well I finaly found my workhorse tractor! I was able to get a ford yt18h from 1992 for 120$ without the engine, luckly i had rebuilt a engine over the winter a briggs 20hp oppy, This replacement engine is 2 hp more and 100cc's larger that the original kohler. the transaxle is a Eaton 850 with a charge pump and a filter the trans can put out 800 pound feet of torque at 20hp and has a high price if it breaks so hopefully that doesnt happen. i will post photos in the morning so be ready!
the hydro is foot operated and it has an interesting way to put it into neutral, its a choke cable that goes down to the bypass valve, so theroreticly i can put as much rpm as i want into the input.
here is the pully diagram, there is a double stack pully in the center because the engine is lower than the trans
Crazy_Carl Veteran Member
just a small update, but ive had some major issues with my opposed briggs the piston rod cap for the bottom cylinder came loose and destroyed the inside sending bits of metal everywhere and destroying both cylinders. becuase of that ive upgraded to a kohler V-twin.
so far ive noticed 3 things that are different, i have "full pressure lubrication". that will greatly benifit the lubrication of the engine (poor lubrication probobly killed the briggs). i have an oil filter (the briggs didnt have this). and a ton of wiring becuase of the amount of switches, ampmeter, electric pto, etc. (as seen below)
hotrod-craftsman Member
Age : 22 Join date : 2017-08-26 Points : 2699 Posts : 51 Location : omaha nebraska
The Kohler is definitely stuffed in it I had to bend the steering arm in 3 places to get it to fit, and had to switch the side that the drain plug was on.
im just trying to find out what it is bc i have lots of 3 point attatchments (mower, blade, scrapper, etc). im looking to see if i would need to adapt it to a sleeve hitch or i would be able to put on a 3 point kit
update on the ford, im going to be taking it apart and future proofing it for anything i can throw at it. going to take the seat pan, steering colum and panel off so its going to be pretty bare bones for me to work on. i am going to be looking into either new tires or chains, i will be getting a new seat (due to the condition of the current one) and i plan on repainting the ford as well. photos to come tommorow
