| 73 sears workhorse/mudder | |
+15Dr Bob Rustbucket Garage Hillbilly Offroading mowerjunkie03 MatthewD mr.modified CraftsmanQuad19 RichieRichOverdrive TheBeal prancstaman Double W Cross Ranch Crazy_Carl MightyRaze AllisKidD21 Buck 19 posters |
Buck Member
| Subject: Re: 73 sears workhorse/mudder July 23rd 2018, 5:26 am | |
| and its hidden, once I pull the tractor apart to paint it I'll have to clean up the wiring, I'm not a fan of having a bunch of wires running to the battery ( maybe a junction box/block for power and same for ground side ) | |
Crazy_Carl Veteran Member
Age : 35 Join date : 2017-10-30 Points : 5335 Posts : 2561 Location : Rochester, New York
| Subject: Re: 73 sears workhorse/mudder July 23rd 2018, 8:17 pm | |
| Nice that the boost setup that tow trucks have.
I'd keep the main connections right on the battery. Less connections to fail. You could put in a fuse block for your smaller loads to neaten things up. | |
Buck Member
Join date : 2017-11-01 Points : 2884 Posts : 282 Location : Eastern Ontario
| Subject: Re: 73 sears workhorse/mudder July 23rd 2018, 9:30 pm | |
| @Crazy_Carl , yes exactly I do have it wired straight to the battery, a fuse box would work. I'm running 2 breakers and 2 inline fuses so far | |
Buck Member
Buck Member
Buck Member
Buck Member
| Subject: Re: 73 sears workhorse/mudder August 18th 2018, 12:42 pm | |
| they want to take it up the trail and get the quad stuck in mud so they can pull it out with the winch, so it's on charge lol | |
Buck Member
| Subject: Re: 73 sears workhorse/mudder August 21st 2018, 4:52 am | |
| @Crazy_Carl that's the winch controller line, I haven't hard wired it yet, I'm going to run both. 2 toggle switches one to power the other so my kids dont destroy my cable. | |
Age : 20 Join date : 2017-06-09 Points : 5494 Posts : 2640 Location : Literally Nowhere, Texas
Buck Member
| Subject: Re: 73 sears workhorse/mudder August 21st 2018, 6:22 pm | |
| @Double W Cross Ranch Ya once I find some like tractor tread tires, there 25 x 8x12 on the back I think 26x 10 would be better and on the fronts are 22" I would like to stay the same height but skinner | |
Buck Member
Buck Member
| Subject: Re: 73 sears workhorse/mudder January 8th 2019, 4:37 pm | |
| Those are some wide Mud Lites!!! Definitely gonna be a big improvment in the traction department. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
mowerjunkie03 Member
Age : 20 Join date : 2018-10-29 Points : 2598 Posts : 342 Location : Burnt Ranch, California
| Subject: Re: 73 sears workhorse/mudder January 8th 2019, 4:43 pm | |
| Great build man! I always liked the way skinny tirea looked on a Sears but those mud lites are XLs. You should have plenty of traction. There alittle worn in the middle so dont be afraid to run them a little bit hire psi. Maybe 10 or 11. | |
Buck Member
| Subject: Re: 73 sears workhorse/mudder January 8th 2019, 4:56 pm | |
| i might fill them with Antifreeze or washerfliud for weight, i have some landscaping to do this spring | |
Buck Member
| Subject: Re: 73 sears workhorse/mudder January 8th 2019, 5:01 pm | |
| i also have a set of these i might run them in the front but if i do that i have to beef up the front. | |
| Subject: Re: 73 sears workhorse/mudder January 8th 2019, 5:07 pm | |
| - Buck wrote:
- i might fill them with Antifreeze or washerfliud for weight, i have some landscaping to do this spring
Well I wouldn't really recomend that. It puts alot more strain on your motor and other components and if you plan on doing any trail riding or mudding all that wheight will not get you anywhere. If you want to have the weight for doing yard work you should get wheel weights you can easily remove. Jusy my opinion. Do what ever you think is best. | |
| Subject: Re: 73 sears workhorse/mudder January 8th 2019, 5:13 pm | |
| - Buck wrote:
- i also have a set of these i might run them in the front but if i do that i have to beef up the front.
I assume these are 23 inch? If you want to run them in the front and you want it to sit level you might have to get/make a new front axle that has straight spindles instead of J spindles. | |
Buck Member
| Subject: Re: 73 sears workhorse/mudder January 8th 2019, 6:22 pm | |
| @mowerjunkie03 thats the plan i have a extra front axle i want to mod, the best thing if i dont like it, i can swap back the oem one and put the other one on frankensears. @Double W Cross Ranch the mud lites? sidewall is like 9/16 think. the AGs are front tires off a 4x4 kabota | |
Buck Member
| Subject: Re: 73 sears workhorse/mudder January 8th 2019, 6:55 pm | |
| - mowerjunkie03 wrote:
- Great build man! I always liked the way skinny tirea looked on a Sears but those mud lites are XLs. You should have plenty of traction. There alittle worn in the middle so dont be afraid to run them a little bit hire psi. Maybe 10 or 11.
I like the skinny tire look aswell, if i can find some mud lites in 8" ill use them. then these can go one frankensears | |
Buck Member
