| Craftsman LT4000 utility / mower build | |
biggasmowers Veteran Member
![biggasmowers](https://2img.net/u/2812/37/66/46/avatars/2889-58.jpg)
Age : 24 Join date : 2016-12-30 Points : 4856 Posts : 1944 Location : Kansas
![Craftsman LT4000 utility / mower build Empty](https://2img.net/i/empty.gif) | |
![Craftsman LT4000 utility / mower build Empty](https://2img.net/i/empty.gif) | Subject: Re: Craftsman LT4000 utility / mower build March 3rd 2018, 10:08 pm | |
| It's going to get AT tires and a rack , engine swap, small pulley swap, and maybe paint touch up. Defiantly more than 50 percent incomplete lol | |
![Craftsman LT4000 utility / mower build Empty](https://2img.net/i/empty.gif) | Subject: Re: Craftsman LT4000 utility / mower build March 5th 2018, 9:17 am | |
| ![Craftsman LT4000 utility / mower build 20180329](https://i.servimg.com/u/f62/19/59/62/16/20180329.jpg) hot it running. Disconnected the kill wire , freed up the cylinder with a pipe wrench , cleaned the spark plug and filled the cylinder with oil over night then turned it over for a while with the spark plug out and then put it in and added some gas in the carb and she fired right up! First start in over 4 years. | |
Crazy_Carl Veteran Member
![Craftsman LT4000 utility / mower build Empty](https://2img.net/i/empty.gif) | Subject: Re: Craftsman LT4000 utility / mower build March 5th 2018, 8:53 pm | |
| Well nice machine for what you have into it. I can see you're officially addicted now. I thought you were already set with your murray, craftsman, and snapper death trap, but it looks like your collection is just going to keep growing. | |
![Craftsman LT4000 utility / mower build Empty](https://2img.net/i/empty.gif) | Subject: Re: Craftsman LT4000 utility / mower build March 5th 2018, 9:36 pm | |
| - Crazy_Carl wrote:
- Well nice machine for what you have into it. I can see you're officially addicted now. I thought you were already set with your murray, craftsman, and snapper death trap, but it looks like your collection is just going to keep growing.
I was addicted long ago, just did not have so many mowers then! Well I guess I did, but they were junk and never turned into anything and I didn't habe a welder so that greatly impeded my creativity. | |
![Craftsman LT4000 utility / mower build Empty](https://2img.net/i/empty.gif) | Subject: Re: Craftsman LT4000 utility / mower build March 7th 2018, 5:42 pm | |
| Time for a big block Briggs opposed? Hahaha ![](https://i.servimg.com/u/f86/19/98/54/71/separa13.png) "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
![Craftsman LT4000 utility / mower build Empty](https://2img.net/i/empty.gif) | Subject: Re: Craftsman LT4000 utility / mower build March 8th 2018, 7:40 am | |
| I'd like to see you rip apart that engine and take pictures of the cam damage. We'd all find that pretty interesting. And if it's worth it to put it back together (it might not be)that'd be really cool to see too. | |
![Craftsman LT4000 utility / mower build Empty](https://2img.net/i/empty.gif) | Subject: Re: Craftsman LT4000 utility / mower build March 8th 2018, 9:10 am | |
| Yeah, i will take it apart today and mabye make a video about it, idk. i would like to fix it but the new part would be more costly than just putting in a good old durable engine that i know runs | |
![Craftsman LT4000 utility / mower build Empty](https://2img.net/i/empty.gif) | Subject: Re: Craftsman LT4000 utility / mower build March 8th 2018, 9:27 am | |
| I have an oppy, a Briggs 12 flat head already off and ready to bolt in, then I have parts mtds that the engines supposedly run. I would really like to get this kohler running again but I might put it on my other build off plans if I fix it. It was pretty under powered with the governor on it . | |
![Craftsman LT4000 utility / mower build Empty](https://2img.net/i/empty.gif) | Subject: Re: Craftsman LT4000 utility / mower build March 8th 2018, 1:38 pm | |
| Yeah I never liked the Idea of the plastic cam gears in some newer engines. It probably it a bit quiter but I still don't know if I'd trust it. How many hp is the opposed you have? ![](https://i.servimg.com/u/f86/19/98/54/71/separa13.png) "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
