 [2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build!
darkside0914
TheCollector
BlakeGroce
Hillbilly Offroading
13 posters
[2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 Empty
PostSubject: Re: [2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build!   [2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 Icon_minitimeFebruary 20th 2020, 8:59 pm
Looks good man. Makes me wanna build a rock bouncer now...
PostSubject: Re: [2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build!   [2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 Icon_minitimeFebruary 20th 2020, 9:26 pm
I just don't want the adjustment to turn because it kinda defeats the purpose of the joint, haha.
Well fellas I made some more progress after the last update!
Got some lower coilover mounts made up to be welded to the axle:
[2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 20200265
[2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 20200264
Set the coilovers in place to check things out:
[2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 20200263
Then I though I'd set the engine in place before doing the upper mounts and I'm glad I did because there were some serious clearance issues:
[2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 20200266
[2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 20200267
However I wasn't too concerned. Since this frame is so long I was able to cut the hole for the crank and slide the engine back about 5" no problem:
[2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 20200268
Perfect! Just have to drill new mounting holes, but that's no problem. Also the engine being closer to the middle should help the weight balance anyways, so it'll work out nicely I'm thinking.
Then basically once I figured out the easiest way to do it, I made my coilover towers:
[2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 20200269
Look, no jack!!
[2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 20200270
[2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 20200271
[2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 20200272
There will be cross bracing for the towers too, I just ran out of time for that today. Also I rigged up a temporary track bar just so I could roll it around.
[2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 20200273
Did a little articulation test too of course, haha.
[2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 20200275
[2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 20200274
Not too bad! I didn't wanna push it until I got a chance to check clearances and stuff, but nothing appeared to be binding or anything. Has a good amount of drop travel too which should be great for crawling.
Then to cap it all off, a hood fitment test:
[2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 20200276
Boy she fits good! No issues whatsoever.
So yeah, got some loose ends to tie up but the front suspension is pretty much done. I'm very pleased with it!
Let me know what you guys think!
PostSubject: Re: [2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build!   [2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 Icon_minitimeFebruary 20th 2020, 9:27 pm
Thanks CQ!
PostSubject: Re: [2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build!   [2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 Icon_minitimeFebruary 21st 2020, 1:52 pm
Looks good! Looks kinda like a lifted K10 in the front and a 1930s Mercedes-Benz in the rear... Interesting.
PostSubject: Re: [2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build!   [2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 Icon_minitimeFebruary 22nd 2020, 12:42 am
Thanks... I think. Haha.
Anyways, quick update here. Got the rims I planned on using seperated from the tires:
[2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 20200277
Old Cub Cadet rims, they have decent ball bearings in them so I figured they'd work fine.
Got the ATV tires swapped over no problem:
[2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 20200278
Good to go!
2019 Build-Off Entrant
1st Place Build-Off 2020
PostSubject: Re: [2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build!   [2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 Icon_minitimeFebruary 22nd 2020, 10:04 am
Interesting setup.
PostSubject: Re: [2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build!   [2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 Icon_minitimeFebruary 23rd 2020, 12:18 am
It works great I tell ya.
Not much progress today, got my lock collars put on to hold the wheels on the spindles:
[2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 20200279
Planned on removing the giant stock fuel tank amd replacing it with a smaller one. Need a place for the battery now that the engine has been moved back.
Stock tank:
[2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 20200280
Probably gonna use this one:
[2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 20200281
Looks like plenty of room for a battery. Should work well!
PostSubject: Re: [2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build!   [2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 Icon_minitimeFebruary 23rd 2020, 2:38 pm
Sure you want a smaller tank with a oppy?
PostSubject: Re: [2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build!   [2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 Icon_minitimeFebruary 23rd 2020, 2:42 pm
Is there room under the seat/fenders to fit a battery?
Did you drill the spindle any for the setscrew in your locking collar? Id worry about it sliding off during some hard riding.
PostSubject: Re: [2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build!   [2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 Icon_minitimeFebruary 23rd 2020, 4:53 pm
Pretty sure. I run two other oppy tractors with tanks about the same capacity as this.
Nah unfortunately there isn't enough height under the seat, besides that's just more cable to run, haha.
I think the collars would be fine but I could always drill a little dimple just to be sure.
PostSubject: Re: [2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build!   [2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 Icon_minitimeFebruary 23rd 2020, 9:22 pm
Yeah, AK is more of an off-road cruiser and less balls-to-the-wall.  That size should be fine for him.
[2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 2731072446 [2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 102878487
[2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 Sig115PROJECTS:
[2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 Sig214[2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 Sig314
PostSubject: Re: [2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build!   [2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 Icon_minitimeFebruary 23rd 2020, 9:40 pm
All my riding pretty much consists of some trails and a bunch of crawling spots like ditches and gulleys. Doesn't require much fuel to crawl or climb, but I have riding spots all over the property so I wanna be able to have some range.
Regardless, I'm not worried at all about the capacity of the tank.
PostSubject: Re: [2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build!   [2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 Icon_minitimeFebruary 23rd 2020, 9:51 pm
Nah, your fine. My brother runs an oppy with the same tank as that. Just fill it to the top and you'll have more than enough.
PostSubject: Re: [2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build!   [2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 Icon_minitimeMarch 7th 2020, 11:36 pm
AAaaannyways..
I finally got back to the Jake tonight:
[2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 20200324
Didn't get much done, but I got my temporary track bar knocked off and made up a permanent setup:
[2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 20200325
Much better! Gotta do some trimming in a couple spots for the hood but that will be simple enough.
PostSubject: Re: [2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build!   [2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 Icon_minitimeMarch 8th 2020, 8:18 am
@AllisKidD21 hey Allis are those Princesses Auto shocks ? How do you find them for stiffness?
PostSubject: Re: [2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build!   [2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 Icon_minitimeMarch 9th 2020, 1:00 pm
You are correct Buck, I got them from good ol' Princess Auto.
They are definitely about the perfect spring rate for holding this front end up, but soft enough that I can bottom out the suspension by jumping on the frame.
Anyhow I got the little bit of trimming done to make room for the new track bar. First thing was clearing the hood mount so it would sit next to the upper track bar mount.
Then I had to actually take out a spot of the bottom of the grille so the track bar would clear during travel:
[2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 20200326
This is at about full articulation on that side, so I shouldn't have any issues. Planning on making some bumpstops too.
PostSubject: Re: [2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build!   [2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 Icon_minitimeMarch 9th 2020, 8:34 pm
looking good, man I pulled one of those kohler opposed motors over the weekend and I couldnt believe how heavy it was... compared to the briggs , but the run so good I love them....
PostSubject: Re: [2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build!   [2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 Icon_minitimeMarch 9th 2020, 9:16 pm
Thanks! Yeah the cast iron cylinders really makes a difference in weight, haha. They are great engines!
PostSubject: Re: [2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build!   [2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 Icon_minitimeMarch 13th 2020, 9:09 am
Another minor update just to keep things going, I got the engine location figured out and drilled the new mounting holes yesterday, then I bolted up:
[2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 20200327
Kind of minor progress, but one more thing done nonetheless!
PostSubject: Re: [2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build!   [2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 Icon_minitimeMarch 14th 2020, 10:14 am
One more important front end item knocked off the list yesterday:
[2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 20200328
Cut out some pieces for coilover tower braces.
[2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 20200329
[2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 20200330
Perfect! Should be pretty good now.
PostSubject: Re: [2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build!   [2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 Icon_minitimeMarch 14th 2020, 2:21 pm
On the topic of those kohler twins, I can't believe how smooth they start and run. Shame they're not as common as briggs oppys.
That looks really sturdy allis. Those shocks look really nice too, wish i had a pair.
PostSubject: Re: [2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build!   [2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 Icon_minitimeMarch 14th 2020, 7:34 pm
I'd be game to run one.
PostSubject: Re: [2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build!   [2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 Icon_minitimeApril 3rd 2020, 2:05 pm
Nicely done on that shock tower and bracing.
PostSubject: Re: [2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build!   [2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 Icon_minitimeApril 3rd 2020, 9:58 pm
Thanks fellas.
Unfortunately I haven't been able to work on this tractor since things got all crazy, but hopefully I'll get back to it eventually.
PostSubject: Re: [2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build!   [2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 Icon_minitimeApril 4th 2020, 10:02 am
Is it because you can't get out to the farm?
PostSubject: Re: [2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build!   [2020 Build-Off Entry] AK's Jacobsen Rally Tractor Build! - Page 2 Icon_minitimeApril 4th 2020, 10:28 am
Yeah I don't wanna risk bringing anything out to the grandparents by hanging out there, so I've just been at home. Just taking extra precautions, haha.
» [DNF][2020 Build-Off Entry] Rally Deere Build
» [DNF][2020 Build-Off Entry] loggers gogert build off entry !!!!
» [DNF][2020 Build-Off Entry] Mini Back yard basher build
» [Withdrawn][2020 Build-Off Entry] Bear's beast
» [DNF][2020 Build-Off Entry] Murrraymountain's "Ole Blue" Murray
All-Terrain Lawn Tractor Forum :: Competitions and Challenges :: Build-Off Competition :: Build-Off Archives :: 2020 Archive-
