| Let's Talk! About anything. | |
+24Crazy_Carl loggers gogert diddie Mister_Studabaker Koltin Doug Hillbilly Offroading BlakeGroce Rerun muddstir fatboy_dan Tour1 Ashleigh90 TheCollector mrshaft696 prancstaman TheBeal RichieRichOverdrive AllisKidD21 mr.modified CraftsmanQuad19 Double W Cross Ranch Murraymountain MightyRaze 28 posters |
BlakeGroce Member
Murraymountain Veteran Member
Join date : 2019-02-04 Points : 4429 Posts : 2178 Location : North Carolina
| Subject: Re: Let's Talk! About anything. July 21st 2020, 3:42 pm | |
| - BlakeGroce wrote:
- Yall hear that Briggs and stratton filed for bankruptcy?
Yup. It's too bad. They were really the only good engine manufacturer left. | |
| Subject: Re: Let's Talk! About anything. July 21st 2020, 7:07 pm | |
| Everything is getting outsourced to the chonda engines. I see toros and such with no name Chinese engines. And these are riders. Let alone all the tillers, pressure washers, wood chippers, and generators that have been using Chinese engines for years | |
Koltin New Member
Age : 24 Join date : 2019-02-22 Points : 2117 Posts : 15 Location : Akershus County, Norway
| Subject: Re: Let's Talk! About anything. July 22nd 2020, 1:01 pm | |
| Chapter 11, apparently which means they can restructure IIRC. Chapter 7 means they are no longer a company IIRC. Pretty sad they went bankrupt. | |
BlakeGroce Member
Age : 21 Join date : 2019-06-02 Points : 2515 Posts : 469 Location : Richmond Ky
| Subject: Re: Let's Talk! About anything. July 23rd 2020, 5:56 pm | |
| Yeah...actually toro started manufacturing there own engines but I have no idea if they are clone or not. Dont look like a clone anyways. See alot more kohlers on zero turns than anything else but briggs have always dominated the riding mowers and push mowers.
Honestly I like the 6.5 vanguard the most out of any engine that's new. Way better than the hondas. | |
BlakeGroce Member
| Subject: Re: Let's Talk! About anything. July 25th 2020, 3:58 pm | |
| Anyone know where I can get a 9/16 id X 3/4 od x 5/8 bearing at? I've found koyo/torrington is the only company I can find that makes it but it seems to be obsolete from any bearing dealer. Numbers we've found so far have been a M-19101 and B-910 | |
Age : 20 Join date : 2017-06-09 Points : 5489 Posts : 2640 Location : Literally Nowhere, Texas
Age : 49 Join date : 2016-09-06 Points : 15661 Posts : 10980 Location : Oklahoma
| Subject: Re: Let's Talk! About anything. August 13th 2020, 5:56 pm | |
- When you can't afford a jeep.
Dude, that thing would sell for much more than a jeep around here. You can get an '87 Cherokee for like $500 up here. Everywhere you go there's one following you around. There like little fleas. My dad had a '98 2WD Cherokee in FL. We sold it before we moved because the trans went out. Now the Hummer's trans went out. I can't blame it. It's lasted 260K miles. | |
Age : 22 Join date : 2016-10-29 Points : 7212 Posts : 4014 Location : Lewisburg, KY
| Subject: Re: Let's Talk! About anything. August 14th 2020, 12:43 pm | |
| - BlakeGroce wrote:
- Anyone know where I can get a 9/16 id X 3/4 od x 5/8 bearing at? I've found koyo/torrington is the only company I can find that makes it but it seems to be obsolete from any bearing dealer. Numbers we've found so far have been a M-19101 and B-910
Anything with that thin of a cross section sounds like a needle bearing. Just keep checking for cross reference. Also have you checked McMaster or Grainger? | |
Tour1 Member
Join date : 2019-03-15 Points : 2192 Posts : 81 Location : Nassau and Sullivan counties, NY
| Subject: Re: Let's Talk! About anything. August 28th 2020, 10:57 pm | |
| McMaster's has these sleeve bearings listed but either 1/2" or 3/4" long: SAE 841 bronze bearings are porous and embedded with graphite for continuous lubrication. SAE 841 Bronze Bearings For 9/16" Shaft Dia. OD Length Lube Temp Range °F Part No. Price each 3/4" 1/2" 450 lbs. @ 60 rpm Embedded -50° to 700° 9368T169 $1.57 3/4" 3/4" 670 lbs. @ 60 rpm Embedded -50° to 700° 9368T171 2.00 SAE 660 Leaded Bronze Bearings For 9/16" Shaft Dia. OD Length Lube Temp Range °F Part No. Price each 3/4" 1/2" 1,100 lbs. @ 60 rpm Required -350° to 450° 6381K526 $5.59 3/4" 3/4" 1,650 lbs. @ 60 rpm Required -350° to 450° 6381K527 4.42 Meanwhile, this snake held up traffic on the boardwalk trail at Bushkill Falls, PA. It was about 2 feet long and the skinny part of its neck is about 1/2" diameter. What kind of snake is it? Is it dangerous? | |
BlakeGroce Member
| Subject: Re: Let's Talk! About anything. August 29th 2020, 10:27 pm | |
| Well I've just decided that the old one is good enough to reuse. It's just obsolete. Appreciate looking tho! | |
Koltin New Member
| Subject: Re: Let's Talk! About anything. September 5th 2020, 9:09 pm | |
My dad had a '98 2WD Cherokee in FL. We sold it before we moved because the trans went out. Now the Hummer's trans went out. I can't blame it. It's lasted 260K miles. Dirty Title though, totaled. Due to friggin dent. | |
| Subject: Re: Let's Talk! About anything. September 17th 2020, 3:44 pm | |
| I see you made me a Dimeweld, Mighty. Interesting, you might change that if you saw the welds i don't post.
Just saw you're from Norway, Koltin. Do you dislike the Finnish as much as every other Norwegian i know? | |
| Subject: Re: Let's Talk! About anything. September 17th 2020, 4:07 pm | |
| I just noticed that earlier today too. I'm a prybar or something? I'll accept that I guess. Prybar are good friends of mine... | |
BlakeGroce Member
| Subject: Re: Let's Talk! About anything. September 18th 2020, 6:25 pm | |
| Hahaha XD I'm alright with being a screwdriver! Not the best tool in the tool box but good for simple stuff. Anywards thought I'd give a little update on the garage in all its lime green glory! Thanks to my uncle for not being afraid of heights, unlike like myself, it now has a roof on it! | |
Koltin New Member
| Subject: Re: Let's Talk! About anything. September 19th 2020, 6:55 pm | |
- I see you made me a Dimeweld, Mighty. Interesting, you might change that if you saw the welds i don't post.
Just saw you're from Norway, Koltin. Do you dislike the Finnish as much as every other Norwegian i know? I don't hate Finns actually, they're good people. | |
TheBeal Veteran Member
Age : 30 Join date : 2013-06-06 Points : 5714 Posts : 1402 Location : Central PA
| Subject: Re: Let's Talk! About anything. September 19th 2020, 8:48 pm | |
| - Koltin wrote:
Just saw you're from Norway, Koltin. Do you dislike the Finnish as much as every other Norwegian i know? I don't hate Finns actually, they're good people. Interesting. My other friend said they have a big influence over Norway despite being like 2% of the population. Beal should just be burgermiester. Hmmmm....burgers. mmmmmmmmmm | |
loggers gogert Member
Age : 18 Join date : 2020-02-14 Points : 1958 Posts : 202 Location : U.S, virginia
| Subject: Re: Let's Talk! About anything. September 20th 2020, 4:58 pm | |
| - loggers gogert wrote:
- Finnaly got a welder
Nice! ARC, MIG, or TIG? I'm getting a Millermatic 211 in like a week or two. | |
