Got the factory trans axle opened up and it looks pretty rough.
Found out why this mower was parked... guess its time to get this cleaned up and find a new chain.
Also having issues with the shifter not lining up with Zeus's transaxle. I swapped over the shift linkage as well and the angle of the mounting holes are off. So i figured it would just be easier and better to fet the factory transaxle going.
Brianator Moderator
Due to life issues the builds have been off to a slow start but ive been making slow progress.
Ended up taking the whole transaxle apart and cleaned out the old nasty grease. It was a nightmare for sure. Even using gloves and being careful to not get grease everywhere, it still ended up everywhere in my shop lol Let everything sit in gasoline for a while and used a brush to scrub everything clean, rinsed with water then sprayed everything down with brake cleaner. Met up with another member for a trade and set me up with a new reverse chain some front wheels and a couple old motorcycle mufflers. For now im going to leave the diff open just to get this project moving so i can make some progress on Zeus for the build off. Hopefully this weekend we can ride!
RichieRichOverdrive, Brianator and Rustbucket Garage like this post
Mrbrucie22 Member
Age : 34 Join date : 2022-11-26 Points : 823 Posts : 72 Location : Glasgow KY
Well its moving on it own power now but ive run into an issue i should have noticed sooner. If i press the clutch/brake down too far the clutch pulley hits the engine pulley. But in 1st gear its about as fast as my grass cutting mower. Anyone know what i can do about the clutch?
Unfortunately on dynamarks you can only run a 4” engine pulley with the factory clutch set up. If you re locate the clutch pulley further back on the clutch arm, you can sneak a 5” engine pulley.
Youre poop out of luck on dynamarks, aside from moving your engine forward, or building a new clutch system youre stuck with a smaller engine pulley than most other brands
Espyville Mudders White Trash Productions Ohio Offroad Mowers Top Tractor Challenge Host #StopStretchingTractors2021 Builds: Sears Killer, Mud Dynamark, Drift Missile, 4x4 Dynamark + many more
Have you done this? Do you have any post or videos explaining the procedure?
Age : 37 Join date : 2013-07-02 Points : 5016 Posts : 731 Location : Logan Ohio
If you search on here you can find my AMF build which uses the same frame/clutch as a dynamark and I show how I put a clutch setup out of a craftsman GT6000 in it. It worked really well and I ran a 8 inch engine pulley iirc
