 73 sears workhorse/mudder
Dr Bob
Rustbucket Garage
Hillbilly Offroading
mowerjunkie03
19 posters
73 sears workhorse/mudder  - Page 3 Empty
PostSubject: Re: 73 sears workhorse/mudder    73 sears workhorse/mudder  - Page 3 Icon_minitimeWed Mar 21, 2018 12:04 pm
is that a newer sears blade? that's a clean looking grill, this blade is only temp , the front is wore out
PostSubject: Re: 73 sears workhorse/mudder    73 sears workhorse/mudder  - Page 3 Icon_minitimeWed Mar 21, 2018 12:10 pm
MightyRaze wrote:
Buck Mault wrote:
When I got Frankin Sears a blade came with it, no mounts, and in great shape just like the tractor lol, i build a mount for it, made it so it can hook into the factory rear deck mount.
i dont have a winch yet so its a strong arm lift. and its a workout.
Sears blade is a arm workout too.  Bottom 1/4 flat stock is a necessary upgrade should you find one.  Yours may be sturdier.
73 sears workhorse/mudder  - Page 3 20151010
73 sears workhorse/mudder  - Page 3 20151011
How many tractors do you have?
PostSubject: Re: 73 sears workhorse/mudder    73 sears workhorse/mudder  - Page 3 Icon_minitimeWed Mar 21, 2018 12:48 pm
Buck Mault:
There is the one I have, snow/dozer.  Then there is the other one that looks like
73 sears workhorse/mudder  - Page 3 Post-66772-0-35804800-1426427796
This was just after I cleaned and repainted mine a couple years ago.
Grill, yeah I had to do some work the bottom was busted off,  I still had the busted piece, I mounted a steel brace  in there, screwed it together then hid it with bondo.  LOL  :-)
How many tractors? Double W...
2 Sears Suburbans  75(pictured), 77
4 Sears Craftsmans  74, 90, 94(AWS), 2006
2 Murrays 82(buildoff), 89
1 Troybuilt  can't recall year.
HAHA!
73 sears workhorse/mudder  - Page 3 Sig115PROJECTS:
73 sears workhorse/mudder  - Page 3 Sig21473 sears workhorse/mudder  - Page 3 Sig314
PostSubject: Re: 73 sears workhorse/mudder    73 sears workhorse/mudder  - Page 3 Icon_minitimeWed Mar 21, 2018 12:53 pm
MightyRaze wrote:
Buck Mault:
HAHA!
that is exactly what im looking for.
really that's the only major thing sears/roper did wrong was the grill
PostSubject: Re: 73 sears workhorse/mudder    73 sears workhorse/mudder  - Page 3 Icon_minitimeWed Mar 21, 2018 12:57 pm
There is a Roper one that is Cast Aluminum I think instead of fiberglass.
PostSubject: Re: 73 sears workhorse/mudder    73 sears workhorse/mudder  - Page 3 Icon_minitimeWed Mar 21, 2018 1:00 pm
@MightyRaze oh Ill have to look into that I know they had the sh*t fiberglass ones to
PostSubject: Re: 73 sears workhorse/mudder    73 sears workhorse/mudder  - Page 3 Icon_minitimeWed Mar 21, 2018 2:01 pm
I see my wheel horse dozer blade is not the only design out there that can be mechanically angled side to side. I'll give you sears guys a point for that lol.
@Buck Mault Nothing wrong with a good arm workout. It will turn you into popeye lol. Looks like you mimicked the way a wheel horse dozer blade connects all the way back to the transaxle. It's a strong design. I'm glad you went that route. The only thing I would add is some gussets where the original plow frame meets that beautiful frame you built so the original mount can't bend either to the left or to the right.
PostSubject: Re: 73 sears workhorse/mudder    73 sears workhorse/mudder  - Page 3 Icon_minitimeWed Mar 21, 2018 3:03 pm
@Crazy_Carl lol it only works out one arm, thanks, it was a hasty build i didnt want to shovel snow, the amount of time i put in that thing i could have shoved the snow muli times and drank beer after. it does swivel left to right i just need to rebuild it
PostSubject: Re: 73 sears workhorse/mudder    73 sears workhorse/mudder  - Page 3 Icon_minitimeSun Mar 25, 2018 1:34 pm
I was using the Tractor around the yard yesterday cleaning up trees and noticed a vibration coming from the engine it was shacking the whole tractor. tighten up the motor mounts but didn't help. i figures the governor let go because it wasent working right before. so I pulled the engine 73 sears workhorse/mudder  - Page 3 20180335
73 sears workhorse/mudder  - Page 3 20180336
73 sears workhorse/mudder  - Page 3 20180337
73 sears workhorse/mudder  - Page 3 20180338
everything is tight, valves are out a bit and the head gasket was leaking. then i busted off a head bolt 73 sears workhorse/mudder  - Page 3 2429134702
PostSubject: Re: 73 sears workhorse/mudder    73 sears workhorse/mudder  - Page 3 Icon_minitimeSun Mar 25, 2018 1:39 pm
might aswell pull the starter apart and clean it up
PostSubject: Re: 73 sears workhorse/mudder    73 sears workhorse/mudder  - Page 3 Icon_minitimeSun Mar 25, 2018 1:55 pm
good luck getting that both out. Those are a ton of fun. Look at the tapered roller bearing on the crankshaft, never seen that before in a motor.
PostSubject: Re: 73 sears workhorse/mudder    73 sears workhorse/mudder  - Page 3 Icon_minitimeSun Mar 25, 2018 2:25 pm
It's super easy, just use a bolt extractor set. I've done that before, took 10 minutes to fix it.
PostSubject: Re: 73 sears workhorse/mudder    73 sears workhorse/mudder  - Page 3 Icon_minitimeSun Mar 25, 2018 2:47 pm
@Double W Cross Ranch i never had luck with them ill give it a try or just drill it out and keen cert it or he'll coil , i might drill into it and then weld a nut on.
PostSubject: Re: 73 sears workhorse/mudder    73 sears workhorse/mudder  - Page 3 Icon_minitimeSun Mar 25, 2018 3:12 pm
Id weld a washer down first, if you have a thick one, you should be able to get some nice hot welds then weld a nut to the washer. Just dont stick it to the block. 73 sears workhorse/mudder  - Page 3 2664539216
The Tec on my st10 shakes the whole tractor at full rpms. Its pretty intense, but bump it down a little bit its not bad
PostSubject: Re: 73 sears workhorse/mudder    73 sears workhorse/mudder  - Page 3 Icon_minitimeSun Mar 25, 2018 3:22 pm
@TheBeal thats a good idea thanks, but i still cant figure out why i had all that Vibration
PostSubject: Re: 73 sears workhorse/mudder    73 sears workhorse/mudder  - Page 3 Icon_minitimeSun Mar 25, 2018 3:27 pm
Sure thing. Ide probably whack it with a hammer after welding the washer on, and again when the nut is welded on. If you can turn it, might be good to work it back and forth a bit with some liquid wrench.
PostSubject: Re: 73 sears workhorse/mudder    73 sears workhorse/mudder  - Page 3 Icon_minitimeSun Mar 25, 2018 6:16 pm
How is your clutch/pulley? Looks like you got some good mud there. You don't have a bearing going out in the clutch causing it to bounce the belt?
PostSubject: Re: 73 sears workhorse/mudder    73 sears workhorse/mudder  - Page 3 Icon_minitimeSun Mar 25, 2018 6:20 pm
I'll check that out the belt bounces alittle.
PostSubject: Re: 73 sears workhorse/mudder    73 sears workhorse/mudder  - Page 3 Icon_minitimeSun Mar 25, 2018 8:27 pm
prancstaman wrote:
MightyRaze wrote:
Does an old Tecumseh have a compression release of sorts?
On the vertical shaft engines, that have the oil pump driven off the cam. When the engine is not running and no oil pressure, that is when the compression release is on. It is on the cam exhaust lobe. The cam is hollow and a pathway for the oil to the whole engine. When the engine is cranking to start, it dumps compression out the exhaust a few revolutions, enough to get the engine spinning and to fire. when the engine fires, usually when the oil pressure is at max, the easy start rod on the cam lobe disengages and you get full compression. If the engine doesn't fire or start then the easy start won't disengage. The oil pump will only supply enough oil to disengage it when running.
On a horizontal shaft Tecumseh, IDK if it has this setup or a different kind of setup. But does need the rpm of engine running to disengage it, and cranking rpm usually isn't fast enough.
here is the mechanical compression release (MCR) spring loaded and the released by centrifugal force73 sears workhorse/mudder  - Page 3 20180339
73 sears workhorse/mudder  - Page 3 20180340
something got lodged in there
PostSubject: Re: 73 sears workhorse/mudder    73 sears workhorse/mudder  - Page 3 Icon_minitimeSun Mar 25, 2018 8:31 pm
yeah bad scratches, I wonder if the previous owner rain it without an air cleaner, I'd get her bored
PostSubject: Re: 73 sears workhorse/mudder    73 sears workhorse/mudder  - Page 3 Icon_minitimeSun Mar 25, 2018 8:33 pm
That sucks about the cylinder wall. That compression release looks quite a bit like the ACR Kohler had, pretty simple system really haha.
PostSubject: Re: 73 sears workhorse/mudder    73 sears workhorse/mudder  - Page 3 Icon_minitimeSun Mar 25, 2018 8:36 pm
I've seen this happen when guys shove sh*t down there so they can lock it up to pull the flywheel
That release is gone now same as the governor.
PostSubject: Re: 73 sears workhorse/mudder    73 sears workhorse/mudder  - Page 3 Icon_minitimeFri Mar 30, 2018 7:48 pm
not much done, just cleaned it up and starting to go back together
73 sears workhorse/mudder  - Page 3 20180343
73 sears workhorse/mudder  - Page 3 20180344
73 sears workhorse/mudder  - Page 3 20180345
PostSubject: Re: 73 sears workhorse/mudder    73 sears workhorse/mudder  - Page 3 Icon_minitimeFri Mar 30, 2018 9:54 pm
I'm not much of an engine guy other than add fuel vapor, air and spark and watch the boom, but I wonder if rehoning would help that scratch?
PostSubject: Re: 73 sears workhorse/mudder    73 sears workhorse/mudder  - Page 3 Icon_minitimeFri Mar 30, 2018 11:25 pm
Best you could do with a hone would be to just break the glaze off of the bore. Not much you could do otherwise, unless you wanted to go with an oversize piston
PostSubject: Re: 73 sears workhorse/mudder    73 sears workhorse/mudder  - Page 3 Icon_minitimeSat Mar 31, 2018 5:10 am
ya for now I'm going to run it , the engine 45 years old lol. but once i find a kit i will be rebuilding it
Page 3 of 8Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
» Sears trail/mudder named Grace
» Ford YT18h WorkHorse
» Murray Monster Mudder
» 1978 Cub Cadet 1450 Workhorse
» 1969 Wheel Horse 700 WORKHORSE
