| "NellyBelle" Craftsman LT1000 [2018 Build-Off Entry] | |
+14RichieRichOverdrive mrshaft696 TheBeal Dave 007 Doug muddstir CraftsmanQuad19 RCG Crazy_Carl AllisKidD21 biggasmowers muckmudd MightyRaze Double W Cross Ranch 18 posters |
biggasmowers Veteran Member
Age : 24 Join date : 2016-12-30 Points : 4927 Posts : 1944 Location : Kansas
Age : 20 Join date : 2017-06-09 Points : 5489 Posts : 2640 Location : Literally Nowhere, Texas
| Subject: Re: "NellyBelle" Craftsman LT1000 [2018 Build-Off Entry] March 2nd 2018, 2:32 pm | |
| - biggasmowers wrote:
- If you get the john deere and sell the parts you dont use , buy a welder so you can make more stuff easy. or offer to trade your deere parts for a welder.
yeah I really need one. lol. | |
| Subject: Re: "NellyBelle" Craftsman LT1000 [2018 Build-Off Entry] March 2nd 2018, 3:27 pm | |
| If you made a piece of pipe with female threads and found an automotive sway bar link with a shaft that was the same O.D. as the I.D. of the pipe threads, you could cut it in half and run a die over the shaft to make male threads. Then you could thread the halves of the sway bar into the pipe and have and adjustable tie rod with heavy duty ends! Just a suggestion, haha. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: "NellyBelle" Craftsman LT1000 [2018 Build-Off Entry] March 2nd 2018, 6:39 pm | |
| Well I just assumed he already had access to a tap and die set. That's why I never mentioned anything about buying one. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: "NellyBelle" Craftsman LT1000 [2018 Build-Off Entry] March 2nd 2018, 7:06 pm | |
| - AllisKidD21 wrote:
- Well I just assumed he already had access to a tap and die set. That's why I never mentioned anything about buying one.
Yeah I don't have one. I always just make my own taps when ever I need them. | |
muckmudd Established Member
Age : 22 Join date : 2017-07-11 Points : 3558 Posts : 825 Location : In the shop
TheBeal Veteran Member
Age : 30 Join date : 2013-06-06 Points : 5714 Posts : 1402 Location : Central PA
Age : 23 Join date : 2018-02-27 Points : 3843 Posts : 1299
