 1976 Sears Craftsman Eager 1 RATROD/HOTROD
BlakeGroce
9 posters
BlakeGroce
1976 Sears Craftsman Eager 1 RATROD/HOTROD - Page 2 Empty
PostSubject: Re: 1976 Sears Craftsman Eager 1 RATROD/HOTROD   1976 Sears Craftsman Eager 1 RATROD/HOTROD - Page 2 Icon_minitimeJuly 1st 2020, 4:07 pm
Thanks Rich! I think I can come up with something for a carb.
On a side note anyone know a trick to getting rusted rims off of the axles? I'm thinking about just taking both axles out and just setting them in a press, little heat and some penetrating oil should come out but anyone have a better way?
PostSubject: Re: 1976 Sears Craftsman Eager 1 RATROD/HOTROD   1976 Sears Craftsman Eager 1 RATROD/HOTROD - Page 2 Icon_minitimeJuly 1st 2020, 4:48 pm
If you want to save the rim... yeah heat is the best.  If you don't want to save the rim, you can carefully cut them off.
1976 Sears Craftsman Eager 1 RATROD/HOTROD - Page 2 Sig115PROJECTS:
1976 Sears Craftsman Eager 1 RATROD/HOTROD - Page 2 Sig2141976 Sears Craftsman Eager 1 RATROD/HOTROD - Page 2 Sig314
PostSubject: Re: 1976 Sears Craftsman Eager 1 RATROD/HOTROD   1976 Sears Craftsman Eager 1 RATROD/HOTROD - Page 2 Icon_minitimeJuly 1st 2020, 10:09 pm
Like mighty said, angle grinder never fails. If you're driving them out, make sure the end of the shaft doesn't mushroom. That's the important part.
PostSubject: Re: 1976 Sears Craftsman Eager 1 RATROD/HOTROD   1976 Sears Craftsman Eager 1 RATROD/HOTROD - Page 2 Icon_minitimeJuly 2nd 2020, 12:16 pm
That is very important...
BlakeGroce
BlakeGroce
PostSubject: Re: 1976 Sears Craftsman Eager 1 RATROD/HOTROD   1976 Sears Craftsman Eager 1 RATROD/HOTROD - Page 2 Icon_minitimeJuly 2nd 2020, 7:36 pm
I having a great time. No
These transmissions are weird as heck!
1976 Sears Craftsman Eager 1 RATROD/HOTROD - Page 2 20200710
1976 Sears Craftsman Eager 1 RATROD/HOTROD - Page 2 20200711
PostSubject: Re: 1976 Sears Craftsman Eager 1 RATROD/HOTROD   1976 Sears Craftsman Eager 1 RATROD/HOTROD - Page 2 Icon_minitimeJuly 2nd 2020, 7:51 pm
That a peerless 600?  @AllisKidD21 knows a lot about them.
BlakeGroce
BlakeGroce
PostSubject: Re: 1976 Sears Craftsman Eager 1 RATROD/HOTROD   1976 Sears Craftsman Eager 1 RATROD/HOTROD - Page 2 Icon_minitimeJuly 2nd 2020, 11:23 pm
Yeah it's a 600. Once I got it all apart it actually is alot simpler than my wheel horse. Definitely a pretty weak transaxle but I guess I'm use to the 85 pound cast iron pure bread MERICA! Transaxles. But I do appreciate how light it is.
PostSubject: Re: 1976 Sears Craftsman Eager 1 RATROD/HOTROD   1976 Sears Craftsman Eager 1 RATROD/HOTROD - Page 2 Icon_minitimeJuly 3rd 2020, 6:35 am
Yep, the good ol' Peerless 600! Those things are great, definitely my favorite vertical input transaxle.
BlakeGroce
BlakeGroce
PostSubject: Re: 1976 Sears Craftsman Eager 1 RATROD/HOTROD   1976 Sears Craftsman Eager 1 RATROD/HOTROD - Page 2 Icon_minitimeJuly 3rd 2020, 3:16 pm
Well I dug out what use to be a snap ring and a needle bearing....the rest of it was just mush. Some of the gears are pretty worn but they're good enough for me so I'm gonna run em anyways.
The carnage
1976 Sears Craftsman Eager 1 RATROD/HOTROD - Page 2 15938010
PostSubject: Re: 1976 Sears Craftsman Eager 1 RATROD/HOTROD   1976 Sears Craftsman Eager 1 RATROD/HOTROD - Page 2 Icon_minitimeJuly 3rd 2020, 3:44 pm
The mowrons ran 600s in their first batch of tractors. Don’t know what exactly broke, but they said they broke them a lot. It be ok for lighter off roading but a big pulley swap and a vtwin or oppy would probably kill it pretty quick.
AK is kind of the 600 guru, so he is the one to ask about weak points and where to find parts
BlakeGroce
BlakeGroce
PostSubject: Re: 1976 Sears Craftsman Eager 1 RATROD/HOTROD   1976 Sears Craftsman Eager 1 RATROD/HOTROD - Page 2 Icon_minitimeJuly 3rd 2020, 4:14 pm
Will do!  1976 Sears Craftsman Eager 1 RATROD/HOTROD - Page 2 2731072446  I found everything I need on searspartsdirect suprisingly.
I did polish the input shaft because I heated it up to get the pulley off. Basically I just do it the old school way and use some 400 grit and spray it down with oil (I used WD40) then hand sand it till it's not gritty anymore, then I used some mother's mag polish to polish it up. You dont have to use mothers just any ol metal polish will work. I've used brasso in the past but that stuff smells like pure cancer in a bottle so I used mother's this time around.....plus it's way better anyways. (This also works on crankshafts but use some sort of string to wrap around the sandpaper so you can work it from all sides.)
Before
1976 Sears Craftsman Eager 1 RATROD/HOTROD - Page 2 20200712
After
1976 Sears Craftsman Eager 1 RATROD/HOTROD - Page 2 20200713
PostSubject: Re: 1976 Sears Craftsman Eager 1 RATROD/HOTROD   1976 Sears Craftsman Eager 1 RATROD/HOTROD - Page 2 Icon_minitimeJuly 3rd 2020, 7:01 pm
Wow, that's pretty good! I'll have to try that on some stuff!
PostSubject: Re: 1976 Sears Craftsman Eager 1 RATROD/HOTROD   1976 Sears Craftsman Eager 1 RATROD/HOTROD - Page 2 Icon_minitimeJuly 3rd 2020, 11:23 pm
If prepped right a pulley swap and big engine isn't gonna kill it, just the same as any other lawn tractor transaxle. Not like there are any shift keys to wear out or anything, and they are already oil filled.
Lots of racers use the ol' 600's with good luck but there are a couple things that need addressed before running the high speeds that they do.
BlakeGroce
BlakeGroce
PostSubject: Re: 1976 Sears Craftsman Eager 1 RATROD/HOTROD   1976 Sears Craftsman Eager 1 RATROD/HOTROD - Page 2 Icon_minitimeJuly 5th 2020, 3:01 pm
Well I knocked out what's left of that bearing. I'm not sure how the heck these get lubricated because there is a seal on the outside of the aluminum case and there is no gasket between the case and the axle housing so I'm not sure if you're supposed to fill up the axle housings with oil or what.
1976 Sears Craftsman Eager 1 RATROD/HOTROD - Page 2 20200714
BlakeGroce
BlakeGroce
PostSubject: Re: 1976 Sears Craftsman Eager 1 RATROD/HOTROD   1976 Sears Craftsman Eager 1 RATROD/HOTROD - Page 2 Icon_minitimeJuly 6th 2020, 10:11 pm
Did some work on one of the case halves. Inside it was chewed up from those peices of bearing and snap ring floating around in there. So I just plugged up the bearing and the bushing, then took a dremel with a sanding wheel and just smoothed it all out.
1976 Sears Craftsman Eager 1 RATROD/HOTROD - Page 2 20200717
BlakeGroce
BlakeGroce
PostSubject: Re: 1976 Sears Craftsman Eager 1 RATROD/HOTROD   1976 Sears Craftsman Eager 1 RATROD/HOTROD - Page 2 Icon_minitimeJuly 17th 2020, 3:12 pm
Well I need some opinions on clear coat. I'm not sure which to do either satin or gloss. Gloss really brings out the color and also makes it easier to clean but it gets too glossy and I kinda want my rust to look like rust. Satin just kinda fades away and you really cant tell you even painted it....cant feel it either but it keeps it the way it looks now. I dont know which one I like and honestly I could just go semi gloss but I dont know what that looks like. Just need some opinions.
1976 Sears Craftsman Eager 1 RATROD/HOTROD - Page 2 20200729
On the left side of the yellow line is gloss and on the right side is the satin.
PostSubject: Re: 1976 Sears Craftsman Eager 1 RATROD/HOTROD   1976 Sears Craftsman Eager 1 RATROD/HOTROD - Page 2 Icon_minitimeJuly 17th 2020, 5:14 pm
Seen the black frame on a craftsman. That is semi gloss.
BlakeGroce
BlakeGroce
PostSubject: Re: 1976 Sears Craftsman Eager 1 RATROD/HOTROD   1976 Sears Craftsman Eager 1 RATROD/HOTROD - Page 2 Icon_minitimeJuly 18th 2020, 11:56 pm
BlakeGroce
BlakeGroce
PostSubject: Re: 1976 Sears Craftsman Eager 1 RATROD/HOTROD   1976 Sears Craftsman Eager 1 RATROD/HOTROD - Page 2 Icon_minitimeAugust 10th 2020, 2:27 pm
Well I managed to get a bunch of carburetors that my grandfather had for spare parts so hopefully I can make one good one out of these.
1976 Sears Craftsman Eager 1 RATROD/HOTROD - Page 2 20200810
PostSubject: Re: 1976 Sears Craftsman Eager 1 RATROD/HOTROD   1976 Sears Craftsman Eager 1 RATROD/HOTROD - Page 2 Icon_minitimeAugust 10th 2020, 9:19 pm
Carb kits are pretty reasonable and give you parts that may need.  I use to cannibalize, now I get kits.  They work out so much better.
BlakeGroce
BlakeGroce
PostSubject: Re: 1976 Sears Craftsman Eager 1 RATROD/HOTROD   1976 Sears Craftsman Eager 1 RATROD/HOTROD - Page 2 Icon_minitimeAugust 19th 2020, 4:10 pm
I'm getting a carb kit but I just needed a float bowl, needle, the float bowl shaft, and spring for the idle adjustment screw. I know I can just buy all of that new but I'm cheap and I'm also cheap. lol!
PostSubject: Re: 1976 Sears Craftsman Eager 1 RATROD/HOTROD   1976 Sears Craftsman Eager 1 RATROD/HOTROD - Page 2 Icon_minitimeAugust 19th 2020, 9:40 pm
I mean why buy it if you don't have to!
600s have always seemed stout to me. I've seen plenty around here. Usually the first thing to break on a vertical input trans is the case, and it seems to me that would one of the last things that would break on a 600.
BlakeGroce
BlakeGroce
PostSubject: Re: 1976 Sears Craftsman Eager 1 RATROD/HOTROD   1976 Sears Craftsman Eager 1 RATROD/HOTROD - Page 2 Icon_minitimeAugust 19th 2020, 10:14 pm
Yeah it's pretty thick! I really had low expectations of it since its aluminum and only having 3/4 inch axles but it's a nice little transaxle.
Also got my bearings ordered for it today and my carb kit. Gotta order my seal kit next so I can get this thing back together!
BlakeGroce
BlakeGroce
PostSubject: Re: 1976 Sears Craftsman Eager 1 RATROD/HOTROD   1976 Sears Craftsman Eager 1 RATROD/HOTROD - Page 2 Icon_minitimeAugust 24th 2020, 7:14 pm
Well I just realized that theres a bunch of stuff that I've done but havent mentioned.
First off my dad took the rear rims to work and pressed the axles out. Waiting on getting them sandblasted. I'll probably paint them white.
1976 Sears Craftsman Eager 1 RATROD/HOTROD - Page 2 15983110
I also painted yhe axle shafts satin black.
1976 Sears Craftsman Eager 1 RATROD/HOTROD - Page 2 15983111
BlakeGroce
BlakeGroce
PostSubject: Re: 1976 Sears Craftsman Eager 1 RATROD/HOTROD   1976 Sears Craftsman Eager 1 RATROD/HOTROD - Page 2 Icon_minitimeAugust 24th 2020, 7:23 pm
Also does anyone know what type of steering this is? It has SO MUCH play in it that it wont even turn left and turns to the right just a little bit. The front axle is also wore slam out so I'm sure that's not helping. No
1976 Sears Craftsman Eager 1 RATROD/HOTROD - Page 2 15983112
PostSubject: Re: 1976 Sears Craftsman Eager 1 RATROD/HOTROD   1976 Sears Craftsman Eager 1 RATROD/HOTROD - Page 2 Icon_minitimeAugust 24th 2020, 8:44 pm
That joint there on the drag link looks awful loose. Might be a big part of the slop
» Craftsman ratrod mod
» Sears craftsman gt 16
» Sears craftsman. The unknown mower
» 1982 Sears Craftsman LT10
» 1966 sears craftsman build
