I know I said I was going to paint it JD Green but I just wanted to get this project finished and I had some hot rod black (matte black) left over from my mustang so I just used thar. Honestly, I'm kind of digging it. I'll will get it all together tomorrow and and take a picture then.
That yellow seat is going to have to go! I think I may tint over that large light lens. I did add a couple of red led lights but you can't see them with the regular bulbs on.
BigPip Member
Age : 44 Join date : 2014-08-10 Points : 3844 Posts : 73 Location : Central FL
Made a few changes including a black seat, smoked headlight lens and changing the oil and filter. This time I added zddp and Lucas oil stabilizer to her and that valve chatter went away in less than 3 minutes Here is a quick walk around
BigPip Member
So this is going to be the last update for awhile because... Well, she's done. Mostly, eventually I will get around to completely redoing the front end but for now I'm just going to Send it!
BigPip Member
Here we are... Stage 2 I found a front end from a golf cart pretty cheap on marketplace so I decided I needed to make it work. 3/8 angle on the front frame rails and extended out about 4 inches. Next week I get to sort out the steering.
MightyRaze, Brianator, Nevadablue and FatMike like this post
Brianator Moderator
I mean, I did put red stickers on it... But on stage 3 I have color change plans. Anyways, I never posted pictures of the chain drive setup. Belt drive from engine, through clutch to jackshaft - chain around jackshaft and transmission. I know everyone wants speed out of their rigs but I use my tractor to pull my trailer around and had to tone it down to a maximum speed of 9mph in 5th gear. Anyways, don't pick the pictures apart to much because it was really just slapped together for fitment. After I get the steering working I will be taking this apart and making it beefier.
Well I got the steering working, that was fun! I used the original steering shaft, cut off the teeth and used a lathe to make the diameter small enough to slide in the steering joint. I also had to lathe the shaft going into the golf cart steering joint because it was smaller. After all the lathing fun I zapped them in and figured out the rest... Twice... First time was a fail but I cleaned up, went inside and pondered on it for a little bit and went back to work and now we are golden.
Brianator Moderator
I redid the shifter linkage last week but it is still really hard to shift. Not sure why but I'm sure it's in the transmission. Today I finished up the exhaust, I was searching O Reilly's and found an exhaust pipe just the size I was looking for (1.75") and it had some bends on it! Double win, ordered it Monday for Tuesday pickup and this morning I put it to work and the straight part is just about as long as the foot board which I really liked. And to finish the exhaust I found a Yamaha muffler and a Harley Davidson muffler that was in a scrap pile but couldn't find it inside myself to throw them out. Obviously I went with the HD pipe
Here is the exhaust pipe all welded up and ready to get installed
And here it is all finished up- originally I did not plan on the tip sticking out so far but it's growing on me
The last thing I did to it today was cut off the right pedal and welded the left pedal to the shaft so I could have a left clutch pedal. Drives me nuts every time I get on this thing with a left clutch pedal. I planned on still using the parking brake lock but when I cut the pedal off I cut just a hair to much so I do not have a parking brake right now... To be continued...
