| | JC Penny mudder | |
farmerall New Member
Age : 32 Join date : 2012-04-05 Points : 4581 Posts : 1
| Subject: JC Penny mudder April 5th 2012, 10:16 pm | |
| Hi everyone I just want to share what my new project will be here soon. A year ago I got this old tractor to fix up and resell. Well the engine started to go bad and it turned into a money pit. So after scraping the deck and and removing the engine no one wanted the tractor even for free. It just wont go away lol. So now I am go to turn it into a beater and maybe a racer eventually. I hope that I can start this project soon and I'm open to suggeestions about what I should do to it. Here it is from when I first got it. | |
| | | cumminsbayou Member
Age : 27 Join date : 2011-11-04 Points : 4987 Posts : 232 Location : fairhope Al.
| Subject: Re: JC Penny mudder April 6th 2012, 1:25 am | |
| id first paint it i have the same lawn mower but mines a murry thats who made them all i found it out in the woods and it had no dack and a 11 hp cized briggs i took that off and havent messed with it really but im gonna lift it or lower it or somthing soon[left]
All remeber Nothin stops a Kawasaki,and to save your confederate dollors cause the south will rise again | |
| | | gilsonrumbler Member
| Subject: Re: JC Penny mudder April 6th 2012, 11:44 pm | |
| i would just find a motor for it and run it until the wheels fall off! | |
Age : 49 Join date : 2012-04-05 Points : 5667 Posts : 959 Location : Mansfield, Ohio
| Subject: Re: JC Penny mudder April 7th 2012, 7:43 am | |
| That's the same frame I started with for one of mine. Frame is decent, but has some flex. Had to build a x-brace underneath. Front axle mounting is also weak, and bolts like to get loose. Decent steering box, decent transmission. If you ride it hard (jumps/crash) the frame can bend behind the front axle. Hood hinges are riveted and will need replaced with bolts eventually.
If you run a 4 in pulley on the front and a 3 in the rear, top speed is 35-40. I would recommend larger pulleys front and rear to prevent belt slip, but keep the 4-3 ratio. Gear oil in the transmission will help it last. | |
Age : 53 Join date : 2010-02-10 Points : 7042 Posts : 1726 Location : Florida, USA
| Subject: Re: JC Penny mudder April 7th 2012, 6:31 pm | |
| I have a similar tractor- mines a 80's agway( murray) 3 speed - for years stock i ran it thru the swamp behind the folks house when visited - did pretty good for a 10HP briggs and stock wheels , cept when i got into the thick stuff it just didnt go anywhere, i beat the snot out of it and it handled it pretty well.
I did a minor pulley swap- like 4" motor pulley and 6" trans pulley, wasnt searching for insane speed, just faster then the geriatric stock speed. Eventually i dragged it down south , added larger front tires , planned on 14.5HP OHV motor, but due to other things going on, its pretty much sat under a tarp.
Eventually i plan on either finishing it ( atv wheels and a 4x4 mod) or using another tractor for a offroader and returning it back to mowing . | |
| | | | | JC Penny mudder | |
| Who is online? | In total there are 44 users online :: 0 Registered, 0 Hidden and 44 Guests
