 My starter motor throws sparks when it hits the flywheel
akcender
akcender
My starter motor throws sparks when it hits the flywheel Empty
PostSubject: My starter motor throws sparks when it hits the flywheel   My starter motor throws sparks when it hits the flywheel Icon_minitimeDecember 8th 2011, 4:21 pm
anyone elses starter motor make sparks when it hits the flywheel, i think its just because i have a low battery but i cant be sure
PostSubject: My starter motor throws sparks when it hits the flywheel   My starter motor throws sparks when it hits the flywheel Icon_minitimeDecember 8th 2011, 4:30 pm
If it is throwing sparks, you are grinding down the steel gear on the starter. once it starts rubbing, it will keep getting worse. A weak battery and or starter will cause this from not spinning fast enough to engage the gear.
a dirty/ sticky bendix will cause this too. some times you can turn the gear over for a quick fix but it will need to be replaced.
if it doesnt have a steel gear, you have big problems. time for a new starter!
akcender
akcender
PostSubject: Re: My starter motor throws sparks when it hits the flywheel   My starter motor throws sparks when it hits the flywheel Icon_minitimeDecember 8th 2011, 4:42 pm
Thats the thing, it is brand new. i did notice when i was installing it that the teeth didnt mesh very well though, im thinking i might grind down the mounting bracket so the teeth will grab more. either that or ill check if the old starter gear is bigger and try to swap it witht that one
PostSubject: My starter motor throws sparks when it hits the flywheel   My starter motor throws sparks when it hits the flywheel Icon_minitimeDecember 8th 2011, 4:47 pm
are you sure its the right starter? briggs starters should just be " bolt on and go". usually if you have alignment problems, its the starter bearings
akcender
akcender
PostSubject: Re: My starter motor throws sparks when it hits the flywheel   My starter motor throws sparks when it hits the flywheel Icon_minitimeDecember 8th 2011, 10:03 pm
its the right starter, i matched up the numbers and everything else works fine, i dont know whats going on with it. its a tecumseh
» What is the best way to derust my flywheel?
» Briggs Opposed twin Starter and Flywheel issues
» Do you think my starter motor is dead and should be replaced?
» How do I remove a seized flywheel?
» FLYWHEEL & STARTERS WHAT YOU NEED TO KNOW
