| New tanny or no? | |
CityRedneck Member
Age : 28 Join date : 2011-08-13 Points : 5141 Posts : 241 Location : Winter Park
| Subject: New tanny or no? August 14th 2011, 2:00 am | |
| i have a craftsmanlt1000 with hydro trans. a while ago the wheels stopped turning but the axle would turn slow or if you jacked it up off the ground the wheels ould spin but if you touched them they slowed to a stop. any ideas? havnt cracked it open but im using this mower for deep water and need speed and power. should i just put a 820 peerless in it??? | |
Guest Guest
| Subject: New tanny or no? August 14th 2011, 1:05 pm | |
| could just be low on oil...could be a busted pump |
Ropertractor14 Member
Age : 110 Join date : 2010-02-23 Points : 5468 Posts : 84 Location : Nova Scotia, Canada
| Subject: Re: New tanny or no? August 14th 2011, 2:57 pm | |
| Belt worn out? When the wheels stop look and see if the fan/pulley on the top of the transmission is still spinning fast. If it is you have pump trouble. If it slows down considerably or stops the belt is slipping. | |
CityRedneck Member
noledroByrreK Member
Age : 30 Join date : 2011-01-14 Points : 5370 Posts : 252 Location : DFW Texas
| Subject: Re: New tanny or no? August 14th 2011, 11:09 pm | |
| hydro trannys are bad for speed. they like to blow lines and stuff because they cant handle the extra speed. i dont remeber exactly why cuz iv never had a hydro but im sure someone on here will explain it better for you.
redneckcarrow Member
Age : 54 Join date : 2010-12-22 Points : 5121 Posts : 30 Location : maine
| Subject: Re: New tanny or no? August 16th 2011, 8:12 pm | |
| if the aaxle is turning and not the wheel i would check the sguare key for the wheel | |
CityRedneck Member
| Subject: Re: New tanny or no? August 16th 2011, 8:13 pm | |
| im getting a 18hp 6sp peerless 820 tranny. is that good? | |
| Subject: Re: New tanny or no? August 16th 2011, 8:17 pm | |
| 820s are the ones with one inch axles. so yea prolly the toughest u can find. make sure ur rims arent for 5/8 or 3/4 what ever the smaller size axle that most other trannys are | |
| Subject: Re: New tanny or no? August 16th 2011, 8:27 pm | |
| and i agree with carrow sounds like ur just missing the axle key. if youve ever taken your tires on and off and didnt know they where there they would easly fall out and go in the grass or somethin | |
CityRedneck Member
| Subject: Re: New tanny or no? August 16th 2011, 9:52 pm | |
| i took them off and i looked for keys or anything but there wasnt any. theres not even holes for keys. im pretty sure lt1000 the same year as your has a 1nch | |
Trcustoms Member
Join date : 2010-09-19 Points : 5406 Posts : 225 Location : Bear,De USA
| Subject: Re: New tanny or no? August 16th 2011, 11:17 pm | |
| - CityRedneck wrote:
- i took them off and i looked for keys or anything but there wasnt any. theres not even holes for keys. im pretty sure lt1000 the same year as your has a 1nch
It won't be a hole, it will be a long slit down the axle shaft( i think it's about 1/4" wide). I've worked on many new and old craftsmands and they all have had them. Can you take pictures of the shaft? | |
CityRedneck Member
| Subject: Re: New tanny or no? August 17th 2011, 1:44 am | |
| sure ill jack it up tomorrow and take the tires off and take pics for ya | |
CityRedneck Member
Trcustoms Member
| Subject: Re: New tanny or no? August 17th 2011, 10:51 pm | |
- sure ill jack it up tomorrow and take the tires off and take pics for ya
Yeah.., I see the keyway clear as day. The keys are very easy to lose, I've done it lots of times. | |
Guest Guest
| Subject: New tanny or no? August 17th 2011, 11:04 pm | |
| sometimes they stick in the wheel, sometimes they squirt out when you put the wheel back on. usually the pop out the end and the wheel sticks half way on. easy to forget to put back in too |
CityRedneck Member
| Subject: Re: New tanny or no? August 17th 2011, 11:14 pm | |
| yea. im gonna buy some keys or something from a hardware store then swap transmissions from my 21hp 820peerless to the hydro that way i dont have to buy a new tranny | |
| Subject: Re: New tanny or no? August 18th 2011, 12:43 am | |
| ya the keyway is that grove down the axle. your rim will also have a keyway. you line up the 2 keyways and slide the rim on. thats keystock you just cut it to fit if u cant get precut pieces. normally come in one foot pieces but a hardware store or mower repair store will prolly have them the right size | |
CityRedneck Member
| Subject: Re: New tanny or no? August 18th 2011, 3:53 pm | |
| i got bored so i went out and took some pictures to better explain it for ya:) The groove down the middle is the keyway this is the key you put the key in the keyway There is also a keyway in the rim you line the two keyways up and slide the tire on Hope that helps:) | |
CityRedneck Member
| Subject: Re: New tanny or no? August 18th 2011, 4:40 pm | |
| haha thanks i think i remember taking the tires off to pump them up and not realizing that the keys are not attached haha. i was new to mowers at the time so :/ | |
| Subject: Re: New tanny or no? August 19th 2011, 10:23 am | |
| haha yea i did the same thing. made me look around in the grass for 30 min when i finally realized i needed em. and i figured with pics there no way you dont understand now. lol bit overkill i guess | |
CityRedneck Member
| Subject: Re: New tanny or no? August 19th 2011, 12:40 pm | |
| i went to ace and got the keys but i got 1 size to big because i was in a rush because once i get the keys ima go mudding for a while | |
