 [Complete] MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry}
17 posters
Go to page : Previous  1 ... 7 ... 10, 11, 12 ... 17  Next
[Complete] MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry} - Page 11 Empty
PostSubject: Re: [Complete] MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry}   [Complete] MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry} - Page 11 Icon_minitimeMay 30th 2018, 9:28 pm
You can't put a tensioner on the engine belt for a vari drive setup, it will keep it from shifting and force the belts to go into high gear. The tensioner on the trans belt is the tensioner for the whole setup. Need to increase tension on the transmission belt, which will pull on the vari drive pulley harder to increase tension on the engine belt by pushing the middle vari drive variable pulley into the engine belt harder (this is how you increase tension on the engine belt). When you increase the tension on the transmission belt (by the little spring for the tensioner pulley), this will make the vari drive setup shift slower or not at all. To have it shifting again, you need to increase the spring pressure on the spring going to the vari drive pulley itself(the big spring). This big spring is the tension you feel in the clutch pedal mainly, and changing this spring's tension should be done in high gear on the vari drive setup.
The clutch linkage going to the vari drive swing arm should be adjustable to where neutral is all the way forward on the clutch pedal, then should engage in first gear when shifter is in first. Adjust as needed. This ensures the belt length will work correctly for the setup on the engine belt.
You can do all the adjustments while the transaxle is in neutral. That way you can see the vari drive working when you shift and not worry about the mower moving. And you need to do it in the order as written for ease of getting the setup to work right.
PostSubject: Re: [Complete] MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry}   [Complete] MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry} - Page 11 Icon_minitimeMay 31st 2018, 4:19 pm
Bumper looks cool! Does she have some toe?
PostSubject: Re: [Complete] MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry}   [Complete] MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry} - Page 11 Icon_minitimeMay 31st 2018, 5:05 pm
Looks pretty neat! You could maybe reinforce this one if you don't quite trust it. Just rig up a few braces from the bumper to the frame somehow, probably wouldn't be too hard.
PostSubject: Re: [Complete] MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry}   [Complete] MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry} - Page 11 Icon_minitimeMay 31st 2018, 7:17 pm
That looks pretty cool, suits the square hood. I need a front bumper on the Westwood, don't want that nice plastic nose getting crushed.
PostSubject: Re: [Complete] MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry}   [Complete] MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry} - Page 11 Icon_minitimeMay 31st 2018, 11:37 pm
Bumper is nice!
[Complete] MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry} - Page 11 Sig115PROJECTS:
[Complete] MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry} - Page 11 Sig214[Complete] MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry} - Page 11 Sig314
PostSubject: Re: [Complete] MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry}   [Complete] MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry} - Page 11 Icon_minitimeJune 1st 2018, 5:56 pm
Bumper looks good! Reminds me of the first one i made, just a straight piece of box steel across the front of the mower. Simple and effective.
PostSubject: Re: [Complete] MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry}   [Complete] MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry} - Page 11 Icon_minitimeJune 5th 2018, 8:44 am
That's sweet! Looks really nice! I have an ammo crate from WWII in my shop, but it's much bigger.
PostSubject: Re: [Complete] MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry}   [Complete] MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry} - Page 11 Icon_minitimeJune 5th 2018, 11:06 am
Looks good. But it looks a bit big for the rear. How big really is it?
PostSubject: Re: [Complete] MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry}   [Complete] MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry} - Page 11 Icon_minitimeJune 5th 2018, 7:26 pm
Nice wooden tool box!  Very fine german craftsmanship there.
Good start to a bumper butI would rethink the way you mounted that bumper or add more braces.  I prefer the 45 degree cuts on the ends facing forward instead of that but to each their own.
PostSubject: Re: [Complete] MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry}   [Complete] MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry} - Page 11 Icon_minitimeJune 5th 2018, 11:53 pm
Looks good! Is the wood sealed to protect it from rotting?
PostSubject: Re: [Complete] MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry}   [Complete] MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry} - Page 11 Icon_minitimeJune 7th 2018, 10:55 pm
TEST IMAGE...
[Complete] MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry} - Page 11 A111
Hope you have better luck next try. Give another go!
PostSubject: Re: [Complete] MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry}   [Complete] MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry} - Page 11 Icon_minitimeJune 8th 2018, 12:54 am
Test image worked but it took quite a while to load.
PostSubject: Re: [Complete] MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry}   [Complete] MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry} - Page 11 Icon_minitimeJune 8th 2018, 8:59 am
Try changing this setting.
[Complete] MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry} - Page 11 Upload10
I have noticed that host has made some changes. I'll have @Doug look into it when he gets back from Haspin.
Only other thing I can think of, maybe lowering the resolution of the camera? Not Ideal.
PostSubject: Re: [Complete] MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry}   [Complete] MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry} - Page 11 Icon_minitimeJune 8th 2018, 9:25 am
I too have been having a bunch of issue uploading photos, and then once they finish uploading then they flip the picture over if it's a horizontal frame setup.
Isn't this build almost finished? I mean it looks great and looks like you have completed all of your goals for it (better tires yet?)
PostSubject: Re: [Complete] MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry}   [Complete] MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry} - Page 11 Icon_minitimeJune 9th 2018, 10:00 am
Thanks Mighty! I'll try it soon. Hopefully it works then fine. With Camera i had'nt issues til now. Some Pics had even more MB,s and i also tried lower MB Pics, they even do'nt work.
There have been some issues with the host last couple days. It appears to finally resolve last night. Lets hope it does not return.
Page 11 of 17Go to page : Previous  1 ... 7 ... 10, 11, 12 ... 17  Next
» [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]
» [Complete] Maine Mud Mower "Mud Wizard" [2018 Build-Off Entry]
» [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]
» [Complete] Redzz02's Haspin Build [2018 Build-Off Entry]
» [Complete] Bow Tie Mud Guy : BOUNTY HUNTER BUILD [2018 Build-Off Entry]
All-Terrain Lawn Tractor Forum :: Competitions and Challenges :: Build-Off Competition :: Build-Off Archives :: 2018 Archive :: Finalist Archive-
