| MrShaft696 Tractor buying Sellin Mowing....Projects | |
+13diddie Murraymountain prancstaman Crazy_Carl mrshaft696 RichieRichOverdrive MightyRaze biggasmowers CraftsmanQuad19 MatthewD Buck AllisKidD21 Double W Cross Ranch 17 posters |
mrshaft696 Established Member
Age : 25 Join date : 2016-07-10 Points : 8553 Posts : 5190 Location : Ontario Canada
| Subject: Re: MrShaft696 Tractor buying Sellin Mowing....Projects June 12th 2018, 9:11 pm | |
| Sweet K Series! How many horsepower is it? "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Join date : 2016-07-10 Points : 4025 Posts : 870 Location : Phillydelphia
| Subject: Re: MrShaft696 Tractor buying Sellin Mowing....Projects June 12th 2018, 9:14 pm | |
| Been working on this one for about a month or so, couldn't get it to run right, then I soaked the carb for a few days in a magic brew of paint thinner, sea foam & carb cleaner, it opened up and started to run right... I put tubes in the tires, new ignition, battery, valve cover gasket, and oil, now it seems to be running cutting ok.... It is too small for my yard, but i like the deck control lever it is pretty sweet.... gonna try and sell it for 350? something like that.... | |
| Subject: Re: MrShaft696 Tractor buying Sellin Mowing....Projects June 12th 2018, 9:16 pm | |
| Ah, K321. Nice! They're great engines. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Crazy_Carl Veteran Member
Age : 35 Join date : 2017-10-30 Points : 5299 Posts : 2561 Location : Rochester, New York
| Subject: Re: MrShaft696 Tractor buying Sellin Mowing....Projects June 13th 2018, 7:07 am | |
| - Crazy_Carl wrote:
- $350 seems fair. Does it have just a 38" deck. Does that JD have the pto lever on the dash? I thought I saw a PTO switch on the right fender but I could be mistaken.
Its a STX38, so 38 in deck with a hood from a 30. PTO & ignition on the fender. I see people asking good money for john deere stuff. | |
| Subject: Re: MrShaft696 Tractor buying Sellin Mowing....Projects June 14th 2018, 9:15 pm | |
| I done it again.... got a free bolens thing, the deck has a broken weld on a bracket but I think it is fixable. I drove it, has a 15hp, the MTD trans is stupid in my opinion since you have to put it in a fwd N or rev , clutch and then pick a gear, but whatever. Probably just fix the deck and sell or get a trailer for it and sell.... | |
| Subject: Re: MrShaft696 Tractor buying Sellin Mowing....Projects June 15th 2018, 9:44 am | |
| - Crazy_Carl wrote:
- Yeah this looks like a good one to flip. Did it come with the WD 40 can? My ATC200 came with that in the trunk!
Yeah came with the WD and a free dog leash holding up the mowing deck. Still best free item I got was the mouse that was in my simplicity haha. Seems like this model of MTD kind of sucks, its made real cheap, originally sold by lowes. Im considering keeping the engine but I need the cash. | |
MatthewD Veteran Member
Age : 23 Join date : 2014-11-16 Points : 5719 Posts : 1993 Location : Northern Ireland
| Subject: Re: MrShaft696 Tractor buying Sellin Mowing....Projects June 15th 2018, 11:01 am | |
| Cool looking mower, I like the hood on it. Free is always best. Had one of those Intek single cyl. engines in for servicing recently, they seem quite good engines, even if they are a little more complicated that the older flatheads. | |
Age : 24 Join date : 2016-04-12 Points : 5938 Posts : 2636 Location : Indiana
| Subject: Re: MrShaft696 Tractor buying Sellin Mowing....Projects June 20th 2018, 9:31 am | |
| - CraftsmanQuad19 wrote:
- The numbers should be stamped into the top of the valve cover
Ok ill check that out, these engines are pretty ugly and cheap ass looking with the corny looking vacuum cleaner compartment air cleaner thing, but the 15hp I have runs, this 12.5 is to be determined. I might use this one to drive thru the woods & bang into trees. The bolens mower is the dumbest mower I have ever used, It will not start unless you are sitting in the seat, and you have to turn the key and press a button to mow in reverse. | |
Age : 20 Join date : 2017-06-09 Points : 5458 Posts : 2640 Location : Literally Nowhere, Texas
| Subject: Re: MrShaft696 Tractor buying Sellin Mowing....Projects June 24th 2018, 9:17 pm | |
- Sharp eye, I missed that
haha yes both tractors have non original engines..... no idea how it happened, so whatever... will try to start the opposed this week and see what happens..... I got it on this weekend with this MTD junk pile...... tractor is a pile of junk but it runs good so i need to find some atv tires for it..... | |
| Subject: Re: MrShaft696 Tractor buying Sellin Mowing....Projects June 25th 2018, 7:57 am | |
- That’s a pretty sweet picture man! Those MTDs are not very good tractors, but with a lot of patience and angle iron they can be ok
yeah the whole double belt transaxle varidrive is stupid in my opinion & this one makes some stupid noises when you come to a quick stop, like belt or pulley slapping like that.... Anyway im just gonna use it to beat around the yard & woods. | |
