| | Heavy Loads | |
Murraymountain Veteran Member
Join date : 2019-02-04 Points : 4397 Posts : 2177 Location : North Carolina
| Subject: Heavy Loads June 25th 2019, 9:54 pm | |
| So I'm pretty sure we all use our tractors for yard work and dragging trees around and whatnot, so I thought I'd put something out to brag about how much a load your tractor (or whatever it is) can take. The golf cart. And we wonder why it breaks... The JD. The load was so big I had to put a brick on it to keep it from falling out... | |
| | | AllisKidD21 Moderator
Age : 25 Join date : 2016-07-10 Points : 8553 Posts : 5190 Location : Ontario Canada
| Subject: Re: Heavy Loads June 25th 2019, 10:10 pm | |
| Neat thread idea! Not much for tongue weight with this one obviously, but here's my B-110 pulling a big gravity wagon: Got awfully bumpy once I hit the hay field I tell ya! This isn't anything crazy, but there was some weight there for sure: The GT has been on tie tugging duty a handful of times: Hmm, I don't really have any pictures of "heavy loads" I suppose. Gonna have to take some in the future so I can better contribute! I tell ya, if this was a "Ground Work and Towing Broken Tractors" thread I could really make hay in here! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Heavy Loads June 26th 2019, 9:20 am | |
| Hey, as long as it ain't an LT or GT, and it's an actual tractor that your towing, go for it. I probably should have said that you can put towing in here too as long as what's being towed is bigger than a GT. And no cars/trucks allowed. | |
| | | Double W Cross Ranch Veteran Member
Age : 20 Join date : 2017-06-09 Points : 5458 Posts : 2640 Location : Literally Nowhere, Texas
| Subject: Re: Heavy Loads June 26th 2019, 9:38 am | |
| Welp, I've only got a few pictures of the 110 doing road work, but before long, I can get a bunch of the 990 for sure. This is a little over half a ton of gravel, I was able to tow it at about 13 mph. Not super impressive, but I've hauled over a ton with it before, but I can't find any pictures. These are a little on the impressive side too. | |
| Subject: Re: Heavy Loads August 14th 2019, 12:29 pm | |
| Haven't done much with big loads lately, but just yesterday we took 4 350 lb loads of creek rock to fill in ruts in our drive way. Only problem was the 45 degree hills we had to take 'em up, so the stamped frame couldn't do it. Bailed out just in time to save the trans. Anyway, the EZGO ended up doing the job. We still have to take another 1200 lbs of rock up to finish the job. | |
| | | | yeethaw Member
Age : 18 Join date : 2019-04-23 Points : 2231 Posts : 182 Location : beecher il
| Subject: Re: Heavy Loads April 20th 2020, 9:46 pm | |
| When I was hauling cinderblocks and landscaping blocks with my craftsman And here’s when I pulled a trailer over filled with landscaping blocks behind the mtd I used to have [url=https://servimg.com/view/20075183/72] [/url The blocks probably weigh around 25 pounds each so I’m sure they were a bit overloaded | |
| | | | Sponsored content
| | | | | Heavy Loads | |
| Who is online? | In total there are 34 users online :: 0 Registered, 0 Hidden and 34 Guests
