 1993 Craftsman LT4000 heavy mud build.
11 posters
Go to page : Previous  1, 2, 3 ... 10, 11, 12, 13  Next
1993 Craftsman LT4000 heavy mud build. - Page 11 Empty
PostSubject: Re: 1993 Craftsman LT4000 heavy mud build.   1993 Craftsman LT4000 heavy mud build. - Page 11 Icon_minitimeMay 21st 2018, 8:55 pm
This tractor made for a great new avatar!
ditto, The craftsman is looking very nice. Love the stance.
PostSubject: Re: 1993 Craftsman LT4000 heavy mud build.   1993 Craftsman LT4000 heavy mud build. - Page 11 Icon_minitimeMay 21st 2018, 10:11 pm
How about a new forum header?....... hehe
Anybody got ideas for making a tranny vent for the 820?
PostSubject: Re: 1993 Craftsman LT4000 heavy mud build.   1993 Craftsman LT4000 heavy mud build. - Page 11 Icon_minitimeMay 22nd 2018, 7:16 am
I'm pretty sure you pipe tap the fill plug hole for 1/4-18 NPT
PostSubject: Re: 1993 Craftsman LT4000 heavy mud build.   1993 Craftsman LT4000 heavy mud build. - Page 11 Icon_minitimeMay 22nd 2018, 9:45 am
There is no true fill hole, only the neutral safety switch hole. It's already 1/8" NPT so you can screw whatever fitting into it you want, if you trim a bit off the bottom of them to clear the shift fan.
PostSubject: Re: 1993 Craftsman LT4000 heavy mud build.   1993 Craftsman LT4000 heavy mud build. - Page 11 Icon_minitimeMay 22nd 2018, 10:27 am
I just got schooled, eh oh well. live and learn
PostSubject: Re: 1993 Craftsman LT4000 heavy mud build.   1993 Craftsman LT4000 heavy mud build. - Page 11 Icon_minitimeMay 22nd 2018, 11:21 am
Even easier...
Probably thinking MST?
1993 Craftsman LT4000 heavy mud build. - Page 11 Sig115PROJECTS:
1993 Craftsman LT4000 heavy mud build. - Page 11 Sig2141993 Craftsman LT4000 heavy mud build. - Page 11 Sig314
PostSubject: Re: 1993 Craftsman LT4000 heavy mud build.   1993 Craftsman LT4000 heavy mud build. - Page 11 Icon_minitimeMay 22nd 2018, 11:28 am
Well since I am in town I will see if I can get a screw in fitting.
PostSubject: Re: 1993 Craftsman LT4000 heavy mud build.   1993 Craftsman LT4000 heavy mud build. - Page 11 Icon_minitimeMay 22nd 2018, 5:59 pm
Well didn't end up getting a fitting so made my own by using a tapered air fitting and heating it up and poking it in the middle of the plastic screw in cap and then doused in in water to seal it up . Then ran a line from it to on the side of the console with a pleated fuel filter under a loop that should act as a trap if I ever get any water near it. Had a spring line protector so put that on the part closest to the belt and moving parts .1993 Craftsman LT4000 heavy mud build. - Page 11 20180535
1993 Craftsman LT4000 heavy mud build. - Page 11 20180532
1993 Craftsman LT4000 heavy mud build. - Page 11 20180530
1993 Craftsman LT4000 heavy mud build. - Page 11 20180531
1993 Craftsman LT4000 heavy mud build. - Page 11 20180533
1993 Craftsman LT4000 heavy mud build. - Page 11 20180534
PostSubject: Re: 1993 Craftsman LT4000 heavy mud build.   1993 Craftsman LT4000 heavy mud build. - Page 11 Icon_minitimeMay 22nd 2018, 6:54 pm
Looks good. I like the spring idea.
PostSubject: Re: 1993 Craftsman LT4000 heavy mud build.   1993 Craftsman LT4000 heavy mud build. - Page 11 Icon_minitimeMay 22nd 2018, 6:55 pm
Nice job, should work great!
I think it needs some taller, thinner front tires.
PostSubject: Re: 1993 Craftsman LT4000 heavy mud build.   1993 Craftsman LT4000 heavy mud build. - Page 11 Icon_minitimeMay 22nd 2018, 7:39 pm
Thanks! Yeah these fronts have got to go, but I need to completely rebuild the front end to accommodate suspension. Really liking the mono link setup as it looks sturdier and less linkages and joints to mess with, plus more steering
PostSubject: Re: 1993 Craftsman LT4000 heavy mud build.   1993 Craftsman LT4000 heavy mud build. - Page 11 Icon_minitimeMay 22nd 2018, 7:40 pm
Maybe just cut the Murray apart and use those parts.
PostSubject: Re: 1993 Craftsman LT4000 heavy mud build.   1993 Craftsman LT4000 heavy mud build. - Page 11 Icon_minitimeMay 22nd 2018, 7:47 pm
Was thinking of doing that but I want a beefier setup than that. Will probs my use it's front on the muckraker.
PostSubject: Re: 1993 Craftsman LT4000 heavy mud build.   1993 Craftsman LT4000 heavy mud build. - Page 11 Icon_minitimeMay 22nd 2018, 7:48 pm
A 1-link setup would be awesome on this rig! Be nice if you could find some nice some coils to use so you could have some good travel.
PostSubject: Re: 1993 Craftsman LT4000 heavy mud build.   1993 Craftsman LT4000 heavy mud build. - Page 11 Icon_minitimeMay 22nd 2018, 8:01 pm
Yup. Will have to use smaller tires so I don't jack up the front end and whack off my hood whenever I flex it .
PostSubject: Re: 1993 Craftsman LT4000 heavy mud build.   1993 Craftsman LT4000 heavy mud build. - Page 11 Icon_minitimeMay 22nd 2018, 9:28 pm
I like the filter under the dash.  Is the vent line taped to your shifter?  It's looks awfully close to the belt too but sometimes these pictures distort distance quite a bit.
PostSubject: Re: 1993 Craftsman LT4000 heavy mud build.   1993 Craftsman LT4000 heavy mud build. - Page 11 Icon_minitimeMay 22nd 2018, 10:41 pm
The tube is loosely zip tied to the shifter, bit it has the protective cage that prevents rubbing through the rubber hose, and the belt is about an inch from the tube that is also covered in protective covering.
Drove it to mow at the neighbors tonight and looked down to see my left rear tire wobbling back and forth like a bobble head . Somehow my lugs were not tightened down and had been loosening up over the drives it has had. Borrowed a ratchet and tightened then back up and good as new. Headlights are quite a nice feature when driving back at night. Front tires are out of balance and have flat spots so it goes up and down when driving fast.
PostSubject: Re: 1993 Craftsman LT4000 heavy mud build.   1993 Craftsman LT4000 heavy mud build. - Page 11 Icon_minitimeMay 26th 2018, 8:09 pm
Brought back the Murray from the woods with this beast. Rows a trailer very well but does bog down a bit in 5th at idle lol. Swapped the front tires back to the skinny ones and it really improved the steering and hopefully improves how this thing handles in mud. Also made that stance more equal or better looking anyway.1993 Craftsman LT4000 heavy mud build. - Page 11 20180548
1993 Craftsman LT4000 heavy mud build. - Page 11 20180547
1993 Craftsman LT4000 heavy mud build. - Page 11 20180549
PostSubject: Re: 1993 Craftsman LT4000 heavy mud build.   1993 Craftsman LT4000 heavy mud build. - Page 11 Icon_minitimeMay 26th 2018, 8:14 pm
Yeah it definitely looks nicer with those fronts on there. Are they a bit taller than the rear tires?
PostSubject: Re: 1993 Craftsman LT4000 heavy mud build.   1993 Craftsman LT4000 heavy mud build. - Page 11 Icon_minitimeMay 26th 2018, 8:15 pm
23's on front, 22's on rear.
PostSubject: Re: 1993 Craftsman LT4000 heavy mud build.   1993 Craftsman LT4000 heavy mud build. - Page 11 Icon_minitimeMay 26th 2018, 8:18 pm
Ah, I see. Thought it looked like it in the second picture, haha. Still pretty cool looking though!
PostSubject: Re: 1993 Craftsman LT4000 heavy mud build.   1993 Craftsman LT4000 heavy mud build. - Page 11 Icon_minitimeMay 26th 2018, 10:08 pm
The plan is to have larger tires on the back eventually . Maybe still itp mudlites but 25" instead of 22"
PostSubject: Re: 1993 Craftsman LT4000 heavy mud build.   1993 Craftsman LT4000 heavy mud build. - Page 11 Icon_minitimeJune 4th 2018, 9:05 pm
So I plan on getting some more aggressive tires to put on the new 12 inch rims I have for this mower. 25×8×12 is the size I think I am going to go with. Probably going to use itpud lite xls as they are cheap and have good lugs with that nice trademark tread pattern.
PostSubject: Re: 1993 Craftsman LT4000 heavy mud build.   1993 Craftsman LT4000 heavy mud build. - Page 11 Icon_minitimeJune 8th 2018, 12:00 am
Hehe. Man these are going to look killer on this thing. Also went mudding earlier and got pretty stuck once my tires dug down and bottomed out the tranny on the mud. Went in water up to the bottom slat on the grill, had a blast tho, and these new tires will really improve the performance of it I hope. Should get them in the mail next week and get them mounted up for a test drive.1993 Craftsman LT4000 heavy mud build. - Page 11 Img_1512
PostSubject: Re: 1993 Craftsman LT4000 heavy mud build.   1993 Craftsman LT4000 heavy mud build. - Page 11 Icon_minitimeJune 8th 2018, 9:07 am
Very nice!
PostSubject: Re: 1993 Craftsman LT4000 heavy mud build.   1993 Craftsman LT4000 heavy mud build. - Page 11 Icon_minitimeJune 8th 2018, 9:17 am
Yup, can't wait to get them ! The mud lites on it right now are going on the gt3000 for better traction and a slightly pulley swap so I have another machine for a friend to drive or another one to pull out the other mower when it gets stuck (hopefully the executioners will prevent getting stuck again so easily. )
Page 11 of 13Go to page : Previous  1, 2, 3 ... 10, 11, 12, 13  Next
» Craftsman LT4000 utility / mower build
» 1995 Craftsman LT4000 Off-Road/Mud Build
» My new trail machine- 1993 Craftsman II
» Craftsman Lt4000 mild off-roader
» Craftsman lt4000
