor Man Jeff
PostSubject: Re: monster muddy orange   monster muddy orange - Page 5 Icon_minitimeFebruary 28th 2013, 1:05 pm
Find one that has small bolt posts. Some have both regular posts and threaded ones. One of the batteries in my truck has both.
matthew sidor
matthew sidor
PostSubject: Re: monster muddy orange   monster muddy orange - Page 5 Icon_minitimeFebruary 28th 2013, 4:21 pm
Alright I finally got it running and once again Ive bent something smh and I didnt even make it to the trails. So I think I need to rethink my whole driveline idea
cuz its always something with the driveline the breaks something
monster muddy orange - Page 5 544176_482022281859206_489590010_n
monster muddy orange - Page 5 540885_482022451859189_974461600_n
Tractor Man Jeff
Tractor Man Jeff
PostSubject: Re: monster muddy orange   monster muddy orange - Page 5 Icon_minitimeFebruary 28th 2013, 4:49 pm
Glad it didn't break the transaxle. You might need more bracing on that as it looks awfully spindly.
matthew sidor
matthew sidor
PostSubject: Re: monster muddy orange   monster muddy orange - Page 5 Icon_minitimeFebruary 28th 2013, 5:00 pm
yeah Im thinking of making a new one. But dam now I have to grind and do more welding on the traction bar
PostSubject: Re: monster muddy orange   monster muddy orange - Page 5 Icon_minitimeFebruary 28th 2013, 5:39 pm
Definitely need some heavier reinforcement on the rear end. Youre lucky the support gave and not the casing.
PostSubject: Re: monster muddy orange   monster muddy orange - Page 5 Icon_minitimeFebruary 28th 2013, 6:19 pm
Needs a little bit more support.
matthew sidor
matthew sidor
PostSubject: Re: monster muddy orange   monster muddy orange - Page 5 Icon_minitimeMarch 1st 2013, 12:14 pm
yeah i actually looked at my transmission after and it was smoking but it still worked. Is that bad?
PostSubject: Re: monster muddy orange   monster muddy orange - Page 5 Icon_minitimeMarch 1st 2013, 2:35 pm
Smoking? Maybe it was just hot. Is it pulley swapped? Might be worth looking at putting a vent on it.
matthew sidor
matthew sidor
PostSubject: Re: monster muddy orange   monster muddy orange - Page 5 Icon_minitimeMarch 1st 2013, 8:50 pm
Its got stock pulleys on it
greener179
greener179
PostSubject: Re: monster muddy orange   monster muddy orange - Page 5 Icon_minitimeMarch 1st 2013, 9:44 pm
You sure it wasnt the belt?
xxXMowerdudeXxx
PostSubject: Re: monster muddy orange   monster muddy orange - Page 5 Icon_minitimeMarch 1st 2013, 9:54 pm
is it low on lube? maybe?
Chopperhed
Chopperhed
PostSubject: Re: monster muddy orange   monster muddy orange - Page 5 Icon_minitimeMarch 1st 2013, 11:44 pm
I wouldn't be surprised if the stresses from the bent bracket caused enough distortion in the trans to cause the bushings to bind.
Stiffen her upa and try it again
PostSubject: Re: monster muddy orange   monster muddy orange - Page 5 Icon_minitimeMarch 2nd 2013, 4:02 am
Use angle bars for stiffness, and are you planning on bigger diameter wheels?
Murray modder
Murray modder
PostSubject: Re: monster muddy orange   monster muddy orange - Page 5 Icon_minitimeMarch 2nd 2013, 8:56 am
Take a look at modern roll cages, there mostly made of triangle arranged in squares and stuff....simply put, triangle at the STRONGEST shape.
matthew sidor
matthew sidor
PostSubject: Re: monster muddy orange   monster muddy orange - Page 5 Icon_minitimeMarch 2nd 2013, 4:42 pm
well I was thinking of just using a couple flat pieces of flat 1/4 in iron and welding them to fit so the bracket will be really strong
PostSubject: Re: monster muddy orange   monster muddy orange - Page 5 Icon_minitimeMarch 2nd 2013, 9:10 pm
Yeah that might work.
PostSubject: Re: monster muddy orange   monster muddy orange - Page 5 Icon_minitimeMarch 10th 2013, 1:08 am
take a look at how mine is brace, i can do a vid on it if you want me to, i took and rotated the brackets where they faced forward, then weld a piece of 1x1 sqare tubing to them where it fit taght againsnt the transaxle, then took and welded a piece of angle iron over that, then have a piece of 1x1 sqare tubing going up tp the frame and another going diaganoly to the frame, its really freaking dtrong
Page 5 of 5Go to page : Previous  1, 2, 3, 4, 5
» The Orange Deere
» What Welder is the best for mower modding?
» An old Orange Craftsman Project
» M&G MOTORSPORTS ''MUDDY CUB'' mb3 [2018 Build-Off Entry]
» G1 monster mower
