 DEKOPRO 110/220V 160A ARC Welder Review
Hillbilly Offroading
2019 Build-Off Entrant
1st Place Build-Off 2020
DEKOPRO 110/220V 160A ARC Welder Review  Empty
PostSubject: DEKOPRO 110/220V 160A ARC Welder Review    DEKOPRO 110/220V 160A ARC Welder Review  Icon_minitimeApril 24th 2020, 12:33 pm
Wanted to do a review of this DEKOPRO 110/220V MMA Welder,160A ARC Welder. This portable Welder (11.4" x 4.92"x 7.87") comes equipped with Machine IGBT Digital Display LCD Hot Start with Electrode Holder, Work Clamp, Input Power Adapter Cable, and Brush. It's very lightweight, compact, and portable unit. At 110v its capable of running a 3/32 rod with no problem and on 220v it can handle a 1/8 rod and have great penetration on 1/4 metal. Dual voltage range is nice when having to do field work. The ground clap isn't bad just not the best but nowhere near the worst. Arrow For Sale On Ebay For $115 Click Here Exclamation There sold on Ebay, Amazon, Walmart, & a few other places that ranges from $115-$170. This power full unit will enable you to have professional looking welds and welds thin metal for yall that does body work on your project vehicles.
★Advanced IGBT Inverter Technology:Powerful welder capable of welding mild steel, weld steel, stainless steel and cast iron. IGBT power device with unique control mode improves the reliability of welding machine
★Portable Design:This welder features a easy carrying handle,compact design, easy for translation and storage. Very convenient,  It can be used anywhere you need
★Leading Control Mode:Closed loop feedback control,the output voltage is stable,strong adaptability for electricity network
★Energy Efficient:Reduce the damage of Copper and Iron,obviously increase the frequency,and energy-conserving result is remarkable
★Multi Use: The MMA welder is suitable for welding stainless steel, mild steel, aluminum and other metal materials
Specification:
Material:
steel frame and plastic handle
Net weight:12.1 lbs
Package Dimension:11.4" x 4.92"x 7.87"
Length of power cord:71.6"
Input Voltage: Ac110/220V               AC not DC
Input Power:5.8KW
No-load Voltage:60V
Current Range:10-160(A )
Rated Duty Cycle(%): 40/60
Protection Grade:IP21S
Power Factor:0.85
What your getting for your money:
1X MMA Welder
1X Electrode Holder & 9.28 ft. Cable
1X Work Clamp & 9.55 ft. Cable
1X Input Power Adapter Cable & Plug
1X Plug adapter & 19.3 inch 1X Brush & 3.26 inch
1X Owner’s Manual
Pros: lightweight, compact, capable of 110v and 220v , easy to use, professional finish welds, long leads, great unit for beginners/hobbyist/advanced farcatiors/mud mower modifications, and affordable.
Cons: Stinger is plastic so I wouldn't recommend swinging it at stuff, upgrade the wire brush and slag hammer for sure, and that's really all.
DEKOPRO 110/220V 160A ARC Welder Review  51sgzq10
DEKOPRO 110/220V 160A ARC Welder Review  51h3am10
DEKOPRO 110/220V 160A ARC Welder Review  51cjve10
DEKOPRO 110/220V 160A ARC Welder Review  51biqz10
DEKOPRO 110/220V 160A ARC Welder Review  516ss610
DEKOPRO 110/220V 160A ARC Welder Review  41xhgn10
DEKOPRO 110/220V 160A ARC Welder Review  41foc710
» 220v single phase?
» VOTE REVIEW!
» i really need a welder....
» 84 murray mudding project
» First Welder
All-Terrain Lawn Tractor Forum :: Product Reviews :: Power Equipment/ Tools-
