 CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry]
Dave 007
14 posters
CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] - Page 2 Empty
PostSubject: Re: CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry]   CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] - Page 2 Icon_minitimeMay 29th 2018, 8:44 pm
Interesting idea of welding a frame on top of a frame. Looking forward to seeing how it turns out.
PostSubject: Re: CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry]   CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] - Page 2 Icon_minitimeMay 29th 2018, 9:28 pm
Well not the entire frame...its all stamped in one piece. I'm thinking weld the middle channel of the murray frame on top of the middle of my frame. Now if I had a frame identical to the CQ I just might weld the entire thing on lol, but AWS nomas aren't too common
PostSubject: Re: CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry]   CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] - Page 2 Icon_minitimeMay 30th 2018, 6:08 am
Would it not be better just to weld angle iron or box section under the frame to strengthen it, rather than bits of another frame that isn't very strong anyway? It could work, but might be more hassle than it's worth. Looking forward to seeing pics/vids of the CQ at Haspin!
PostSubject: Re: CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry]   CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] - Page 2 Icon_minitimeMay 30th 2018, 11:56 am
Under the frame is too hard. This murray frame is basically plate steel, and so is the CQ. Welding it to the top will ensure it doesn't interfere with anything, still be fairly light, and with paint will look completely stock. I also have some flat pieces of deck mount (MTD) I'm going to use to strengthen around the transaxle mounts. That's the frame's weak point (pics will show that. I'm waiting on my old phone to charge so I can get some pics and video).
PostSubject: Re: CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry]   CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] - Page 2 Icon_minitimeMay 30th 2018, 2:42 pm
It is a different way of strengthening the frame, I suppose the supports under the frame would interfere with the belts which you don't want. Looking forward to seeing pics Wink
PostSubject: Re: CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry]   CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] - Page 2 Icon_minitimeMay 30th 2018, 4:09 pm
You mean you would cut part of the 2nd frame out and lay it over the first one? Just the sides? Trying to picture what your idea is.
PostSubject: Re: CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry]   CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] - Page 2 Icon_minitimeMay 30th 2018, 7:56 pm
Just the middle. Got my phone fixed today and all my errands ran. Really hoping to get some work done on er tomorrow. Just clearing out the garage was huge to work on it. I can get it down to the frame in a couple hours, then measure, then a couple more hours to cut and weld. Then paint the next day, then reassemble.
Along with the garage, I also pressure washed both frames so I can see what I’m doing lol.
PostSubject: Re: CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry]   CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] - Page 2 Icon_minitimeMay 30th 2018, 11:14 pm
At least you don't have as far to drive to get to haspin.
Good luck with the mods!
PostSubject: Re: CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry]   CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] - Page 2 Icon_minitimeMay 31st 2018, 9:51 pm
Sup guys, got it all apart today. Got the plate cut and welded on. Once side of the frame repaired/reinforced where it was cracking. Video will be up as soon as I get it edited, till then here is a pic to explain my reinforcement strategy:
CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] - Page 2 27494110
The red plate was cut from the Murray
PostSubject: Re: CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry]   CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] - Page 2 Icon_minitimeMay 31st 2018, 10:21 pm
Yup! Plate it up and weld it in. The layers help the whole area from flexing. Very discrete too.
PostSubject: Re: CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry]   CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] - Page 2 Icon_minitimeMay 31st 2018, 10:24 pm
That’s the hope! And I’m gonna use the whole tunnel for storage!
PostSubject: Re: CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry]   CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] - Page 2 Icon_minitimeMay 31st 2018, 11:43 pm
Looks cool so far. That should help. What day you plan on being at haspin? Me and doug are supposed to get there lateish on tuesday night.... supposed to.....
PostSubject: Re: CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry]   CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] - Page 2 Icon_minitimeJune 1st 2018, 5:58 am
That looks pretty good, basically doubles the thickness of the frame there. Hope you get 'er done in time for Haspin! Wink
PostSubject: Re: CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry]   CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] - Page 2 Icon_minitimeJune 1st 2018, 7:28 am
You are cutting it close!  Good idea and job with the plate.
CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] - Page 2 Sig115PROJECTS:
CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] - Page 2 Sig214CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] - Page 2 Sig314
PostSubject: Re: CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry]   CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] - Page 2 Icon_minitimeJune 1st 2018, 8:18 am
Thanks guys. Mr mod, I’m planning on getting there the 6th....don’t remember exactly what day that is though lmao
PostSubject: Re: CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry]   CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] - Page 2 Icon_minitimeJune 3rd 2018, 10:23 pm
OK. Looks like ill be getting to Haspin early afternoon Wednesday. No further progress yet, spent the weekend up at my grandmas. Tomorrow hopefully will be trans swap, other side reinforced, steering, and paint. Then Tuesday will be more coats of paint and reassembly.
Here is the video from Thursday:
PostSubject: Re: CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry]   CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] - Page 2 Icon_minitimeJune 4th 2018, 11:48 am
Update: transaxle is out and first coat of paint on side panels and fenders. Waiting on help to arrive so I can swap the frame to the driveway and paint stuff in the garage. Too darn windy.
PostSubject: Re: CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry]   CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] - Page 2 Icon_minitimeJune 4th 2018, 11:57 am
Nice, like the video. Hope you allow enough time for the paint to dry, wet paint and mud don't mix too well lol!
PostSubject: Re: CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry]   CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] - Page 2 Icon_minitimeJune 4th 2018, 12:02 pm
Lol I’m actually just painting over a little bit of mud.....hahahaha
PostSubject: Re: CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry]   CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] - Page 2 Icon_minitimeJune 6th 2018, 6:00 am
All done except the back wheels/tires. One won’t come off the old transaxle
CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] - Page 2 A186d410
PostSubject: Re: CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry]   CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] - Page 2 Icon_minitimeJune 6th 2018, 6:56 am
Looking good. Sux about the stuck rim, tried heat or wax?
PostSubject: Re: CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry]   CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] - Page 2 Icon_minitimeJune 6th 2018, 9:40 am
Tried heat and quenching it with wd40. Not even the 2 pound hammer with a punch will budge it. Couple options here.
Option 1: go to Napa and have them use a hydraulic press to push the axle out of the rim
Option two (backup plan): go to the junkyard and find a rim with the right offset, pull my tire off the rim and swap it onto the new rim and slide it on the new trans
PostSubject: Re: CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry]   CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] - Page 2 Icon_minitimeJune 6th 2018, 10:02 am
Probably be easier to get a similar rim and just swap the tyre on.
PostSubject: Re: CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry]   CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] - Page 2 Icon_minitimeJune 6th 2018, 2:19 pm
Well , one option would be to pull the axle out of the tranny and pound it out from the back way. I have done this on extremely stuck axles and it works pretty good of you don't care about the axle. You can point the axles out a bit then sand it down and then slide it off the intentional way.
PostSubject: Re: CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry]   CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] - Page 2 Icon_minitimeJune 6th 2018, 2:59 pm
Well I’m gonna reuse this transaxle in another build. I’ll just cut the rim off. I’ve already got a new rim and am most of the way to haspin. Just made a gas and pizza stop
PostSubject: Re: CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry]   CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] - Page 2 Icon_minitimeJune 6th 2018, 7:28 pm
Awesome!!!! Hope ya have a blast and don't break down. Good luck with the tire I guess.
» [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry]
» Duuds Build Off 2018 "The Donkey" aka "Eesel" [2018 Build-Off Entry]
» Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry]
» 2018 ATLTF Build off The ATM [2018 Build-Off Entry]
All-Terrain Lawn Tractor Forum :: Competitions and Challenges :: Build-Off Competition :: Build-Off Archives :: 2018 Archive-
