| AMF Rally mudder build 20hp vanguard, Locked ETC | |
+7CraftsmanQuad19 biggasmowers mr.modified MightyRaze AllisKidD21 Crazy_Carl Creepycrawler 11 posters |
| Subject: Re: AMF Rally mudder build 20hp vanguard, Locked ETC October 2nd 2019, 9:15 pm | |
| Thanks cq we are very excited
Thanks MM I debated long and hard on how I wanted to brace it up. I didn’t really want it to be noticed, and I didn’t want to go crazy, the factory frame was really close to being fine as is, it was the notch for the front tires that did it in. I also have some 3/4 x1/8 square tube I’m gonna use for cross braces, it should clear the belt about perfect as I have a inch between the belt and the frame as is. Should really help stiffen up the frame for years of use to come. I’m really missing having this thing around the house, it was pretty much my go too for any kind of Chore or running around. Hope to have the cross braces cut out and weld prepped by this weekend, maybe even tomorrow and possible have the front axle back under it next week, we will see though, still a lot of stuff going on and it’s hard to dedicate much time to this much as I want to | |
Age : 37 Join date : 2013-07-02 Points : 5015 Posts : 731 Location : Logan Ohio
| Subject: Re: AMF Rally mudder build 20hp vanguard, Locked ETC October 7th 2019, 12:00 am | |
| Worked on this a bit more tonight, got the front brace and the and the square tube braces done, I think I’m gonna run two pieces all the way across to brace up the floorboards also, I laid a piece across to show what I’m talking about. Hope to get this part of the bracing welded tomorrow, that way I can mock up the rest of it later this week. Managed to fit it in my vw golf, just barely | |
Age : 34 Join date : 2013-11-02 Points : 7165 Posts : 2910 Location : New Jersey USA
Age : 24 Join date : 2016-04-12 Points : 5977 Posts : 2645 Location : Indiana
redzz02 Site VIP
1st Place Build-Off 2015
1st Place Build-Off 2017
1st Place Build-Off 2018
Age : 30 Join date : 2010-05-12 Points : 6372 Posts : 899 Location : PA pittsburgh and pymatuning
Mister_Studabaker Member
Age : 56 Join date : 2019-03-15 Points : 2215 Posts : 118 Location : Grand Rapids, Mi.
| Subject: Re: AMF Rally mudder build 20hp vanguard, Locked ETC October 16th 2019, 12:12 pm | |
| Thanks guys, it’s mocked up at about 3.5 inches wider in the rear and about 4.5 wider up front. Front is still narrower than the rear. I’ll have to run a doc locker with a extended axle but I’ve wanted to do that for awhile anyways. Hoping to have this thing ready for haspin 2020. Got some other cool ideas I wanna do to it but we will see what actually gets done | |
diddie Member
Age : 57 Join date : 2016-10-02 Points : 3426 Posts : 411 Location : Indiana
| Subject: Re: AMF Rally mudder build 20hp vanguard, Locked ETC October 19th 2019, 6:58 pm | |
| yep yep it had some issues, think carb related, it would idle perfectly all day but loaded up bad above idle and would clean out sometimes and really scream but half the time it acted like it was running on one cylinder. either way I put it back together with a governer and for the tractors new intended use I think I wanna go single cylinder no governer, so Ill be bringing the motor in to clean up and pull the governerer out at some point once I get the frame patched back up. | |
| Subject: Re: AMF Rally mudder build 20hp vanguard, Locked ETC October 19th 2019, 7:49 pm | |
| I came into a weird engine awhile ago, its a 14 hp vanguard single ohv. Its full pressure lube, cant find much on it but it looks built like a tank, so Im gonna give it a go, plan is governer delete, 400ex carb that I have laying around from a atv project thats long ago sold, mild port job and either shave the head or hoping to lap the head to block and just run shellac or some other thin gasket maker, if if remember right Mr.Modified did that to the Gtr4 | |
| Subject: Re: AMF Rally mudder build 20hp vanguard, Locked ETC October 24th 2019, 11:54 pm | |
| Made a bit more super slow progress, made this bracket to hold the front side of the bolt, pretty happy with it if I do say so myself
Also made a couple braces to help tie the front all together and serve as bumper mounts But the pic thing is being stupid I’ll try later | |
