 Pulley swap
Madmowers
Pulley swap Empty
PostSubject: Pulley swap   Pulley swap Icon_minitimeJuly 10th 2014, 10:49 pm
I pulley swaped a mower that has a 3 1/2 inch front pulley and 2 inch back pulley and I don't know how to get a belt size any ideas
Pulley swap Empty
PostSubject: Re: Pulley swap   Pulley swap Icon_minitimeJuly 10th 2014, 11:01 pm
If you have the old belt, it should be able to wrap around all your pulleys and zip tie it. push in the clutch all the way and route the belt so is relatively loose in the pulleys so it can disengage. then bring it to tractor supply, measure it with the belt guide there and get the belt you need.
Craftsman1998
Craftsman1998
Pulley swap Empty
PostSubject: Re: Pulley swap   Pulley swap Icon_minitimeJuly 11th 2014, 8:13 am
I take a bad belt put it around the pulleys and then cut it to the size i need then wire the 2 ends together then go to tractor supply and try and find one close. thats my redneck way of doing it isn't really the right way but it works.
Pulley swap Empty
Pulley swap
» HELP!!!! PULLEY SWAP
» Racing mower: pulley swap
» Pulley Swap
» HELP pulley swap
» I need help with my pulley swap! :(
