 Fozzy locker or welded spiders
Chopperhed
Craftsman Dude
avrappy
W1ldyOvvnZ
briggs 123
1MurrayMayhem1
RompinRedneck
gilsonrumbler
Fattypipemuarry
Jordan
AcreFarm
blanket80
18 posters
RompinRedneck
Fozzy locker or welded spiders  - Page 2 Empty
PostSubject: Re: Fozzy locker or welded spiders    Fozzy locker or welded spiders  - Page 2 Icon_minitimeJanuary 1st 2012, 6:36 pm
I'm gonna do FearlessFront's way. As long as you clean your gears nice and good before welding, make sure everything is lined up, and after welding you make sure to clean up all the slag, you will be fine.
https://www.youtube.com/user/rompinredneck
1MurrayMayhem1
PostSubject: Re: Fozzy locker or welded spiders    Fozzy locker or welded spiders  - Page 2 Icon_minitimeJanuary 15th 2012, 9:58 pm
I have welded 2 by welding the gears to shafts and gears to pins and have not had a problem FearlessFronts method
blanket80
blanket80
PostSubject: Re: Fozzy locker or welded spiders    Fozzy locker or welded spiders  - Page 2 Icon_minitimeJanuary 16th 2012, 1:04 am
good to hear.
briggs 123
PostSubject: Re: Fozzy locker or welded spiders    Fozzy locker or welded spiders  - Page 2 Icon_minitimeJuly 11th 2012, 10:17 pm
blanket80 wrote:
I have welded spiders before in my Dynamark and had great success. Although, I recently learned about the fozzy locker. Now the question is what style should I do to my new project... The choices are Fozzy locker, welding spiders together, or fearlessfronts weld the gears to the pin style.
Commets, Sugestions??..
Fozzy Locker
Fozzy locker or welded spiders  - Page 2 Fozzy
Traditional Welded Gears
Fozzy locker or welded spiders  - Page 2 Weldedspiders
Fearlessfronts way
What do you guys think?
what is a fozzy locker
W1ldyOvvnZ
W1ldyOvvnZ
PostSubject: Re: Fozzy locker or welded spiders    Fozzy locker or welded spiders  - Page 2 Icon_minitimeJuly 11th 2012, 11:26 pm
Fozzy Locker
Fearlessfronts way
The first picture, with one tooth on each side left unwelded to, a quick and easier way(in my opinion) to lock a transaxle.
http://www.stat10.tk/
avrappy
PostSubject: Re: Fozzy locker or welded spiders    Fozzy locker or welded spiders  - Page 2 Icon_minitimeJanuary 8th 2013, 10:32 am
Where can I buy a Fozzy Locker??? Sounds easier than welding.
W1ldyOvvnZ
W1ldyOvvnZ
PostSubject: Re: Fozzy locker or welded spiders    Fozzy locker or welded spiders  - Page 2 Icon_minitimeJanuary 8th 2013, 1:49 pm
i am pretty sure you have to weld it up your self(weld the other teeth up on the gears), i have a set of gears that i wanted to try them to but ive never brought them out and welded them up yet, which reminds me about going out and actually doing it... The bad thing about going with the Fozzy locker is that your going to have play in the rear end.
PostSubject: Re: Fozzy locker or welded spiders    Fozzy locker or welded spiders  - Page 2 Icon_minitimeJanuary 8th 2013, 2:55 pm
Probably have to get them custom made, im pretty sure nobody actually makes them for tractors. WOuldnt be hard to make one yourself though, all you are is filling in gaps in the gear so it cant turn. But like Wildy said, youll have some play.
W1ldyOvvnZ
W1ldyOvvnZ
PostSubject: Re: Fozzy locker or welded spiders    Fozzy locker or welded spiders  - Page 2 Icon_minitimeJanuary 8th 2013, 3:32 pm
i just welded up some gears i had from a Peerless transaxle i had sitting in the scrap pile(the transaxle casing was cracked and completely useless unless you had another casing).
Fozzy locker or welded spiders  - Page 2 PIC_0230_zps222b8c1c
They aren't ground down yet, i will do that sometime later when i need them or want to use them for a lawn tractor. if you are going to do it clean the teeth you didn't weld up(clean the slag, its not a good idea because it will damage other parts inside the transaxle) and make sure everything fits right when you put it back in or you might have problems later on.
PostSubject: Re: Fozzy locker or welded spiders    Fozzy locker or welded spiders  - Page 2 Icon_minitimeJanuary 8th 2013, 4:55 pm
Id be aiming for using the fozzy gears over welding everything solid - least it can be reversed easily enough.
Only sure fire way to cure any movement is to mount a straight axle thru the trans.
AcreFarm
AcreFarm
PostSubject: Re: Fozzy locker or welded spiders    Fozzy locker or welded spiders  - Page 2 Icon_minitimeJanuary 8th 2013, 6:56 pm
Using a fozzy locker is the way to go over Lincoln-locking the diff IMO. Depending on the transaxle you can simply add 2 more spider gears to effectively lock the differential.
...from my Peerless 900
Fozzy locker or welded spiders  - Page 2 IM000747
Craftsman Dude
Craftsman Dude
PostSubject: Re: Fozzy locker or welded spiders    Fozzy locker or welded spiders  - Page 2 Icon_minitimeJanuary 8th 2013, 7:14 pm
OMG i have to try that next time my trans is apart a locker with no welding .
PostSubject: Re: Fozzy locker or welded spiders    Fozzy locker or welded spiders  - Page 2 Icon_minitimeJanuary 8th 2013, 7:32 pm
I think that differential was made for that. I know my bull gears are completely milled and wouldnt support extra gears.
AcreFarm
AcreFarm
No welding. Maybe some grinding, depending on what you've got. You will need to have an identical set of spiders...gears from other transaxles (Foote, DANA/Spicer, etc. won't work).
It's also easily reversible if you want to go back to an open diff.
AcreFarm
AcreFarm
PostSubject: Re: Fozzy locker or welded spiders    Fozzy locker or welded spiders  - Page 2 Icon_minitimeJanuary 8th 2013, 7:35 pm
That is a factory ring & spider gear-set from a Peerless 900, with 2 spiders added to it. I had to grind the flat side of the 2 additional gears just a bit to make them fit into the ring gear
** edit**
This will work with some (820, 900, 910, 915, 920, 930, 940 series) Peerless transaxles, other manufacturers & Peerless models are a different story.
Chopperhed
Chopperhed
PostSubject: Re: Fozzy locker or welded spiders    Fozzy locker or welded spiders  - Page 2 Icon_minitimeJanuary 8th 2013, 7:41 pm
A strong spring on the shaft between the two spiders would make a cheap posi.
Used to do it on Ford 9" diffs to help wheelspin
W1ldyOvvnZ
W1ldyOvvnZ
PostSubject: Re: Fozzy locker or welded spiders    Fozzy locker or welded spiders  - Page 2 Icon_minitimeJanuary 8th 2013, 8:16 pm
Yeah i think a Solid axle through the entire setup would be the best.
Wouldn't a strong spring be more like a Limited-Slip Differential?
Ooh yeah got bored and ground down the gear.
Fozzy locker or welded spiders  - Page 2 PIC_0235
i put a thin coating of grease over everything so it doesn't rust as easily while it isn't in the tractor
Chopperhed
Chopperhed
PostSubject: Re: Fozzy locker or welded spiders    Fozzy locker or welded spiders  - Page 2 Icon_minitimeJanuary 8th 2013, 10:42 pm
Thats exactly what it is,
It depends what you want.
sometimes its desirable to have a little more control steering, but when not steering have a fairly solid forward drive.
It would also maximize traction in a front diff.
W1ldyOvvnZ
W1ldyOvvnZ
PostSubject: Re: Fozzy locker or welded spiders    Fozzy locker or welded spiders  - Page 2 Icon_minitimeJanuary 9th 2013, 3:13 pm
That would be nice to have, i might add that into a lawn tractor sometime, how strong of a spring did you use? i was thing of using a valve spring from a car engine but i dont know one that is long enough.
Craftsman Dude
Craftsman Dude
PostSubject: Re: Fozzy locker or welded spiders    Fozzy locker or welded spiders  - Page 2 Icon_minitimeJanuary 9th 2013, 6:20 pm
I think a limited slip would work great for me i am going to try this one day. How large / strong of a spring would i need.
W1ldyOvvnZ
W1ldyOvvnZ
PostSubject: Re: Fozzy locker or welded spiders    Fozzy locker or welded spiders  - Page 2 Icon_minitimeJanuary 9th 2013, 10:49 pm
i was thinking it would be better on the transaxle and less stress too if you drove on hard packed roads or pavement alot compared to a locked transaxle.
Craftsman Dude
Craftsman Dude
PostSubject: Re: Fozzy locker or welded spiders    Fozzy locker or welded spiders  - Page 2 Icon_minitimeJanuary 9th 2013, 11:30 pm
Exactly I go up and down my street alot so this would be good also I dont want to loos my turning radius .
Chopperhed
Chopperhed
PostSubject: Re: Fozzy locker or welded spiders    Fozzy locker or welded spiders  - Page 2 Icon_minitimeJanuary 10th 2013, 12:48 am
It will take some trial and error. I only remember this from 20 some years ago in a Hot Rod magazine for 9" ford diffs.
The engineering is sound. We just need to figure out the details.
Depending on the length required and shaft size etc. the possibilities are immense.
Might even be able to incorporate a clutch pad setup from an ATV too. Currently working on a belleville spring setup for a surpluss MTD fnr transaxle. The yamagha big bears had a posi front diff with small cluth plates on the spiders.
It boils down to adding friction between the spiders while not limiting the spiders from performing their function.
I have a peerless 600-612A in my LT75. It looks like a good candidate as well
dked41
dked41
PostSubject: Re: Fozzy locker or welded spiders    Fozzy locker or welded spiders  - Page 2 Icon_minitimeJanuary 10th 2013, 10:45 am
I would use 2 thrust washers outboard on the spiders to keep the lash to a minimum, then you could use a valvle spring with washer spacers to adjust tension. I think the hardest part would be compressing everything to get it installed. I would guess that to be affective, you need a fair amout of pressure. Much more than being able to compress by hand. I may have to experiment with this myself, being able to turn short with traction sounds like a great idea. The transaxle case may live a little longer, without the strains of a locked diff trying to turn sharp regularly.
W1ldyOvvnZ
W1ldyOvvnZ
PostSubject: Re: Fozzy locker or welded spiders    Fozzy locker or welded spiders  - Page 2 Icon_minitimeJanuary 10th 2013, 5:05 pm
Chopperhed so you never have tried it on a lawn tractor transaxle before only from the ford 9" differentials? i thought washer would be a good idea, id prefer to wreck a washer over a gear. i think i am going to try this sometime(probably with those variable speed MTD lawn tractor transaxles because there worth almost nothing to me). And using an ATV diff would be cool but you would need to modify the transaxle casing and weld in the ATV Diff casing to it or machine the transaxle case properly.
RCG
RCG
2016 Build-Off Finalist
PostSubject: Re: Fozzy locker or welded spiders    Fozzy locker or welded spiders  - Page 2 Icon_minitimeMarch 31st 2013, 6:59 pm
Just figured i would add another option to the list.
http://www.Mudmower.com
» Question about Fozzy locker
» Fozzy locking
» LOCKED TRANSAXLE
» where is the thread with pics how to bolt in extra spiders to lock?
» Selectable locker idea
