| Trans-Axles | |
gearheadmike Member
Age : 34 Join date : 2011-11-18 Points : 5183 Posts : 392 Location : west chazy ny
| Subject: Trans-Axles November 24th 2011, 6:14 pm | |
| Ok i was woundering whats the best transaxle for the manual belt drive tractors like mtd/agway/craftsman/murray/ect? i know theres a few different ones. | |
| | | Ford Boi Member
Age : 40 Join date : 2010-08-22 Points : 5445 Posts : 242 Location : Yarmouth, Nova Scotia, Canada
| Subject: Re: Trans-Axles November 24th 2011, 6:51 pm | |
| I've had best performance from newer Peerless 5 and 6 speeds, factory equipped with 80W90 and sealed. 1995 and newer roughly. The older Peerless 5-spds are quite tough, they have the boxy case. Spicer and Foote transaxles that I've had work decent but tend to wear out or blow up much quicker. The very old 3-spd Peerless transaxles are also tough but alot harder to work on. | |
| | | gearheadmike Member
| Subject: Re: Trans-Axles November 24th 2011, 7:13 pm | |
| yea i got the 5spd in my mtd my friend has the 3spd and my parts agway has the 7spd side shift | |
| | | Ford Boi Member
| Subject: Re: Trans-Axles November 24th 2011, 7:18 pm | |
| You should look on the top case of the 5spd to see what kind it is | |
| | | gearheadmike Member
| Subject: Re: Trans-Axles November 24th 2011, 8:54 pm | |
| i will tomarrow i plan on pulling rear soon to change the pulley for some more speed, cause 1,2,3 is dead slow 4th and 5th is ok but need more. | |
| | | gearheadmike Member
| Subject: Re: Trans-Axles November 26th 2011, 10:26 pm | |
| ok well got the rear end out tonight its a peerless 5spd i cant seem to find the model number? ill cet oics of it tomarrow. | |
| | | gearheadmike Member
| | | | Sponsored content
| | | | | Trans-Axles | |
| Who is online? | In total there are 4 users online :: 0 Registered, 0 Hidden and 4 Guests
