 Lawnmowerboy's Burn-in-Rubber [2018 Build-Off Entry]
Lawnmowerboy
8 posters
Lawnmowerboy
Lawnmowerboy
Lawnmowerboy's Burn-in-Rubber [2018 Build-Off Entry] Empty
PostSubject: Lawnmowerboy's Burn-in-Rubber [2018 Build-Off Entry]   Lawnmowerboy's Burn-in-Rubber [2018 Build-Off Entry] Icon_minitimeFebruary 1st 2018, 7:22 pm
My plans are to put "big tires" all the way around and have it go around 20mhp or so, have a channel iron front bumper, upgrade the steering, wire it up, twin gas tanks, transaxel supports, trodle cable, parking break,  center shiftier, wheeler bar, head light tale light, battery box, pull start
Lawnmowerboy's Burn-in-Rubber [2018 Build-Off Entry] Omg_us10
-Approved by Doug, 2/1/2018
-Update Alert by MightyRaze 5/2/2018
-Update Alert **Removed** by MightyRaze 5/2/2018
PostSubject: Re: Lawnmowerboy's Burn-in-Rubber [2018 Build-Off Entry]   Lawnmowerboy's Burn-in-Rubber [2018 Build-Off Entry] Icon_minitimeFebruary 1st 2018, 9:04 pm
Youre in, good luck!
PostSubject: Re: Lawnmowerboy's Burn-in-Rubber [2018 Build-Off Entry]   Lawnmowerboy's Burn-in-Rubber [2018 Build-Off Entry] Icon_minitimeFebruary 1st 2018, 9:45 pm
Nice to see you here scotty.
PostSubject: Re: Lawnmowerboy's Burn-in-Rubber [2018 Build-Off Entry]   Lawnmowerboy's Burn-in-Rubber [2018 Build-Off Entry] Icon_minitimeFebruary 1st 2018, 9:53 pm
Nice and shiny!  Good luck dude!
Lawnmowerboy
Lawnmowerboy
PostSubject: Re: Lawnmowerboy's Burn-in-Rubber [2018 Build-Off Entry]   Lawnmowerboy's Burn-in-Rubber [2018 Build-Off Entry] Icon_minitimeFebruary 4th 2018, 7:31 pm
Update #1 This weekend i got the trans mounted and the wheels on it Still got to make up a gas tank and shifter, bumper, and try fixing the flat tires on the left side, wire it!
Lawnmowerboy's Burn-in-Rubber [2018 Build-Off Entry] 20180210
Lawnmowerboy's Burn-in-Rubber [2018 Build-Off Entry] 20180211
Lawnmowerboy's Burn-in-Rubber [2018 Build-Off Entry] 20180212
PostSubject: Re: Lawnmowerboy's Burn-in-Rubber [2018 Build-Off Entry]   Lawnmowerboy's Burn-in-Rubber [2018 Build-Off Entry] Icon_minitimeFebruary 4th 2018, 7:36 pm
looks like you need to lift the rear to level her out
PostSubject: Re: Lawnmowerboy's Burn-in-Rubber [2018 Build-Off Entry]   Lawnmowerboy's Burn-in-Rubber [2018 Build-Off Entry] Icon_minitimeFebruary 4th 2018, 7:55 pm
Did you paint the engine?
PostSubject: Re: Lawnmowerboy's Burn-in-Rubber [2018 Build-Off Entry]   Lawnmowerboy's Burn-in-Rubber [2018 Build-Off Entry] Icon_minitimeFebruary 4th 2018, 8:13 pm
Good start. Keep it up!
Lawnmowerboy's Burn-in-Rubber [2018 Build-Off Entry] Sig115PROJECTS:
Lawnmowerboy's Burn-in-Rubber [2018 Build-Off Entry] Sig214Lawnmowerboy's Burn-in-Rubber [2018 Build-Off Entry] Sig314
Lawnmowerboy
Lawnmowerboy
PostSubject: Re: Lawnmowerboy's Burn-in-Rubber [2018 Build-Off Entry]   Lawnmowerboy's Burn-in-Rubber [2018 Build-Off Entry] Icon_minitimeFebruary 5th 2018, 5:55 pm
thanks ever one and yes i did paint the engine
Dave 007
2017 Build-Off Top 3 Winner
PostSubject: Re: Lawnmowerboy's Burn-in-Rubber [2018 Build-Off Entry]   Lawnmowerboy's Burn-in-Rubber [2018 Build-Off Entry] Icon_minitimeFebruary 13th 2018, 5:47 am
Good luck and best wishes, very happy to see your entry. cheers.
Lawnmowerboy
Lawnmowerboy
PostSubject: Re: Lawnmowerboy's Burn-in-Rubber [2018 Build-Off Entry]   Lawnmowerboy's Burn-in-Rubber [2018 Build-Off Entry] Icon_minitimeFebruary 22nd 2018, 9:04 pm
Well i decided to go with a kohler v twin 11hp would not run.. but i need to get a new frame for it becuase the old one is fu$&ed up
Lawnmowerboy's Burn-in-Rubber [2018 Build-Off Entry] 20180213
Lawnmowerboy's Burn-in-Rubber [2018 Build-Off Entry] 20180214
PostSubject: Re: Lawnmowerboy's Burn-in-Rubber [2018 Build-Off Entry]   Lawnmowerboy's Burn-in-Rubber [2018 Build-Off Entry] Icon_minitimeApril 26th 2018, 11:18 am
@Lawnmowerboy Please update your thread! Other members please refrain from responding until thread owner updates.
Lawnmowerboy
Lawnmowerboy
PostSubject: Re: Lawnmowerboy's Burn-in-Rubber [2018 Build-Off Entry]   Lawnmowerboy's Burn-in-Rubber [2018 Build-Off Entry] Icon_minitimeMay 2nd 2018, 11:21 am
Well sorry for not updating i have been looking for another lawn mower frame and trans and a engine and i found them....i hope its okay if i use them for this profect my planes are still the same i just half to fix the tires that go flat from the other mower and put them on this one
I have all ready swaped the stearing out to second gen on the new mower
Lawnmowerboy's Burn-in-Rubber [2018 Build-Off Entry] Img_2011
Lawnmowerboy's Burn-in-Rubber [2018 Build-Off Entry] Img_2010
PostSubject: Re: Lawnmowerboy's Burn-in-Rubber [2018 Build-Off Entry]   Lawnmowerboy's Burn-in-Rubber [2018 Build-Off Entry] Icon_minitimeMay 2nd 2018, 1:04 pm
Thanks for the update! (Alert removed) There have been some other frame swaps in the past. I personally do not see anything over the 50% mark bringing in the new chasis, but I am just a MOD not an ADMIN like @Doug who would have final say. Lawnmowerboy's Burn-in-Rubber [2018 Build-Off Entry] 2731072446
Lawnmowerboy
Lawnmowerboy
PostSubject: Re: Lawnmowerboy's Burn-in-Rubber [2018 Build-Off Entry]   Lawnmowerboy's Burn-in-Rubber [2018 Build-Off Entry] Icon_minitimeMay 2nd 2018, 7:28 pm
Thanks Mighty Raze and yeah only thing i have done is pully swap and a searing change
Lawnmowerboy
Lawnmowerboy
PostSubject: Re: Lawnmowerboy's Burn-in-Rubber [2018 Build-Off Entry]   Lawnmowerboy's Burn-in-Rubber [2018 Build-Off Entry] Icon_minitimeMay 31st 2018, 9:24 pm
Well i ditched the big tire plain but i found this oppy and put it on her and made it run with a side post chevey battery and a rear gas tank just need to get me some atv tires when ever i get me some money.
Lawnmowerboy's Burn-in-Rubber [2018 Build-Off Entry] Img_2013
Lawnmowerboy's Burn-in-Rubber [2018 Build-Off Entry] Img_2012
PostSubject: Re: Lawnmowerboy's Burn-in-Rubber [2018 Build-Off Entry]   Lawnmowerboy's Burn-in-Rubber [2018 Build-Off Entry] Icon_minitimeMay 31st 2018, 9:32 pm
Nice, what happened to that brush guard?
PostSubject: Re: Lawnmowerboy's Burn-in-Rubber [2018 Build-Off Entry]   Lawnmowerboy's Burn-in-Rubber [2018 Build-Off Entry] Icon_minitimeJune 1st 2018, 6:01 am
Cool mower, I actually quite liked those big tyres. I like the front bumper!
» Duuds Build Off 2018 "The Donkey" aka "Eesel" [2018 Build-Off Entry]
» Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry]
» 2018 ATLTF Build off The ATM [2018 Build-Off Entry]
» Budget build murray [2018 Build-Off Entry]
All-Terrain Lawn Tractor Forum :: Competitions and Challenges :: Build-Off Competition :: Build-Off Archives :: 2018 Archive-
