 220v single phase?
ncredleg
motorhead45102
6 posters
motorhead45102
220v single phase? Empty
PostSubject: 220v single phase?   220v single phase? Icon_minitimeJune 12th 2010, 9:32 pm
Im getting alittle confused, but i get confused alot unless i actually see the thing im trying to work with.
well i just wanted to get an idea, the 220v welder is a single phase, can someone give me alittle info on it. Im sure it will come to sense once i get an idea. is single phase 220 like the outlet for the dryer?
well i know electric but the phases thing kinda gets confusing a little bit.
ncredleg
ncredleg
PostSubject: Re: 220v single phase?   220v single phase? Icon_minitimeJune 13th 2010, 7:37 am
motorhead45102 wrote:
I`m getting a little confused, but I get confused alot unless I actually see the thing I`m trying to work with.
well I just wanted to get an idea, the 220v welder is a single phase, can someone give me a little info on it. I`m sure it will come to sense once I get an idea. is single phase 220 like the outlet for the dryer?
well I know electric but the phases thing kinda gets confusing a little bit.
A 220vac single phase welder uses the same volts and amps as your electric stove, 220vac 50amps. Mine anyhow. Smile study
CMHN
CMHN
PostSubject: Re: 220v single phase?   220v single phase? Icon_minitimeJune 13th 2010, 8:32 am
Yes, you will wire up your new receptacle for your welder just like your electric heater, you may need to use a bigger breaker though. I use a 50 amp for my welder.
3 phase is mainly used in factories, single phase is used in most homes and many businesses.
http://ctraugh.blogspot.com/
motorhead45102
PostSubject: Re: 220v single phase?   220v single phase? Icon_minitimeJune 13th 2010, 8:42 am
thanks for giving me an idea, i was sure it was something i already knew, but wasn't sure.
Webmaster
Webmaster
Webmaster
Webmaster
PostSubject: Re: 220v single phase?   220v single phase? Icon_minitimeJune 13th 2010, 9:38 am
I have no idea on this stuff.... lol! I'm glad someone else knows! Electricians are expensive!
http://ww.atltf.com
PostSubject: Re: 220v single phase?   220v single phase? Icon_minitimeJune 13th 2010, 7:51 pm
My dad helped me wire some stuff up at my house - wired the kitchen , changed an outside outlet and wired the shed for me - only hard part is remembering its a circuit y haveta complete.
CMHN
CMHN
PostSubject: Re: 220v single phase?   220v single phase? Icon_minitimeJune 13th 2010, 8:29 pm
I have been in construction most of my life. I wired my first room when I was 14. I rewired my house from a 60 amp service to a 200 amp service when I moved in. Rewired the entire house and wired up my new addition. Everything passed inspection with flying colors, and I have had some strict inspectors come in, but they couldn't find anything to write me up on. Smile
Chunk
Chunk
PostSubject: Re: 220v single phase?   220v single phase? Icon_minitimeJune 14th 2010, 7:22 am
Wow, you seem like you're good at electrics then Chris! Laughing
Most wiring Ive done was my garage lighting....doesnt really compare to be honest.
Single phase is fine for what you need, so done worry!
220v single phase?
» Front bar phase 1
» DEKOPRO 110/220V 160A ARC Welder Review
» Briggs 17.5 single modifications.
» B&S 16 HP OHV Single Damn Smoke
» 17.5 hp briggs single cylinder
