 Appropriate mower for build?
5 posters
zlkahn1
Appropriate mower for build? Empty
PostSubject: Appropriate mower for build?   Appropriate mower for build? Icon_minitimeSeptember 15th 2018, 1:53 pm
Hello all,
I am new to this forum and to modifying mowers. Right now I am looking at a John Deere l100 with a 6speed and a 15 HP Briggs and Stratton 1 Cylinder. Does anyone know if this would be an acceptable mower to do a pulley swap and mild modifications to? I am not looking for extreme speed. maybe 20-30MPH. Also is the one cylinder a problem? Any guidance would be much appreciated. Also, if you have any other good suggestions that would be better for builds like this feel free to let me know.
Thanks.
Last edited by zlkahn1 on September 15th 2018, 2:21 pm; edited 2 times in total (Reason for editing : Spelling Error)
PostSubject: Re: Appropriate mower for build?   Appropriate mower for build? Icon_minitimeSeptember 15th 2018, 2:24 pm
I have an LT160. It's a body on a c channel type frame.  It's very strong, but IDK about the L100.  That might be a pan frame that's more susceptible to twist.  I think you have a spicer rear end so I would take it easy with it and not lock it.  The 15hp OHV briggs single should have enough power to start with and is easy to work on.  Sounds like you have a good basis for a beginner project.
zlkahn1
PostSubject: Re: Appropriate mower for build?   Appropriate mower for build? Icon_minitimeSeptember 15th 2018, 2:27 pm
Thank you for the information. How would I confirm what frame and rear and I have? Also, what is the concnsus on using old sears mowers, in terms of streangth?
PostSubject: Re: Appropriate mower for build?   Appropriate mower for build? Icon_minitimeSeptember 15th 2018, 4:49 pm
Old sears tractors are some of the coolest and strongest around.
I personally stay as far away from John Deere as I can. Very complicated in my experience and all the ones I’ve seen have a spicer (light duty) rear end.
Most guys start with what they can find, but I would try and keep an eye out for an 80s or 90s craftsman with a gear driven transmission. That could be a square body, or what I call the slant hood (my next project actually), or have a plastic front grill with steel hood (most common)
Craftsmen are made by AYP, which is husqavarna. Identical tractors with a different sticker that I’ve seen are poulan, weedeater, husqavarna, rally, meijer (only ever seen one but they exist apparently), wizard (Maine mud mower’s current project), and others I’m sure. These are the most common and strongest LT frames to work with so if you can afford to be picky at all, hold out for one of these. You can take it so much farther and I’m speaking from experience
Try and stay away from anything with a hydro or a stamped frame
zlkahn1
PostSubject: Re: Appropriate mower for build?   Appropriate mower for build? Icon_minitimeSeptember 15th 2018, 5:06 pm
Thank you for the info, I will look into some of those. I also saw a ‘96 white MTD with a 15.5hp and a 6speed, is it any good?
PostSubject: Re: Appropriate mower for build?   Appropriate mower for build? Icon_minitimeSeptember 15th 2018, 5:26 pm
I stay away from JD and even farther from MTD. That actually has a single speed rear end with a variable pulley like a cvt. Which sounds cool but it’s really finicky and prone to failure. Also the frames are really light duty, as are the front spindles. The only reason I would bring home an mtd is for a running engine. The rest is scrap
zlkahn1
PostSubject: Re: Appropriate mower for build?   Appropriate mower for build? Icon_minitimeSeptember 15th 2018, 5:47 pm
Haha, again, thank you for the info. I will probably go with the 12hp I found.
PostSubject: Re: Appropriate mower for build?   Appropriate mower for build? Icon_minitimeSeptember 15th 2018, 6:17 pm
Briggs Flathead I assume? Those are all I ran for a while because they were cheap, reliable, and good on gas. 12 horsepower is plenty for just general off-roading, but it’s gonna struggle in the deep stuff
PostSubject: Re: Appropriate mower for build?   Appropriate mower for build? Icon_minitimeSeptember 15th 2018, 8:53 pm
First off, welcome to the forum!  cheers As far as the tractor, it depends what kinda riding you plan to do with it. For just kinda generally bombing around and some mild off-road most tractors will do just fine. For stuff like crawling and harsh trails though, you'd most likely want something with a decent frame, steering, front axle, etc.
If you really enjoy custom fab work and modifying stuff, you can start with with a weaker tractor and build it up to be more capable and handle some hardcore off-road situations. Most people prefer to start with a good base and work with it though, makes good sense, but it's all personal preference I suppose.
PostSubject: Re: Appropriate mower for build?   Appropriate mower for build? Icon_minitimeSeptember 15th 2018, 10:13 pm
Late to the party... but Welcome!
Appropriate mower for build? Sig115PROJECTS:
Appropriate mower for build? Sig214Appropriate mower for build? Sig314
zlkahn1
PostSubject: Re: Appropriate mower for build?   Appropriate mower for build? Icon_minitimeSeptember 16th 2018, 12:15 am
Thank you, I plan on just messing around, nothing serious. I also do not have a desire to do serious fab work.
» future build off mower project build ( unique build )
» I have atv and mower what should I build
» Ice Mower Build
» Mud mower build question?
» Mud mower build
