 What is the best way to derust my flywheel?
2 posters
noledroByrreK
noledroByrreK
What is the best way to derust my flywheel? Empty
PostSubject: What is the best way to derust my flywheel?   What is the best way to derust my flywheel? Icon_minitimeJanuary 19th 2011, 8:22 pm
Hi i was wondiring what was the best way to derust my flywheel? should i take a grinder to it or go at it with some sand paper
i want it clean it up cuz its bout the only rusty thing on the machine
thanks
PostSubject: Re: What is the best way to derust my flywheel?   What is the best way to derust my flywheel? Icon_minitimeJanuary 19th 2011, 9:57 pm
DONT use a grinder- its a balanced piece of the motor. Just use normal sand paper - it can be painted except where the magnet is riveted to the flywheel - that needs to stay clean for a proper 'signal' to the magneto.
I just scuff mine up and paint em ( least the ones i paint).
noledroByrreK
noledroByrreK
PostSubject: Re: What is the best way to derust my flywheel?   What is the best way to derust my flywheel? Icon_minitimeJanuary 19th 2011, 10:05 pm
alright... mabye ill paint it red to match the engine... an get some red fuel line.. that would make it look sweet
PostSubject: Re: What is the best way to derust my flywheel?   What is the best way to derust my flywheel? Icon_minitimeJanuary 19th 2011, 10:13 pm
On my LT12 craftsman i was going to mod it out and go with a blue black and chrome theme. I painted the tractor blue and black, rims chrome, added blue headlight bulbs. I also bot some small blue LED lights to mount around under the tractor and a couple red tailights - i tested out a string of blue LEDs- it looked way cool at nite. I was searching for some chrome plexiglass , but i recently found some chrome foil peel n stick instead.
Im thinking on my mod MTD i might do the red lights underneath when its done- id put em on my wizard- but then id have to haul a battery around ( its pull start).
noledroByrreK
noledroByrreK
PostSubject: Re: What is the best way to derust my flywheel?   What is the best way to derust my flywheel? Icon_minitimeJanuary 19th 2011, 10:33 pm
that would be awsome:)
» 18.5 b&s sheared flywheel key ?
» FLYWHEEL & STARTERS WHAT YOU NEED TO KNOW
» How do I remove a seized flywheel?
» I have oil slowly leaking out near the flywheel
» Flywheel Removal? Urgent
