 A Rat Rod Wheelbarrow Bucket T Tractor/Kart for my Grandson
MN mudder
Fastman
Budget_gokart
Rustbucket Garage
Nevadablue
12 posters
Go to page : Previous  1, 2, 3, 4, 5, 6, 7
A Rat Rod Wheelbarrow Bucket T Tractor/Kart for my Grandson - Page 7 Empty
PostSubject: Re: A Rat Rod Wheelbarrow Bucket T Tractor/Kart for my Grandson   A Rat Rod Wheelbarrow Bucket T Tractor/Kart for my Grandson - Page 7 Icon_minitimeDecember 2nd 2021, 10:17 pm
Hey take your time and enjoy it, no pressure here! Lol  Don't forget the old adage "slow and steady wins the race!" Love the handle it will fit in beautifully!
Budget_gokart
Budget_gokart
PostSubject: Re: A Rat Rod Wheelbarrow Bucket T Tractor/Kart for my Grandson   A Rat Rod Wheelbarrow Bucket T Tractor/Kart for my Grandson - Page 7 Icon_minitimeDecember 3rd 2021, 6:51 am
Take your time how do you think the greatest builds are the greatest? My tractor is taking just as long to get finished
PostSubject: Re: A Rat Rod Wheelbarrow Bucket T Tractor/Kart for my Grandson   A Rat Rod Wheelbarrow Bucket T Tractor/Kart for my Grandson - Page 7 Icon_minitimeDecember 3rd 2021, 11:53 am
The greatest tractors still are not finished!  They are all works in progress!
Even when you get your Rat Rod tractor done for the grandson, you'll see an improvement here and there always.  Like  @Brianator said above
Brianator wrote:
"Hey take your time and enjoy it, no pressure here!"
Building is fun.
A Rat Rod Wheelbarrow Bucket T Tractor/Kart for my Grandson - Page 7 Sig115PROJECTS:
A Rat Rod Wheelbarrow Bucket T Tractor/Kart for my Grandson - Page 7 Sig214A Rat Rod Wheelbarrow Bucket T Tractor/Kart for my Grandson - Page 7 Sig314
Nevadablue
Nevadablue
PostSubject: Re: A Rat Rod Wheelbarrow Bucket T Tractor/Kart for my Grandson   A Rat Rod Wheelbarrow Bucket T Tractor/Kart for my Grandson - Page 7 Icon_minitimeDecember 3rd 2021, 8:16 pm
Thanks guys. I played (and had fun) for a while today. The shifter support is built and welded together. The old handle has been shortened. Maybe tomorrow I’ll get it mounted. Some cutting and welding left to do.
The good thing is that the 10 pound spool of wire I put on the welder WORKS! I hadn’t run it since I put that on. Now the gas tank is nearly empty. It is a tall one, so when I do get a full tank I should have enough for this lifetime.
Nevadablue
Nevadablue
PostSubject: Re: A Rat Rod Wheelbarrow Bucket T Tractor/Kart for my Grandson   A Rat Rod Wheelbarrow Bucket T Tractor/Kart for my Grandson - Page 7 Icon_minitimeDecember 18th 2021, 7:32 pm
Been a while. I did LOOK at the rat rod today. And, my neighbor brought over the steering wheel he cut out for me.
A Rat Rod Wheelbarrow Bucket T Tractor/Kart for my Grandson - Page 7 850ed610
The plan is to drill holes where the circles are and trim the outer edges as shown and set those into bent pipe sections to make the ends round. The plate above the wheel is a piece from the donor machine’s clutch/brake shaft. I plan to weld the center metal from the original steering wheel to the center of that plate and bolt it to the wheel. Lots of smoothing and grinding and sit down fun.
MightyRaze, Brianator and MN mudder like this post
FlyFrog
FlyFrog
PostSubject: Re: A Rat Rod Wheelbarrow Bucket T Tractor/Kart for my Grandson   A Rat Rod Wheelbarrow Bucket T Tractor/Kart for my Grandson - Page 7 Icon_minitimeJanuary 18th 2022, 9:55 am
hows the build going? any updates?
Nevadablue
Nevadablue
PostSubject: Re: A Rat Rod Wheelbarrow Bucket T Tractor/Kart for my Grandson   A Rat Rod Wheelbarrow Bucket T Tractor/Kart for my Grandson - Page 7 Icon_minitimeJanuary 18th 2022, 12:06 pm
No, it has just been too cold to work in my shop. Soon, I hope.
MightyRaze and MN mudder like this post
Nevadablue
Nevadablue
PostSubject: Re: A Rat Rod Wheelbarrow Bucket T Tractor/Kart for my Grandson   A Rat Rod Wheelbarrow Bucket T Tractor/Kart for my Grandson - Page 7 Icon_minitimeFebruary 19th 2022, 10:26 pm
No real progress other than collecting parts and planning. I did touch the rig a few times lately. I decided to make a check list of things I need to get done so I can test drive it. The list got long pretty quickly.
Rat Rod To-Do
- [ ] Remove chrome front end parts for now
- [ ] Remove hub from other rear wheel
- [ ] Fit hubs to rear axle
- [ ] Install set screws in rear hubs
- [ ] Install rear tires
- [ ] Check lube in transaxle (clean and change later)
- [ ] Install bushings in front hubs
- [ ] Finish shifter mechanism
- [ ] Install belt guards
- [ ] Drain oil, tag engine, so I can turn rig on it’s side to install belt guards
- [ ] Fab steering shaft support
- [ ] Fit steering wheel to steering shaft
- [ ] Make and install brake and clutch pedal pads
- [ ] Fab and install and connect throttle pedal
- [ ] Wiring, install harness
- [ ] Install headlights, tail lights, brake and turn lights
- [ ] Install new oil filter, oil and air cleaner
- [ ] Make seat padding
- [ ] fab aluminum dash panel and engine turn it before mounting parts
- [ ] install gas tank and make access panel
I’m sure there will be some more items added, but I want to concentrate on getting it drivable so i can work out any bugs.
FatMike
FatMike
PostSubject: Re: A Rat Rod Wheelbarrow Bucket T Tractor/Kart for my Grandson   A Rat Rod Wheelbarrow Bucket T Tractor/Kart for my Grandson - Page 7 Icon_minitimeFebruary 19th 2022, 11:28 pm
You're doing better than me, if I made a list like that it would be a whole page and then some i have to break mine down into smaller assemblies.
Living in michigan means having a heater in the garage is almost necessary if you want to work in there unless your young and more tolerant of the cold which I am not, but even so with heat i still don't get as much time in the garage as I need to.
Nevadablue
Nevadablue
PostSubject: Re: A Rat Rod Wheelbarrow Bucket T Tractor/Kart for my Grandson   A Rat Rod Wheelbarrow Bucket T Tractor/Kart for my Grandson - Page 7 Icon_minitimeFebruary 19th 2022, 11:34 pm
The cold is a killer for me now. I’ll be 75 in March and I just can’t take the cold for long. I decided to wait till it warms up some before I fire up the welder again. That list is just the things I can think of to get it moving under it’s own power. Then comes the fun part, finishing and driving.
I have a propane radiant heater in the shop but it only warms what it is pointed at. The building is big and doesn’t heat well. I can wait. A Rat Rod Wheelbarrow Bucket T Tractor/Kart for my Grandson - Page 7 1f601
TechnoChicken
TechnoChicken
PostSubject: Re: A Rat Rod Wheelbarrow Bucket T Tractor/Kart for my Grandson   A Rat Rod Wheelbarrow Bucket T Tractor/Kart for my Grandson - Page 7 Icon_minitimeFebruary 20th 2022, 6:48 am
Down here it's easy to put on 10 coats, it's your hands that are always the problem in -10 degree weather
FlyFrog
FlyFrog
PostSubject: Re: A Rat Rod Wheelbarrow Bucket T Tractor/Kart for my Grandson   A Rat Rod Wheelbarrow Bucket T Tractor/Kart for my Grandson - Page 7 Icon_minitimeApril 5th 2022, 9:49 am
I am so glad i dont have to read pages of updates, i was really into this and intrigued but i had troubles getting on the site then was grounded, luckily i can resume checking for updates as it starts to get warmer
Nevadablue
Nevadablue
PostSubject: Re: A Rat Rod Wheelbarrow Bucket T Tractor/Kart for my Grandson   A Rat Rod Wheelbarrow Bucket T Tractor/Kart for my Grandson - Page 7 Icon_minitimeApril 5th 2022, 5:34 pm
I will be working on it soon I hope. Still some garden/yard work to do then I can resume the slow progress. Razz
Page 7 of 7Go to page : Previous  1, 2, 3, 4, 5, 6, 7
» Truckin42's Go Kart/Tractor Build
» Custom offroad tractor/go kart
» Rat rod t bucket full custom
» Craftsman 25hp Rat Rod T bucket style
» 66 Sears Plow/Bucket Build
