Been a long time and kinda forgot about this place, I’m starting to assemble the tractor now. Got a test run in and I gotta tune the slide carb. It’s crazy looking back on this thread and seeing how far it’s come
Age : 49 Join date : 2016-09-06 Points : 15659 Posts : 10978 Location : Oklahoma
I'm going to guess that is not the battery location since it has no cables and the protector cap is still on. Hood's fine. Should he do a bumper and a winch it would be perfect.
Mightyraze is correct, I plan on a bumper and winch front and back on this rig. On the back im gonna add a bar to use to tow other machines and to lift and move stuff around around the house. The battery will be mounted between my legs and Im gonna attempt to put it inside of an ammo can
Common sense will tell you, it’s 1/4” by 3” flatstock for the extension, 1 piece on each side and each is 3ft long with 2ft of it welded to the stock frame and 1ft past it to make the extension. After doing this I braced it with 1/4” angle iron and some flatstock here and there. Axle mounts are also 1/4” angle iron but they’re boxed on the end. Now compare that to a stock craftsman frame made from thin sheet metal bent and bolted on the corners and tell me how weak this is. Also every inch of the frame from the front to back is braced with 1/4” flatstock or angle iron. Also the axle is the stock axle from a John Deere 165. I have way more faith in this than a stock craftsman axle and at some point it’s going to get other braced up or swapped for front suspension and a better steering system
Age : 21 Join date : 2020-12-23 Points : 2302 Posts : 785 Location : Roachdale IN
I was talking about the axle not the frame those spindles look like they are just gonna bend and fall apart at the slightest bump and the axle explode into peices. My stock craftsman gt axle exploded to peices when i dropped it out of the back of my truck
yeethaw Member
Age : 19 Join date : 2019-04-23 Points : 2262 Posts : 182 Location : beecher il
