 JD LT150 ... continuation
Rustbucket Garage
BigPip
10 posters
BigPip
BigPip
JD LT150 ... continuation Empty
PostSubject: JD LT150 ... continuation   JD LT150 ... continuation Icon_minitimeApril 24th 2020, 2:27 pm
So I tried out for the build off last year, I hope to do it again! I had all the time in the world to finish but somehow didn't have enough time... Figure that one out. There were still a bunch of things I wanted to do it and a confession. I was given a lot of grief about the way I extended the drive pulley and I didn't care- I was gonna run it anyways and fix it when it broke, it just needed to work "for now"... Which it did... Kind of. In my video I used in the build off, I got lucky that my daughter just happened to video me when she did because, NO LIE, 3 seconds after she stopped recording all hell broke lose! The axle is fine, thanks for asking 😂. However, the tension from so far above (6.5") ripped the pulley apart on the axle. 😲.
Enough about that- I recently cleaned my garage and I did the most hated thing ever, I moved the tractor to my shed. As I was pushing it to the back yard as I was telling myself"well, bud- this is the beginning of the end. 😩 I was not satisfied with it being the end and every day I think about what I needed to do to fix it and I am EXTREMELY happy to say I figured it out, ordered a bunch of parts and hopefully in the next couple of weeks I will be getting back to work on it!
I am building a jackshaft kit this time with a smaller pulley in the top, down to a chain gear and I am replacing the original belt pulley in the axle with a gear sprocket to connect to the jackshaft. What I did here is I bought two different size sprockets  for the axle, a 9 tooth and 16 tooth. The drive sprocket is a 12 tooth so I can adjust for speed it creep 👍🏼.
I will be paying more as I receive my this and get ready to go to work.
JD LT150 ... continuation Img_2032
BigPip
BigPip
PostSubject: Re: JD LT150 ... continuation   JD LT150 ... continuation Icon_minitimeApril 30th 2020, 8:20 am
My first package came in! #40 chain, sprockets, pillow blocks, collar locks and 1/4" keys. Still waiting for jackshaft, brake kit and chain tensioner. But when they come in- it's on 👍🏼
JD LT150 ... continuation Img_2072
PostSubject: Re: JD LT150 ... continuation   JD LT150 ... continuation Icon_minitimeApril 30th 2020, 9:34 am
Excellent update!  I can't help but think that rig needs a fake radiator cap or hood ornament up front!  Pretty cool.
JD LT150 ... continuation Sig115PROJECTS:
JD LT150 ... continuation Sig214JD LT150 ... continuation Sig314
BigPip
BigPip
PostSubject: Re: JD LT150 ... continuation   JD LT150 ... continuation Icon_minitimeApril 30th 2020, 9:44 am
You know what... I do have an old Ramcharger Hood ornament... Maybe something I need to look into.
PostSubject: Re: JD LT150 ... continuation   JD LT150 ... continuation Icon_minitimeApril 30th 2020, 11:14 am
Ramcharger ornament? Now we're talkin!
PostSubject: Re: JD LT150 ... continuation   JD LT150 ... continuation Icon_minitimeApril 30th 2020, 6:01 pm
Really neat build, a unique look for sure. I like it a lot. Can't wait to see what you come up with, especially starting with this.
BigPip
BigPip
PostSubject: Re: JD LT150 ... continuation   JD LT150 ... continuation Icon_minitimeMay 5th 2020, 3:34 pm
Here we have the belt pulley and the chain tensioner made for a motorcycle so it should work with no problem on this setup. Still waiting on one order that has the axle and brakes. Almost two weeks and they still haven't shipped it yet.
JD LT150 ... continuation Img_2073
BigPip
BigPip
PostSubject: Re: JD LT150 ... continuation   JD LT150 ... continuation Icon_minitimeDecember 13th 2020, 11:06 am
Well... It Feels like this is taking forever!
Today I want to swap the hydro-gear over and see if maybe I can weld the hood brackets on the JD so I can have a proper hood. The lever in the back of the hydro gear won't disengage so that will be the first order of business
JD LT150 ... continuation Img_2095
BigPip
BigPip
PostSubject: Re: JD LT150 ... continuation   JD LT150 ... continuation Icon_minitimeDecember 13th 2020, 3:46 pm
Alright, got the transmission out- I'm going to drain the fluid in it and add clean fluid before I swap them out. Brake ended up being frozen on it, after I loosened the two bolts it was free so that was nice.
I cut the front of the Craftsmen off for the hood mount and had to cut about an inch off the JD to make it fit good
JD LT150 ... continuation Img_2097
JD LT150 ... continuation Img_2098
And of course I couldn't stop there, I had to custom the exhaust just a little... I will do more work to it later
JD LT150 ... continuation Img_2099
JD LT150 ... continuation Img_2096
BigPip
BigPip
PostSubject: Re: JD LT150 ... continuation   JD LT150 ... continuation Icon_minitimeDecember 14th 2020, 8:56 pm
Had to do some math today, originally I was going to connect the trans to the jackshaft with a chain but due to two things I had to change this up. The transmission input on the hydro only want to see 3000 RPM and the pulley on it is a spline for not a key. So knowing the motor pulley is 3" and the transmission pulley is 3.86" I had to figure out the sizes needed for the two other pulleys and I came up with 3.25" for both of them will run the transmission at about 2,800 rpm. I drained the oil today and will fill it and burp it tomorrow and maybe get it bolted on the tractor!
Shifter is going to be SOOOO much easier to connect, just need to figure out the bolting up the jackshaft and belt sizing.
PostSubject: Re: JD LT150 ... continuation   JD LT150 ... continuation Icon_minitimeDecember 14th 2020, 10:25 pm
Doing a great job!
BigPip
BigPip
PostSubject: Re: JD LT150 ... continuation   JD LT150 ... continuation Icon_minitimeDecember 15th 2020, 10:19 pm
5 speed out and the hydro is in! The new pulleys arrived today so hopefully I can start fabricating the mounts for the jackshaft tomorrow. Fingers crossed
JD LT150 ... continuation Img_2100
BigPip
BigPip
PostSubject: Re: JD LT150 ... continuation   JD LT150 ... continuation Icon_minitimeJanuary 21st 2021, 12:53 pm
I need to finish this build so I can start in my next build!
Today I finally stole since time to build my jackshaft mount. I will post some more pictures later once it is mounted in place.
JD LT150 ... continuation Img_2103
JD LT150 ... continuation Img_2102
JD LT150 ... continuation Img_2101
BigPip
BigPip
PostSubject: Re: JD LT150 ... continuation   JD LT150 ... continuation Icon_minitimeJanuary 21st 2021, 3:46 pm
The bracket is in! I got the measurement for the new top belt, when I pick that up I will buy the hardware to mount the bearings and that will be complete. Hedge that I have to make the linkage for the transmission- that will be super easy. Can't wait to finally drive this puppy! I will install the brakes after first drive... Of course 😆
JD LT150 ... continuation Img_2105
JD LT150 ... continuation Img_2104
BigPip
BigPip
PostSubject: Re: JD LT150 ... continuation   JD LT150 ... continuation Icon_minitimeJanuary 22nd 2021, 5:17 pm
It's moving... FINALLY! JACKSHAFT is working pretty awesome, had a few issues to attend to after it was moving, alignment is the pulleys and had to add an extra idler pulley for clearance and ah, yeah- so glad I can finally ride this thing! Hydro trans is pretty awesome on this thing too. Need to finish the exhaust on it and maybe add the lights I bought for it
Rustbucket Garage
Rustbucket Garage
PostSubject: Re: JD LT150 ... continuation   JD LT150 ... continuation Icon_minitimeJanuary 22nd 2021, 6:15 pm
Looks good! I really like the rims.
BigPip
BigPip
PostSubject: Re: JD LT150 ... continuation   JD LT150 ... continuation Icon_minitimeJanuary 22nd 2021, 7:25 pm
Thanks, they are golf cart rims- got then for a steal of a price on fleabay.
BigPip
BigPip
PostSubject: Re: JD LT150 ... continuation   JD LT150 ... continuation Icon_minitimeJanuary 22nd 2021, 7:32 pm
Short video of it moving
BigPip
BigPip
PostSubject: Re: JD LT150 ... continuation   JD LT150 ... continuation Icon_minitimeJanuary 24th 2021, 3:50 pm
I have gotten a lot done in this past week, dang it feels good! Today I made a shift plate then added a muffler ( or 2) which helped because it was LOUD!
JD LT150 ... continuation Img_2107
JD LT150 ... continuation Img_2108
JD LT150 ... continuation Img_2106
Rustbucket Garage
Rustbucket Garage
PostSubject: Re: JD LT150 ... continuation   JD LT150 ... continuation Icon_minitimeJanuary 24th 2021, 6:48 pm
Do you plan to paint the entire machine or leave it like it is?
BigPip
BigPip
PostSubject: Re: JD LT150 ... continuation   JD LT150 ... continuation Icon_minitimeJanuary 24th 2021, 7:25 pm
Paint is in the plans- probably JD Green though
Rustbucket Garage
Rustbucket Garage
PostSubject: Re: JD LT150 ... continuation   JD LT150 ... continuation Icon_minitimeJanuary 24th 2021, 7:55 pm
Best color of green out there in my mind. JD LT150 ... continuation 2731072446
PostSubject: Re: JD LT150 ... continuation   JD LT150 ... continuation Icon_minitimeJanuary 24th 2021, 8:06 pm
Looks good!  Good job not blowing holes in the fenders!
BigPip
BigPip
PostSubject: Re: JD LT150 ... continuation   JD LT150 ... continuation Icon_minitimeJanuary 31st 2021, 3:57 pm
I gained a little progress on the tractor, she's sporting a bunch of primer and no more stickers bounce
And she also has working brakes! Not that it is really needed with the hydro trans but when I attach my trailer to it I will be glad I have them. It didn't mount very pretty but it works, I had to weld the rotor to the hub because there was not a key groove that far back but whatever- it works!
I also found out that I installed a wrong pulley on my jackshaft- I knew I needed a 3.25 up top and a 3.5 on the bottom to give me a stock rpm of about 3000 at the transmission but I accidently put a 3.25 in both top and bottom which have a Max output of about 2700. At this point, I can't change the bottom pulley but I can change the top and the only extra pulley I had left was a 2.7 which would end up with about 3360 at the trans. So, what do you do? YOU SEND IT! and ask for forgiveness to the hydro gods too.. I think. Top speed was a neck breaking 8-9mph
JD LT150 ... continuation Img_2109
BigPip
BigPip
PostSubject: Re: JD LT150 ... continuation   JD LT150 ... continuation Icon_minitimeFebruary 4th 2021, 3:46 pm
I know I said I was going to paint it JD Green but I just wanted to get this project finished and I had some hot rod black (matte black) left over from my mustang so I just used thar. Honestly, I'm kind of digging it. I'll will get it all together tomorrow and and take a picture then.
JD LT150 ... continuation Img_2110
