 Grinding Noise?
5 posters
rockinromac1
Grinding Noise? Empty
PostSubject: Grinding Noise?   Grinding Noise? Icon_minitimeJuly 31st 2018, 11:01 pm
When I go to start my mower it now makes a grinding noise until you release the key. I does not seem to be getting stuck. I gave it some WD-40 a week ago but it has not helped. Any suggestions?
http://rockinromac.com
PostSubject: Re: Grinding Noise?   Grinding Noise? Icon_minitimeAugust 1st 2018, 9:50 am
Where's the the noise coming from? the starter?
PostSubject: Re: Grinding Noise?   Grinding Noise? Icon_minitimeAugust 1st 2018, 11:07 am
If you don't know what is making the noise pull the cover off the starter and watch the engagement. Sometimes when you crank the engine the pulley turns the belts and they can make funky sounds depending on what they are connected to.
Is the starter frozen & not spinning? Smack it with a hammer (lightly), or is your battery dead/weak?
darkside0914
darkside0914
2020 Build-Off Top 3 Winner
PostSubject: Re: Grinding Noise?   Grinding Noise? Icon_minitimeAugust 3rd 2018, 9:42 pm
I had a similar problem, my yard mower started grinding when I cranked it, I found one of the starter bolts had come out and the other had come loose enough that it wasn't engaging the flywheel properly, not saying that's your problem just what I've experienced in a similar situation
PostSubject: Re: Grinding Noise?   Grinding Noise? Icon_minitimeAugust 4th 2018, 9:33 pm
Maybe your starter gear is stripped?
Grinding Noise?
» How do I quiet down my hood and hold in place
» Transaxle noise
» spicer rear end ticking noise: Mean Rabbit build
» Peerless MST206-545C Noise
» 11 HP Briggs & Stratton noise reduction
All-Terrain Lawn Tractor Forum :: Technical Forum :: Electrical Related Issues :: Starting and Soleniods-
