 Help with MTD 2 speed trans
nanner161988
6 posters
nanner161988
nanner161988
Help with MTD 2 speed trans Empty
PostSubject: Help with MTD 2 speed trans   Help with MTD 2 speed trans Icon_minitimeMay 18th 2022, 10:16 pm
I have a new to me mtd 2 speed trans with reverse that I'm wondering if anyone has any info on. Was in a 92 mtd variable speed with 18 hp opposed briggs. Mow thinking about putting it in my 86 mtd 18.5 hp opposed that is my work horse around the yard. It has a 5 speed in it now but could use the 5 speed in another build and thinking if I get the pulley ratio right it should be just fine right??? Not looking for speed but want to be able to pass a snail to and tow logs with the sleeve hitch and chair train when we go down trails towing about 6 chairs one is a double seater and be able to plow snow in the winter with it. Any info would be appreciated. If you think it will work or go terrible please let me know Help with MTD 2 speed trans 20220520
Help with MTD 2 speed trans 20220518
Help with MTD 2 speed trans 20220519
PostSubject: Re: Help with MTD 2 speed trans   Help with MTD 2 speed trans Icon_minitimeMay 18th 2022, 11:19 pm
[mod]I busted your question out into a new topic.  I felt if didn't mesh well with the old topic you posted in.[/mod]
That trans has seen some better days!  affraid
There are a couple MTD guys in here somewhere, hopefully they will jump in.
Help with MTD 2 speed trans Sig115PROJECTS:
Help with MTD 2 speed trans Sig214Help with MTD 2 speed trans Sig314
nanner161988
nanner161988
PostSubject: Re: Help with MTD 2 speed trans   Help with MTD 2 speed trans Icon_minitimeMay 18th 2022, 11:50 pm
Ok thank you. Both rims are stuck on and when I put it on its side water was coming out. Got measurements of bearings that way if it is worth it I can order them all gears moved very smooth before I noticed all the water in it surprisingly hoping to be able to press the axle shafts out at work tomorrow the pulley on it was splined amd had a nut on top. I never ran into a input pulley being splined yet. Only been building for a little over a year and a half and been looking on here alot lately since I came across it for advice got so many questions but trying to be patient and handle one at a time got lots of ideas of multiple projects I want to build. Already accumulated around 15 mowers some run some for parts from 60s to late 90s maybe 2000s. It's an addicting hobby only with there were events closer to me
PostSubject: Re: Help with MTD 2 speed trans   Help with MTD 2 speed trans Icon_minitimeMay 19th 2022, 12:53 am
Being out of an MTD I'd imagine it's a Peerless, have a look for the tag on the case and I'm guessing you'll find it's either a 820 or 900 series,  either of which should do what you're wanting of it although the 820 would be the better of the two. It's going to take some work to get it cleaned up, hopefully it looks decent under that grime! Lol
My All Terrain Tractors:
RCG
RCG
2016 Build-Off Finalist
PostSubject: Re: Help with MTD 2 speed trans   Help with MTD 2 speed trans Icon_minitimeMay 19th 2022, 7:53 am
http://www.Mudmower.com
nanner161988
nanner161988
PostSubject: Re: Help with MTD 2 speed trans   Help with MTD 2 speed trans Icon_minitimeMay 19th 2022, 8:18 am
Not the same one
Help with MTD 2 speed trans 20220521[/url]
Rustbucket Garage
Rustbucket Garage
PostSubject: Re: Help with MTD 2 speed trans   Help with MTD 2 speed trans Icon_minitimeMay 19th 2022, 9:18 am
It will work, but I'd suggest getting a centrifugal clutch pulley like thisHelp with MTD 2 speed trans S-l500
nanner161988 likes this post
nanner161988
nanner161988
PostSubject: Re: Help with MTD 2 speed trans   Help with MTD 2 speed trans Icon_minitimeMay 19th 2022, 9:45 am
Thank you very much. I wouldn't have thought about doing that.
PostSubject: Re: Help with MTD 2 speed trans   Help with MTD 2 speed trans Icon_minitimeMay 19th 2022, 12:07 pm
Can you find another tag on it? Could be glued or etched into the casing itself (on a flat spot), the one you posted is the MTD tag and not the manufactres.
PostSubject: Re: Help with MTD 2 speed trans   Help with MTD 2 speed trans Icon_minitimeMay 19th 2022, 12:51 pm
I'm pretty certain that 618-0009 number is the trans model and the manufacturer of the trans is MTD.  Should be a HI/LO trans.
nanner161988
nanner161988
PostSubject: Re: Help with MTD 2 speed trans   Help with MTD 2 speed trans Icon_minitimeMay 20th 2022, 5:06 am
Number on the differential is the same as a number etched into the casing. Jusy don't have a Photo of it right now. Then hope the other photos help also
Help with MTD 2 speed trans 20220523
Help with MTD 2 speed trans 20220524
Help with MTD 2 speed trans 20220525
JittyJat
JittyJat
PostSubject: Re: Help with MTD 2 speed trans   Help with MTD 2 speed trans Icon_minitimeMay 20th 2022, 3:21 pm
I have one of these up at my grandparent's house as well but the transaxle isn't even hooked up and the mower is in 2 pieces split right down the side
» high/low 3-6 speed trans axle?
» hydro trans will only move at vers slow speed
» 1st attempt at a MTD vari drive and 3 speed manual trans mutation
» tranny ? 5 speed or 6 speed
