 Spring problem!
Normandybrit
7 posters
Normandybrit
Spring problem! Empty
PostSubject: Spring problem!   Spring problem! Icon_minitimeMay 22nd 2023, 11:23 am
I've got a bit of a problem. I managed to replace the items after my MTD had the tensioner pulley and rear belt wreck themselves but I seem to be on my way to a hernia trying to hook up the front belt tension spring. I've slipped the belt off the motor end to give me a bit of slack but still can't pull the spring enough to hook it on to the arm (see photo).  Any thoughts?
Spring problem! Img_2217
PostSubject: Re: Spring problem!   Spring problem! Icon_minitimeMay 22nd 2023, 1:12 pm
Can you shift the belts manually to move the idler arm closer to the spring mount?
PostSubject: Re: Spring problem!   Spring problem! Icon_minitimeMay 22nd 2023, 4:03 pm
For the really tough springs, I use a metal hanger or wire in a big loop.  Hook one end and prybar the other side guiding it to the hole.  Once in, clip the wire.
Spring problem! Sig115PROJECTS:
Spring problem! Sig214Spring problem! Sig314
PostSubject: Re: Spring problem!   Spring problem! Icon_minitimeMay 22nd 2023, 6:59 pm
They are really difficult to stretch that's no lie! A screwdriver can also help but I usually use a quality set of vise grips clamped super tight in a way I can pull them in the direction I need to stretch the spring to get the job done.
My All Terrain Tractors:
MightyRaze and TechnoChicken like this post
JB_4x4
PostSubject: Re: Spring problem!   Spring problem! Icon_minitimeMay 16th 2024, 1:29 am
Maybe the  best choice since you can reuse them for auto jobs
11260 Brake Spring Pliers
https://www.lislecorp.com/specialty-tools/brakes/brake-spring-pliers
These are good with a cheater pipe because it does not impede the hook of the spring
44800 Heavy-Duty Brake Spring Tool
https://www.lislecorp.com/specialty-tools/heavy-duty-brake-spring-tool
Put the spring hook between the tines and fork it over to the bracket
39770 Brake Spring Fork
https://www.lislecorp.com/specialty-tools/heavy-duty/39770-brake-spring-fork
I can't recall ever being disappointed in a Lisle tool.
Please wear googles AND full face protection and lower the plastic face shield over your throat (tuck your chin) while pulling the spring.
TechnoChicken
TechnoChicken
PostSubject: Re: Spring problem!   Spring problem! Icon_minitimeMay 16th 2024, 4:33 pm
Last time I had to do that I used a ratchet strap against a tree to pull the spring and then a very long pry bar to get it hooked on so it wouldn't break my fingers if the strap broke.
ranch king pro 08
ranch king pro 08
2023 Build-Off Top 3 Winner
PostSubject: Re: Spring problem!   Spring problem! Icon_minitimeMay 16th 2024, 4:48 pm
@TechnoChicken an engine hoist works well for that too lol!
TechnoChicken likes this post
JB_4x4
PostSubject: Re: Spring problem!   Spring problem! Icon_minitimeMay 16th 2024, 5:28 pm
Sorry for replying to an old thread, I forgot it was 2024 ... What a Face
Spring problem!
» Do I have a govenor problem or a throttle problem?
» The first day of SPRING!
» Spring Header...
» where does the governor spring hook to?
