 CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry]
Dave 007
14 posters
Go to page : 1, 2, 3  Next
CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] Empty
PostSubject: CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry]   CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] Icon_minitimeFebruary 5th 2018, 10:28 pm
Ok so most of you know my machine, the CraftsmanQuad or CQ for short. But it’s never done and it’s nowher near where I want it for haspin, so hopefully you guys let me in as under 50% completed
Build list:
Reinforce frame
Paint side panels, tunnel, and frame black
Paint fenders tan
Wiring harness
New front tires
Light bar
Battery
Auxiliary tank?
V-twin?
Bigger front pulley?
CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] B37f3410
CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] 50389f10
CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] Ba65e510
CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] 8448c210
-Approved by Doug, 2/8/2018
PostSubject: Re: CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry]   CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] Icon_minitimeFebruary 8th 2018, 9:10 pm
Make sure you have that Waiver signed for Haspin!
PostSubject: Re: CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry]   CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] Icon_minitimeFebruary 9th 2018, 7:24 am
Birthday is in May, I’ll be 18 by then, so I’ll be good right?
PostSubject: Re: CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry]   CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] Icon_minitimeFebruary 10th 2018, 4:48 pm
Here is the link to the original pre-buildoff thread:
CraftsmanQuad
Dave 007
2017 Build-Off Top 3 Winner
PostSubject: Re: CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry]   CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] Icon_minitimeFebruary 13th 2018, 5:41 am
Good luck and best wishes, very happy to see your entry. cheers.
PostSubject: Re: CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry]   CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] Icon_minitimeMarch 2nd 2018, 8:03 pm
Alrighty guys, not a big update here but an update none the less. Got a different idler setup on the rear, and the new belt put on. Took it for a drive tonight and everything was working fine.
Hope this setup is the one, it’s the 3rd or 4th try lol
PostSubject: Re: CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry]   CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] Icon_minitimeMarch 2nd 2018, 8:07 pm
Nice CQ! It's always great to have a nicely functioning belt system. My least favorite part to figure out though, haha.
PostSubject: Re: CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry]   CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] Icon_minitimeMarch 2nd 2018, 8:23 pm
It’s all trial and error. I’ll need to figure out something different on the simplicity when that belt lets go. I’m not doing that setup again
PostSubject: Re: CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry]   CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] Icon_minitimeMarch 18th 2018, 9:06 pm
Small update tonight. Got the transaxle vented for now. Gonna redo it later more permanent when I blow the whole thing apart and go through it from the ground up. Once it’s warm enough I’ll get the pressure washer out, take it down to bare frame, wash it, reinforce everything, paint it all, new bushings in the front axle and steering, transaxle vent to the air intake on the engine, and finally the wiring.
I’m sorry for the slow progress, just waiting on some good weather and some time to really get into it. Few hours here and there isn’t enough for me to justify tearing down my perfectly running rig, upgrades or not.
PostSubject: Re: CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry]   CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] Icon_minitimeMarch 18th 2018, 9:28 pm
No problem, a few of us have been waiting for better days to work! Good you have a todo list. Keeps ya focused!
CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] Sig115PROJECTS:
CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] Sig214CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] Sig314
PostSubject: Re: CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry]   CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] Icon_minitimeApril 3rd 2018, 6:38 pm
I have officially added front transaxle braces to the ‘to-do’ list. Won’t add much weight but will hopefully add a lot of strength. Also, this will be getting a new transaxle. The one in it now is out of a Murray and has the tall shifter. It also leaks a bit.
I’m going to take one of my spare MST 206s (out of a craftsman) and do fresh oil, thread in a transaxle vent, and swap it in. The MST in mine now will go in my friends MTD.
What do you guys recommend running for oil? I run 90wt gear oil in it now, but that stuff gets really thick when it’s cold. Have read about ATF, and have a couple quarts of that on hand so that would be preferable. People have told me it may be a little thin, but some Lucas oil transmission fluid additive would bring up the viscosity quite a bit.
And what else would you guys do while the transaxle is out for durability? As far as I know all the seals and bearings are good, and I don’t want to lock it.
PostSubject: Re: CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry]   CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] Icon_minitimeApril 3rd 2018, 6:59 pm
I would try 50 wt motor oil.  That's what what my hydro uses and it works good in the cold.
PostSubject: Re: CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry]   CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] Icon_minitimeApril 3rd 2018, 10:29 pm
I use Lucas Oil Transmission Fix, I love the stuff. Works wonders for a transaxle.
PostSubject: Re: CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry]   CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] Icon_minitimeApril 3rd 2018, 10:52 pm
Yeah I would think like 15w40 would be a happy medium. Although I run 80w90 gear oil in my transaxles and don't have any issues in the cold. My 600's don't have shift keys obviously, but still. Haha.
PostSubject: Re: CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry]   CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] Icon_minitimeApril 3rd 2018, 11:19 pm
Once that mst warms up it’s fine, but man oh man when it’s cold it’s a bugger haha. Plus my shift pattern is wrong so it’s hard to tell if it’s in neutral
PostSubject: Re: CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry]   CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] Icon_minitimeApril 4th 2018, 7:52 am
Nice to see the CQ in the build off! I've never had any problems with my MST in the cold and I have 80w90 oil in it. As suggested maybe clean the case out and try a thinner oil. Wouldn't want it too thin though as it would leak out of the seals.
PostSubject: Re: CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry]   CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] Icon_minitimeMay 2nd 2018, 10:05 pm
Hauled a couple loads of wood today. Going to swap the transaxle very soon. The one that’s in it now is out of a Murray, so it has the tall shifter, which threw my shift pattern off, and it doesn’t shift very well. When I first got it, the tractor overall wasn’t in very good shape and the little bit of oil that I drained from the transmission looked like Hershey’s chocolate syrup. Not even kidding.
I have much higher hopes for the next trans. Another MST206 but this is from a craftsman. Also will be making front transaxle mounts at some point. Most likely the same time I reinforce the frame
Pic from today:CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] Db0cbe10
PostSubject: Re: CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry]   CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] Icon_minitimeMay 24th 2018, 8:55 am
Ok guys, tomorrow is our last day of school. That gives me about a week to thrash hard on this thing and get it done for the trip. What I’m looking to get done in that time is reinforce the frame with the Murray pan frame I just got, paint, and rebuild the steering with all new bushings, heims, and a new tierod.
In two days this build is officially OFF HOLD
Things like tires and wiring will be done after the trip at some point
PostSubject: Re: CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry]   CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] Icon_minitimeMay 24th 2018, 10:06 am
I really like those rear knobby tires, nice and trippy in various terrains i would think, how do they handle in mud?
PostSubject: Re: CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry]   CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] Icon_minitimeMay 24th 2018, 10:46 am
Let the fun begin!
PostSubject: Re: CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry]   CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] Icon_minitimeMay 24th 2018, 12:01 pm
Be cool if you come to haspin. The rear tires fit nice in the fenders, looks good.
PostSubject: Re: CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry]   CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] Icon_minitimeMay 24th 2018, 1:13 pm
Biggas: they do ok as long as you have enough wheelspeed to keep the tread clear. Real sticky mud or going slow they struggle.
Mighty: haha heck yea!
Mr.moo: yep I’m planning on going! They’re 22x11-8 duros. The stock was 20x10-8. I think they fit nice myself. Wanted to add fender flares for more protection but it would totally kill the look
PostSubject: Re: CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry]   CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] Icon_minitimeMay 24th 2018, 1:37 pm
Yeah my stance is too wide now for any thought of fender flares, and I always get muddy anyway so what's the use.
PostSubject: Re: CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry]   CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] Icon_minitimeMay 29th 2018, 8:16 pm
Ok guys got a bit of an update but no pics yet. My phone has been on the fritz all weekend. I found a pan frame murray for free that I got completely broken down to parts this weekend. Here's what I got:
-12 horse briggs, brothers mower
-wiring, friends MTD
-steering box, also the MTD
-peerless 920 or 930 5 speed, dynamark street rod
-front wheels/tires, my wagon
-the frame, THE CQ!
So I'm cutting up the frame and welding it right in on top of my existing frame. I hope to start tearing down the CQ tomorrow after I clean pressure wash the driveway (long story) and after football practice.
PostSubject: Re: CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry]   CraftsmanQuad19’s CraftsmanQuad [2018 Build-Off Entry] Icon_minitimeMay 29th 2018, 8:44 pm
Interesting idea of welding a frame on top of a frame. Looking forward to seeing how it turns out.
» [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry]
» Duuds Build Off 2018 "The Donkey" aka "Eesel" [2018 Build-Off Entry]
» Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry]
» 2018 ATLTF Build off The ATM [2018 Build-Off Entry]
All-Terrain Lawn Tractor Forum :: Competitions and Challenges :: Build-Off Competition :: Build-Off Archives :: 2018 Archive-
