| GasketCase's SEARS Swamper LT [2018 Build-Off Entry] | |
+8Double W Cross Ranch biggasmowers MatthewD mrshaft696 MightyRaze CraftsmanQuad19 AllisKidD21 GasketCase 12 posters |
GasketCase Member
Age : 29 Join date : 2018-03-26 Points : 2588 Posts : 145 Location : Spring Hill, FL
| Subject: GasketCase's SEARS Swamper LT [2018 Build-Off Entry] May 14th 2018, 7:26 pm | |
| I've decided to enter my 1973-1974 (<--I believe) Sears LT 10 My current ideas/plans for the SEARS Swamper * wire wheel the entire body until I achieve a desired look then clear coat to preserve. * Create a new wiring harness * Install gauge cluster ( amps & voltage ) * Install safety tether * Fabricate a new steering design * Replace and Relocate small fuel tank to large fuel tank * Install the B&S 18 HP twin oppy * Drain, Clean, and Lock then 600 series transaxle. * Paint specific Components to Stand out * Possibly add a separate vacuum fuel pump . (Heard that oppys stock pump can dump into crankcase.) * Find larger and more aggressive for front and rear. For the meantime, i may cut the rear tires since front are already cut. * Install 8" Led bar and incorporate it into the grill. Pretty decent list to start with . I guarantee I'll have more ideas like we always do lol *Accepted MightyRaze 6/6/2018--------------Merged with previous thread--------------------I Haven't posted in awhile , but I recently aquired a sears LT 10/36 from what the hood says. The Model number 536.255212 and the code number was a little difficult to read but I think it said 8118 . (After I wrote down the numbers, I proceeded to wipe the dirt off the label and ended up wiping it all away with just my hand ! ) I can't seem to find a any good information on it for identifying what date it was made. Tractordata.Com states it as a 1974 to 1975. since that's the only years they provide on tractordata. Here's a couple of pictures. By the way, I removed what I believe is a tecumseh engine but I could be wrong . I couldn't find any ID numbers on engine either. So, for anyone that knows or could help me I.D this awesome looking tractor and also Id like to see everybody's opinion if I should lower it and go with maybe a rat rod look? Or go ahead and lift it up and use it for a offroader. Let me know what you guys think (I'm always open to ideas) and if anyone has any info on this , it would be greatly appreciated | |
Age : 25 Join date : 2016-07-10 Points : 8583 Posts : 5190 Location : Ontario Canada
| Subject: Re: GasketCase's SEARS Swamper LT [2018 Build-Off Entry] May 14th 2018, 7:32 pm | |
| That's a sweet looking little tractor! I couldn't tell ya the year or anything but it definitely appears to have a Peerless 600 transaxle. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Crazy_Carl Veteran Member
Age : 35 Join date : 2017-10-30 Points : 5329 Posts : 2561 Location : Rochester, New York
Age : 24 Join date : 2016-04-12 Points : 5977 Posts : 2645 Location : Indiana
GasketCase Member
| Subject: Re: GasketCase's SEARS Swamper LT [2018 Build-Off Entry] May 14th 2018, 9:16 pm | |
| The Transaxle is indeed a peerless 600 3 spd w/ reverse. I'll have to get a picture in the morning of the engine. I found the ignition / pick up coil to be mounted under the flywheel . I found one of the magnets to have separated from inside flywheel. So I saw original location and glued it back in its spot. The engine has compression, so I'm assuming the magnet dislodging was the issue . I have not tried to start it yet . It also has a adjustable main jet on bottom of carburetor bowl with a screw . Looks pretty neat but when I looked inside the bowl it wasnt too pretty. Rusty float pin , so I can't remove float without breaking it. | |
GasketCase Member
| Subject: Re: GasketCase's SEARS Swamper LT [2018 Build-Off Entry] May 14th 2018, 9:21 pm | |
| Ooh, an opposed would be neat for sure! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
GasketCase Member
| Subject: Re: GasketCase's SEARS Swamper LT [2018 Build-Off Entry] May 14th 2018, 9:30 pm | |
| It's on my MTD yard machine but Im tempted to just see what the oppy could do on a smaller tractor . I need to do the separate fuel pump on the oppy though. I have a brand new one ready to throw on it. Just been spending majority of the time on the 6 wheel mower. So what would you guys do in reference to chassis build. Should I make it a race/speed mower or off road it? It had a pretty strong frame but Idk if the short wheelbase will have a negative effect on offroad . Unless I widen the front axle and throw the wide tires I have on the rear. | |
GasketCase Member
| Subject: Re: GasketCase's SEARS Swamper LT [2018 Build-Off Entry] May 15th 2018, 8:31 pm | |
| - MightyRaze wrote:
- Will it fit??? LOL
I Will make it fit , my good sir ! Haha Also here's some pictures of what engine was on it, when I aquire it. Don't want to state it as the original because Im not sure . The block is about half the size of a 12 hp flattie block . | |
GasketCase Member
GasketCase Member
mrshaft696 Established Member
Join date : 2016-07-10 Points : 4055 Posts : 870 Location : Phillydelphia
MatthewD Veteran Member
Age : 23 Join date : 2014-11-16 Points : 5749 Posts : 1993 Location : Northern Ireland
GasketCase Member
| Subject: Re: GasketCase's SEARS Swamper LT [2018 Build-Off Entry] May 16th 2018, 8:00 am | |
| @mrshaft696 thank you for your advice haha. I was going to just throw it out cause it seems to be losing compression through exhaust. Further, found out that the exhaust valve must of been open all this time and made it have a rusty exhaust valve seat. And also it has 4 bolt holes where I would assumed a starter would go. Do you have any opinions on customizing it for street or offroad? The cutting deck was rotted beyond belief, so no chance of restoring it . @MatthewD thank you for your input . Your the first one that has noticed my question for every bodies advice haha | |
| Subject: Re: GasketCase's SEARS Swamper LT [2018 Build-Off Entry] May 16th 2018, 8:48 am | |
| - MatthewD wrote:
- I think these tractors look best with minimal mods tbh. Does the opposed fit without cutting the hood? I'd try to avoid cutting up that lovely hood.
I bet it will fit, but the factory exhaust will stick out the front, so it would have to be changed.... | |
GasketCase Member
| Subject: Re: GasketCase's SEARS Swamper LT [2018 Build-Off Entry] May 16th 2018, 11:38 am | |
| Hmm the biggest tires I have are 23x9.50x12 but the rims are for 1 inch axles instead of 3/4 . So I guess I'll have to go with the 22x10x8 I have on my craftsman. And I'll steal the front rims while I'm at it. This was my first build , I never finished cutting the tires and rubber cementing the pieces back on for more tread depth. (takes forever even with harbor freight multi tool) . Fronts are finished though. | |
GasketCase Member
| Subject: Re: GasketCase's SEARS Swamper LT [2018 Build-Off Entry] May 16th 2018, 11:45 am | |
| Now on the engine fitment. I'm pretty sure from just looking at it by eye , it will fit but @mrshaft696 is right with the exhaust. Good thing I have extra pipe laying around to build a nice dual exhaust or maybe a 2 to 1 depending if I like the sound of the dual or not. | |
biggasmowers Veteran Member
Age : 24 Join date : 2016-12-30 Points : 4926 Posts : 1944 Location : Kansas
| Subject: Re: GasketCase's SEARS Swamper LT [2018 Build-Off Entry] May 16th 2018, 2:05 pm | |
| I agree with mrshaft, I had one of these little Tecumseh 10hps and the timing was impossible to set. Had a strong spark but no matter how I set the points it would only backfire or not fire at all, then I tried a nova point replacer module and that didn't help anything either. An oppy would make this a sweet little death trap . | |
GasketCase Member
| Subject: Re: GasketCase's SEARS Swamper LT [2018 Build-Off Entry] May 16th 2018, 3:12 pm | |
| @Biggs mowers now that you said death trap I'm totally set on the oppy being put on the sears now. Lol . I greatly appreciate the advice everyone , I shall use the tecumseh as my new boat anchor this upcoming scallop season lol Since Ive already made this thread for info , I suppose I should use it for a build thread for it too . I wouldn't want to make two threads with the sears. | |
Age : 20 Join date : 2017-06-09 Points : 5488 Posts : 2640 Location : Literally Nowhere, Texas
| Subject: Re: GasketCase's SEARS Swamper LT [2018 Build-Off Entry] May 16th 2018, 3:25 pm | |
| - GasketCase wrote:
- I greatly appreciate the advice everyone , I shall use the tecumseh as my new boat anchor this upcoming scallop season lol
LOL I love that! Yeah I've been saying forever that Tecumsehs are crap, I remember one guy who had great compression, spark, and starter fluid sprayed into the spark plug hole, and it still wouldn't fire. | |
