| [DNF][2020 Build-Off Entry] Rally Deere Build | |
+2RichieRichOverdrive yeethaw 6 posters |
yeethaw Member
Age : 19 Join date : 2019-04-23 Points : 2267 Posts : 182 Location : beecher il
yeethaw Member
yeethaw Member
| Subject: Re: [DNF][2020 Build-Off Entry] Rally Deere Build May 27th 2020, 9:16 pm | |
| well im starting the build, ive got it stripped down in my basement and im starting to work on making the clutch and mounting the engine. i have an engine that im gonna sell soon and once that is gone im gonna go and buy the live axle and the rest of the rear end. im hoping tonight to be able to get the dash mounts notched to fit the exhaust | |
yeethaw Member
| Subject: Re: [DNF][2020 Build-Off Entry] Rally Deere Build June 16th 2020, 11:23 pm | |
| Got the throttle set up on the v twin, also started to do a direct steering setup for it but I was having problems with roll over on steering shaft arm, how can I fix this? Also ordered my whole rear end setup so I hope to have that put in soon. Anybody have any opinions or input on this build? | |
Age : 22 Join date : 2016-10-29 Points : 7224 Posts : 4021 Location : Lewisburg, KY
| Subject: Re: [DNF][2020 Build-Off Entry] Rally Deere Build June 17th 2020, 6:29 am | |
- What do you mean rollover? Is an arm camming over and locking up?
If this is the case, just weld in some steering stops to limit travel so it doesn’t “roll over” | |
Age : 34 Join date : 2013-11-02 Points : 7171 Posts : 2910 Location : New Jersey USA
| Subject: Re: [DNF][2020 Build-Off Entry] Rally Deere Build June 17th 2020, 10:17 am | |
| You can either add steering stops on the axle or on the steering arm itself so it comes over and hits the axle. Just as long as it's heavy duty enough to not bend too bad or break off. I've used bolts before. | |
yeethaw Member
| Subject: Re: [DNF][2020 Build-Off Entry] Rally Deere Build June 23rd 2020, 9:57 pm | |
| Well I got the rear axle In and finally got the chance to do a mock-up on it. I’ve gotta send the tires back since the beads are messed up All I have left to do is •center rear axle •mount engine •mount trans •get new tires put on •repaint rims •mount clutch •front tires •repaint body And a few other things but this thing is looking closer to completion | |
yeethaw Member
yeethaw Member
mrshaft696 Established Member
Join date : 2016-07-10 Points : 4061 Posts : 870 Location : Phillydelphia
| Subject: Re: [DNF][2020 Build-Off Entry] Rally Deere Build August 29th 2020, 7:50 pm | |
| - Spoiler:
[adm]Per Rules and guidelines: Entrants MUST update their thread at least monthly detailing progress, with either write-ups, videos and/or photos.
If you cannot work on the project right now, please let us know. [/adm]
Last edited by MightyRaze on September 26th 2020, 12:45 am; edited 1 time in total | |
| Subject: Re: [DNF][2020 Build-Off Entry] Rally Deere Build September 25th 2020, 2:22 pm | |
| - Spoiler:
Topic Deficient [/adm]
Please make any kind of update in the next month to avoid probation!
yeethaw Member
| Subject: Re: [DNF][2020 Build-Off Entry] Rally Deere Build September 25th 2020, 9:03 pm | |
| So this things pretty much been sitting, I stole the engine from it for the craftsman. But I managed to get the front axle in, still need to make the spindles. This is probably going to end up being a winter project | |
