Okay guys I have been fighting with a decision on mud tire for my hydro hunting rig and all the tires I have found is for 9 inch rim and I have 10 inch rim and when I type in the tires size I want it all ways bring up the 1 st two set of num is right but the rim . And will a 9 inch fit on a 10 in rim without have problems. These are the one I want for the rear but I can't find the right size I need and the original is is 20x10x10
Hillbilly mowers Member
Age : 38 Join date : 2023-10-12 Points : 750 Posts : 291 Location : Booneville ky
I was just want to change the 20 to a couple of inches bigger for now then next the front has 6 inch rim so it's a had decision to cause I can't find a set for the front either
Brianator Moderator
Type "22x10-10 atv tires" in the ebay search bar and you'll find a better selection. That will be the perfect size for your needs and shouldn't put TOO much extra stress on the the axles. The SunF A001 and A006 both look like pretty decent tires but the A051s would probably be the best of the bunch
Ditto to @Brianator's post, SUNF offers a wide selection of tire sizes in copies of popular tread patterns. Not a high quality tire but for the price they're excellent.
I'm just basically looking for some that will fit very good grip for kind rough terrain and clay mud like that is on dozer road or gravel road and trails cause I'm modify a full skid plate for my hydro so it will help keep the fins Clear of my but I don't think water would hurt it
Age : 22 Join date : 2016-10-29 Points : 7224 Posts : 4021 Location : Lewisburg, KY
You can't put a 9 inch rim tire onto a 10 inch rim, unfortunately. There's a ton of flexibility for the tire widths vs rim widths and some folk have even been known to stretch or stuff different size tubes in different rims, but rim size to rated tire rim size is the one thing you can't get around.
I'm just basically looking for some that will fit very good grip for kind rough terrain and clay mud like that is on dozer road or gravel road and trails cause I'm modify a full skid plate for my hydro so it will help keep the fins Clear of my but I don't think water would hurt the fins cause IV been work trying to figure the skid plates out for this hunting rig and a winch for it to .
22x10-10 will be perfect for your usage as I stated already. 22" tall, 10" wide to fit a 10" wheel which by the way is a oddball wheel size so be thankful there's decent ATV tires available
