 1993 Craftsman LT4000 heavy mud build.
11 posters
Go to page : Previous  1, 2, 3, 4, 5, 6 ... 11, 12, 13  Next
1993 Craftsman LT4000 heavy mud build. - Page 5 Empty
PostSubject: Re: 1993 Craftsman LT4000 heavy mud build.   1993 Craftsman LT4000 heavy mud build. - Page 5 Icon_minitimeMarch 2nd 2018, 1:23 pm
That's what was wrong with my LT1000 when I got it. Bearing in the plastic idler seized and the belt ate the pulley. Just threw a different idler on, got a new belt, and that was all it took to fix it. Damn plastic pulleys, lol
PostSubject: Re: 1993 Craftsman LT4000 heavy mud build.   1993 Craftsman LT4000 heavy mud build. - Page 5 Icon_minitimeMarch 2nd 2018, 1:56 pm
I fear I have the same issue with my regular "mower". Crying or Very sad
1993 Craftsman LT4000 heavy mud build. - Page 5 Sig115PROJECTS:
1993 Craftsman LT4000 heavy mud build. - Page 5 Sig2141993 Craftsman LT4000 heavy mud build. - Page 5 Sig314
PostSubject: Re: 1993 Craftsman LT4000 heavy mud build.   1993 Craftsman LT4000 heavy mud build. - Page 5 Icon_minitimeMarch 2nd 2018, 2:01 pm
Just get a metal pulley instead.
PostSubject: Re: 1993 Craftsman LT4000 heavy mud build.   1993 Craftsman LT4000 heavy mud build. - Page 5 Icon_minitimeMarch 2nd 2018, 2:03 pm
So when it freezes up the belt gets burned up instead of the plastic pulley??
PostSubject: Re: 1993 Craftsman LT4000 heavy mud build.   1993 Craftsman LT4000 heavy mud build. - Page 5 Icon_minitimeMarch 2nd 2018, 2:04 pm
well....the belt is cheaper than the pulley....
PostSubject: Re: 1993 Craftsman LT4000 heavy mud build.   1993 Craftsman LT4000 heavy mud build. - Page 5 Icon_minitimeMarch 2nd 2018, 2:05 pm
not really. all my belts are 20 bucks at the cheapest, an idler is mabye 15
PostSubject: Re: 1993 Craftsman LT4000 heavy mud build.   1993 Craftsman LT4000 heavy mud build. - Page 5 Icon_minitimeMarch 2nd 2018, 2:06 pm
for me, belts are like 10 and an idler is at least 30.  TSC is so expensive.
PostSubject: Re: 1993 Craftsman LT4000 heavy mud build.   1993 Craftsman LT4000 heavy mud build. - Page 5 Icon_minitimeMarch 2nd 2018, 2:11 pm
yeah. i might go out later and clean my fuel system and swap carbs if i get more homework crap done,.....then i will go mudding ! and try out some different filming styles
PostSubject: Re: 1993 Craftsman LT4000 heavy mud build.   1993 Craftsman LT4000 heavy mud build. - Page 5 Icon_minitimeMarch 2nd 2018, 3:25 pm
Not sure why the adjustment screw looks like that,
The one with the spring under it is normal I thought but the other one looks so much different nut appears to be intentional. Anybody know why they look like this? 1993 Craftsman LT4000 heavy mud build. - Page 5 15200210
1993 Craftsman LT4000 heavy mud build. - Page 5 15200211
1993 Craftsman LT4000 heavy mud build. - Page 5 15200212
PostSubject: Re: 1993 Craftsman LT4000 heavy mud build.   1993 Craftsman LT4000 heavy mud build. - Page 5 Icon_minitimeMarch 2nd 2018, 6:46 pm
Well got it running , took it for a romp, and had a BLAST!!! Videos soon to come!!! For once I didn't get stuck but I need to make belly pans because I had the clutch potter pin and belt get knocked off with all of the small trees and brush hitting them.
PostSubject: Re: 1993 Craftsman LT4000 heavy mud build.   1993 Craftsman LT4000 heavy mud build. - Page 5 Icon_minitimeMarch 2nd 2018, 7:08 pm
Yeah I do that so much.  I'll await the footage in earnest!!!
PostSubject: Re: 1993 Craftsman LT4000 heavy mud build.   1993 Craftsman LT4000 heavy mud build. - Page 5 Icon_minitimeMarch 2nd 2018, 7:53 pm
Yup. the mud was great ! i might try to post a short clip so y'all can see some of the action.
PostSubject: Re: 1993 Craftsman LT4000 heavy mud build.   1993 Craftsman LT4000 heavy mud build. - Page 5 Icon_minitimeMarch 2nd 2018, 9:31 pm
Short clip of some fun mudding .
PostSubject: Re: 1993 Craftsman LT4000 heavy mud build.   1993 Craftsman LT4000 heavy mud build. - Page 5 Icon_minitimeMarch 2nd 2018, 10:12 pm
I do not think the one without the spring is adjustable?
PostSubject: Re: 1993 Craftsman LT4000 heavy mud build.   1993 Craftsman LT4000 heavy mud build. - Page 5 Icon_minitimeMarch 3rd 2018, 9:22 am
Really? Well I just cleaned the one that was on it . It had sand in the bowl and the jet was 90% clogged . I think it was getting in through the holes that the air filter is bolted on with so I put some wing nuts on it with a seal under so hopefully that keeps it cleaner. I only had one issue with it running while I was out mudding but it does run very well now.
PostSubject: Re: 1993 Craftsman LT4000 heavy mud build.   1993 Craftsman LT4000 heavy mud build. - Page 5 Icon_minitimeMarch 3rd 2018, 9:50 am
@biggasmowers The engine does sound pretty good in your video. I like the different camera angles you tried. I can't believe how much mud covered you and your machine. Your mud looks like freshly mixed concrete down there. No wonder you get stuck so much. Thank god for pressure washers too.
PostSubject: Re: 1993 Craftsman LT4000 heavy mud build.   1993 Craftsman LT4000 heavy mud build. - Page 5 Icon_minitimeMarch 3rd 2018, 1:08 pm
That's the cleanest mud I have been in for a year or so. No gravel or sand or rotten fish !!! Cleaned up pretty well considering every inch of fenders was plastered.
PostSubject: Re: 1993 Craftsman LT4000 heavy mud build.   1993 Craftsman LT4000 heavy mud build. - Page 5 Icon_minitimeMarch 10th 2018, 7:50 pm
No words needed except I am looking for 2 820s or a 633.1993 Craftsman LT4000 heavy mud build. - Page 5 20180351
1993 Craftsman LT4000 heavy mud build. - Page 5 20180349
1993 Craftsman LT4000 heavy mud build. - Page 5 20180352
1993 Craftsman LT4000 heavy mud build. - Page 5 20180350
1993 Craftsman LT4000 heavy mud build. - Page 5 20180358
1993 Craftsman LT4000 heavy mud build. - Page 5 20180357
1993 Craftsman LT4000 heavy mud build. - Page 5 20180354
1993 Craftsman LT4000 heavy mud build. - Page 5 20180353
1993 Craftsman LT4000 heavy mud build. - Page 5 20180355
1993 Craftsman LT4000 heavy mud build. - Page 5 20180356
PostSubject: Re: 1993 Craftsman LT4000 heavy mud build.   1993 Craftsman LT4000 heavy mud build. - Page 5 Icon_minitimeMarch 10th 2018, 7:59 pm
Holy hell man!
I think she would have done alright with a straight axle and axle supports...
PostSubject: Re: 1993 Craftsman LT4000 heavy mud build.   1993 Craftsman LT4000 heavy mud build. - Page 5 Icon_minitimeMarch 10th 2018, 8:00 pm
Good Lord that is some wicked destruction. Did it bend the frame on that left side?
PostSubject: Re: 1993 Craftsman LT4000 heavy mud build.   1993 Craftsman LT4000 heavy mud build. - Page 5 Icon_minitimeMarch 10th 2018, 8:20 pm
Holy hell man!
Yeah , or just a stronger case........ it might have been because of my locked front end that put too much force on the diff. Still I want to run around screaming big obscene words and blow the mower up .
Ak, the frame doesn't bend, cause of how well i reinforced it, but the tranny mount did bend slightly.
PostSubject: Re: 1993 Craftsman LT4000 heavy mud build.   1993 Craftsman LT4000 heavy mud build. - Page 5 Icon_minitimeMarch 10th 2018, 8:32 pm
Ah, yeah it looks like the mount bent a bit. Still pretty wild though, haha. Should put those pictures in the FAIL thread.
PostSubject: Re: 1993 Craftsman LT4000 heavy mud build.   1993 Craftsman LT4000 heavy mud build. - Page 5 Icon_minitimeMarch 10th 2018, 8:36 pm
There's a fail thread???????? I belong in there lol
PostSubject: Re: 1993 Craftsman LT4000 heavy mud build.   1993 Craftsman LT4000 heavy mud build. - Page 5 Icon_minitimeMarch 10th 2018, 8:38 pm
PostSubject: Re: 1993 Craftsman LT4000 heavy mud build.   1993 Craftsman LT4000 heavy mud build. - Page 5 Icon_minitimeMarch 10th 2018, 9:30 pm
OUCH! That sux. I hope you got a lot of fun in before the break. Hope you can find another trans for a good price.
PostSubject: Re: 1993 Craftsman LT4000 heavy mud build.   1993 Craftsman LT4000 heavy mud build. - Page 5 Icon_minitimeMarch 11th 2018, 7:02 am
Wow look at the carnage. What kind of transaxle was this one?
Page 5 of 13Go to page : Previous  1, 2, 3, 4, 5, 6 ... 11, 12, 13  Next
» Craftsman LT4000 utility / mower build
» 1995 Craftsman LT4000 Off-Road/Mud Build
» My new trail machine- 1993 Craftsman II
» Craftsman Lt4000 mild off-roader
» Craftsman lt4000
