| MTD off-road build (Mobile Terrain Dominator) "2" | |
+15NorthportTroller Creepycrawler Crazy_Carl George Gooding prancstaman MatthewD Dave.MTD CraftsmanQuad19 TheBeal Double W Cross Ranch biggasmowers MightyRaze muckmudd RichieRichOverdrive AllisKidD21 19 posters | |
| | | | AllisKidD21 Moderator
| Subject: Re: MTD off-road build (Mobile Terrain Dominator) "2" March 17th 2018, 9:08 am | |
| In the off-road pictures thread? Yeah that was snow coming down. We can't seem to get rid of the darn stuff, haha. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| | | biggasmowers Veteran Member
Age : 24 Join date : 2016-12-30 Points : 4931 Posts : 1944 Location : Kansas
| Subject: Re: MTD off-road build (Mobile Terrain Dominator) "2" March 17th 2018, 9:20 pm | |
| I decided to try and tackle the new pitman arm today. I got the old stuff all cut off: I just got couple pieces of flatstock and doubled them up, haha. Should alright, definitely won't bend. I'm gonna have a couple braces though for sure. I also had to reshape my drag link a bit because I made the new pitman arm shorter. That's all I had time for today unfortunately, but I got most of it done. I'm gonna have to notch my pitman arm a bit because I have a couple clearance issues, but hopefully it won't be too bad. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Age : 24 Join date : 2016-04-12 Points : 5982 Posts : 2645 Location : Indiana
| Subject: Re: MTD off-road build (Mobile Terrain Dominator) "2" March 17th 2018, 9:26 pm | |
| Yeah that's what I was thinking. Should be a bit lower ratio too which is nice, haha. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: MTD off-road build (Mobile Terrain Dominator) "2" March 18th 2018, 9:12 am | |
| I'm a little concerned about the weld where you joined the new pitman arm to what's left of the original truck one on the steering box. How about adding a couple of small braces like this? | |
| Subject: Re: MTD off-road build (Mobile Terrain Dominator) "2" March 18th 2018, 11:51 am | |
| - AllisKidD21 wrote:
- I'm gonna have a couple braces though for sure.
Yep that's pretty much the plan. I was gonna use two triangular peices like I had before most likely. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: MTD off-road build (Mobile Terrain Dominator) "2" March 21st 2018, 4:56 pm | |
| I decided to go a different route with my pitman arm because of some clearance issues I was having with the flat stock. Cut it all off again... Decided to go with a piece of 5/8" bar stock instead (part of the old steering shaft, haha) It should hold up nice. Made a little flange thing for it as well as you can see in the picture. Ground a flat spot. Burned it in. Then welded it right to the hub on the pitman shaft. And the piece for the drag link to bolt to All buttoned back up! Works great!! Just over 2 1/4 turns lock to lock, which isn't too bad. Should hold up fine too. Let me know what ya think! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: MTD off-road build (Mobile Terrain Dominator) "2" March 21st 2018, 5:06 pm | |
| hmmm the shape those braces have looks awfully familiar lol. As usual nice job man. It amazes me that you do this work outside on a vise screwed down to a big log. If you don't mind working outside of a shop setting you should become a mobile service technician of some kind. There's good money in it. | |
| Subject: Re: MTD off-road build (Mobile Terrain Dominator) "2" March 21st 2018, 5:45 pm | |
| Thanks Carl! Yeah haha, I was just gonna do two triangle braces like I had before, but it came out looking a lot more like your idea. I definitely do most of my work on that ol' stump, but it's not too bad. The wind kinda sucks sometimes though hahaha. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Age : 49 Join date : 2016-09-06 Points : 15677 Posts : 10988 Location : Oklahoma
| Subject: Re: MTD off-road build (Mobile Terrain Dominator) "2" March 21st 2018, 8:49 pm | |
| Well thanks Mighty! I definitely is nice to have 'er driving again haha. I replaced that U-bolt that was too big as well, finally haha. The flat flange for the other U-bolt beeds to be welded down because it keeps coming loose and sliding around. The transaxle moves a bit when it's loose so I'm definitely gonna have to weld that flange down, which isn't a bit deal. The clutch needs adjustment or something as well I think because it's engaging a little hard. That stuff will be tomorrow's job hahaha. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| | | Double W Cross Ranch Veteran Member
Age : 20 Join date : 2017-06-09 Points : 5493 Posts : 2640 Location : Literally Nowhere, Texas
| Subject: Re: MTD off-road build (Mobile Terrain Dominator) "2" March 21st 2018, 8:58 pm | |
| Thanks, haha. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: MTD off-road build (Mobile Terrain Dominator) "2" March 22nd 2018, 12:08 pm | |
| Steering wasn't quite even so I figured It'd be a good idea to have both end of my drag link adjustable. Works good! I also got my U-bolt flange welded down nice and solid, and I tightened up my clutch pivot as it was quite loose. Sooo much smoother now, doesn't try to throw me off anymore haha. Glad to have that fixed up! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| | | muckmudd Established Member
Age : 22 Join date : 2017-07-11 Points : 3562 Posts : 825 Location : In the shop
| Subject: Re: MTD off-road build (Mobile Terrain Dominator) "2" March 22nd 2018, 12:25 pm | |
| - muckmudd wrote:
- Nice, that belt is looking pretty worn though.
Yeah, haha she needs a new one for sure. - biggasmowers wrote:
- Uhuh. There are quite a few extreme angles on those front end parts lol.
If you're reffering to the outer 3-link bars then yes the frame mounts need to be dropped down a bit, but it's hardly an "extreme" angle. It's hardly anything to worry about for the time being. The suspension still works fine as opposed to just being all stiff and annoying and I still have good articulation, which is good for me. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: MTD off-road build (Mobile Terrain Dominator) "2" March 22nd 2018, 7:15 pm | |
| I got a couple cool shots today after I finished working on 'er: Nice to not have to worry about lack of oil at these kinds of angles now, hahaha. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: MTD off-road build (Mobile Terrain Dominator) "2" March 22nd 2018, 8:02 pm | |
| Thanks! Haha. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: MTD off-road build (Mobile Terrain Dominator) "2" March 22nd 2018, 11:19 pm | |
| Thanks mighty! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Age : 22 Join date : 2016-10-29 Points : 7223 Posts : 4021 Location : Lewisburg, KY
| Subject: Re: MTD off-road build (Mobile Terrain Dominator) "2" March 28th 2018, 4:44 pm | |
| Hahaha, well Rich surprisingly enough I haven't made a lick of progress on that particular project. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Who is online? | In total there are 38 users online :: 0 Registered, 0 Hidden and 38 Guests
