| | new storage shed build | |
yeethaw Member
Age : 18 Join date : 2019-04-23 Points : 2231 Posts : 182 Location : beecher il
| Subject: new storage shed build September 16th 2019, 9:35 pm | |
| so theres an old kids fort on our property that wasnt getting used so i decided to to take one of the railings off the side so i could park tractors under it my plans are to put pea gravel down for the floor and build it as cheaply as i can anyone have advice on the thinnest plywood i can use as im trying to do this cheap all we have around the house is 2x4 4x4 and deck boards | |
| Subject: Re: new storage shed build September 16th 2019, 9:51 pm | |
| Moved to "Off-Topic Project Builds"
Plywood would expand pretty quickly especially when it rains. Cheapest would be to tarp it. Unless you get a lot of wind then it may fray. Long term cheaper would to just buy metal siding. If wood, you will need to paint. Same with plywood. | |
| | | yeethaw Member
| Subject: Re: new storage shed build September 16th 2019, 10:02 pm | |
| prolly will just put some pallets on the ground and leave it the way it is we will end up moving within a few years and its concreted down so i dont want to put money into it but if i can find a buttload of pallets ill use the slats to enclose it | |
Age : 34 Join date : 2013-11-02 Points : 7130 Posts : 2907 Location : New Jersey USA
| Subject: Re: new storage shed build September 17th 2019, 9:54 am | |
| You can get plastic roofing pretty cheap in various lengths and colors. Lasts decent and it's light weight. That would be a nice weather proof way to do it. | |
Join date : 2015-02-02 Points : 5062 Posts : 1412 Location : Cleveland,Ohio
| Subject: Re: new storage shed build September 18th 2019, 9:59 pm | |
| I used fence planks from privacy fencing. $1.50 for a 6 foot long by 5 1/2 inch wide plank that is pressure treated. Fence it in should be good enough to keep the weather off your parts. Which leaves the roof. I'd say pallets would be good to use but frustrating to take apart and get anything usable because the wood used is the worst wood of anything used for pallets. | |
| | | Mtdmudmower Member
Age : 42 Join date : 2019-02-03 Points : 2135 Posts : 39 Location : West Salem, Ohio
| Subject: Re: new storage shed build September 18th 2019, 10:50 pm | |
| I just used an outdoor grade wood paneling that came pre primed on my shed. That was about 5 years ago and I still have yet to actually paint it cause it's not getting messed with by the rain or snow here. It was pretty cost effective to. | |
| Who is online? | In total there are 30 users online :: 0 Registered, 0 Hidden and 30 Guests
