 Need belt sizing help on my Dynamark pulley swap.
CraftsMAN
CraftsMAN
Need belt sizing help on my Dynamark pulley swap. Empty
PostSubject: Need belt sizing help on my Dynamark pulley swap.   Need belt sizing help on my Dynamark pulley swap. Icon_minitimeNovember 7th 2011, 10:57 pm
Well as you can see from my youtube videos I took the rearend out of my Dynamark and packed it full of grease and oil then replaced the 7-1/2 pulley with a 3-1/2 pulley. The motor is an 11hp briggs motor. The stock belt was 87-1/2 inches so I picked up a 83 inch belt and that was still to big. I am going to try an 81? Does anyone know how much faster I will be going?
https://www.facebook.com/CRUSHEMCustoms/
CraftsMAN
CraftsMAN
PostSubject: Re: Need belt sizing help on my Dynamark pulley swap.   Need belt sizing help on my Dynamark pulley swap. Icon_minitimeNovember 7th 2011, 10:58 pm
ferg
ferg
PostSubject: Re: Need belt sizing help on my Dynamark pulley swap.   Need belt sizing help on my Dynamark pulley swap. Icon_minitimeNovember 8th 2011, 12:20 pm
http://www.csgnetwork.com/pulleybeltcalc.html add roughly 1 inch to allow for the belt tensioner or just round the number up Smile
looks good!!
You will be going roughly two times as fast ( probably about 1.7x)
PostSubject: Dynamark pulley swap need belt help   Need belt sizing help on my Dynamark pulley swap. Icon_minitimeNovember 8th 2011, 3:48 pm
to find out what size belt on a pulley swap, find the differance in circumferance of the new and old pulley (dx3.14) , divide that by 2, and add or subtract depending if you are going bigger or smaller.
the new belt should be about 6.28" shorter or 81.22"
round that down to 81 and you should be good.
Ditto on the 2X speed increase
CraftsMAN
CraftsMAN
PostSubject: Re: Need belt sizing help on my Dynamark pulley swap.   Need belt sizing help on my Dynamark pulley swap. Icon_minitimeNovember 8th 2011, 11:14 pm
Yea! but bad problem... lol went and got an 83 inch belt then they did not have an 81 at Tractor Supply CO in stock so I picked up an 80.. lol that did not work. So I need to find an 81..
PostSubject: Re: Need belt sizing help on my Dynamark pulley swap.   Need belt sizing help on my Dynamark pulley swap. Icon_minitimeNovember 9th 2011, 6:21 am
Try napa autoparts - they carry lawntractor stuff.
PostSubject: Dynamark pulley swap need belt help   Need belt sizing help on my Dynamark pulley swap. Icon_minitimeNovember 9th 2011, 7:57 am
Dont think the belt number ( B81) is the size, usually the size and the belt number are a few inches off.
a B81 belt is actually 83"
CraftsMAN
CraftsMAN
PostSubject: Re: Need belt sizing help on my Dynamark pulley swap.   Need belt sizing help on my Dynamark pulley swap. Icon_minitimeNovember 9th 2011, 10:53 pm
CraftsMAN
CraftsMAN
PostSubject: Re: Need belt sizing help on my Dynamark pulley swap.   Need belt sizing help on my Dynamark pulley swap. Icon_minitimeNovember 18th 2011, 4:42 pm
OK so now the belt seems to be slipping a lot. Anyone know how to fix this? Bigger pulley on front perhaps?
» Belt twisting after pulley swap
» Easy Belt Length Calculation: Pulley Swap Only
» belt sizing
» MTD Lawnflite belt sizing help
» Pulley Swap
