![All-Terrain Lawn Tractor Forum](https://i.servimg.com/u/f23/18/66/18/00/header10.png)
| | Pin locker durability | |
moparjim Member
![moparjim](https://2img.net/i/fa/i/avatars/gallery/Cinema/Cinema_50.jpg)
Age : 37 Join date : 2016-01-16 Points : 3273 Posts : 82 Location : Kent PA
![Pin locker durability Empty](https://2img.net/i/empty.gif) | Subject: Pin locker durability December 11th 2019, 10:04 am | |
| Utilizing fearlessfronts' method to lock a rear, how durable is it? I'm going to be running 27" tires on my 820 and would like to know if it would hold up. It's on my bolens with a 4" engine and 6.5" trans pulley. It also has a 12 hp Briggs powering it. | |
![Pin locker durability Empty](https://2img.net/i/empty.gif) | Subject: Re: Pin locker durability December 11th 2019, 10:39 am | |
| If you can get a good weld, the weak point would be the case. That style could allow for some flex and split the case if you run it hard. Fearless and many others have had luck and it has come out very durable. Personally, I like the solid axle. Doc style ![Smile](https://2img.net/i/fa/i/smiles/icon_smile.gif) | |
| ![Go down](https://2img.net/i/empty.gif) | | moparjim Member
![Pin locker durability Empty](https://2img.net/i/empty.gif) | Subject: Re: Pin locker durability December 11th 2019, 10:48 am | |
| I'm planning on building a case support truss/skid underneath and top brace as well hopefully incorporating my lift blocks into it as well. | |
| ![Go down](https://2img.net/i/empty.gif) | | CraftsmanQuad19 Veteran Member
![CraftsmanQuad19](https://2img.net/u/2812/37/66/46/avatars/2588-88.jpg)
![Pin locker durability Empty](https://2img.net/i/empty.gif) | Subject: Re: Pin locker durability December 11th 2019, 11:45 am | |
| The way I locked my 820 is I used the fearless method, then meshed the teeth together and filled in all the teeth that don’t mesh with weld. That way if the pin breaks you still have the fozzy locker. I only did the fozzy on this because it has a diff carrier. You don’t wanna do it to an mst or 900 or something | |
![Pin locker durability Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | | Pin locker durability | |
| Who is online? | In total there are 137 users online :: 1 Registered, 0 Hidden and 136 Guests ranch king pro 08Most users ever online was 412 on January 7th 2023, 7:59 am |
