 where does the governor spring hook to?
dwcopple
where does the governor spring hook to? Empty
PostSubject: where does the governor spring hook to?   where does the governor spring hook to? Icon_minitimeJune 3rd 2014, 8:47 pm
The end near the carb is hanging loose on my 12.5 I/C. The spring goes over the link to the governor arm and is attached to the tip of the arm. I need to know where that other end is supposed to be hooked up.
dwcopple
PostSubject: Re: where does the governor spring hook to?   where does the governor spring hook to? Icon_minitimeJune 3rd 2014, 9:19 pm
https://www.youtube.com/watch?v=AshCQPMmdKU
^ this makes it seem as if there is another hole under the linkage hole that the spring is to hook into. I'll check it out tomorrow.
» Opposed twin governor linkage.
» OHV Performance, No Governor
» Governor adjustment old techumseh
» governor on tecumseh 12hp
» The first day of SPRING!
